Question about Whirlpool GS6NBEXR Side by Side Refrigerator
Roper fridge freezer not freezing
My fridge is staying cool, but everything in the freezer thawed. I checked the coils in the back of the freezer and they are not frozen over. They dont seem to be that cold at all. Any help?
    Sergeant:
    Champion:
  • 214 Answers
Sir, To solve this problem, you must open the compressor area at the back bottom of the refrigerator and chek the temperature of the pressure line. If the temperature is between 55celcius to 60 than its ok. Or else you need to change the refrigerant. I suggest you to contact the service authority.
Thanks for contacting Fixya.
Posted on Sep 12, 2009
Freezer coil freezes up the fan is spinning above the coil but the coil is frozen solid is it the defrost timmer, roper model rtbkxkqoo
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 27, 2011 | Refrigerators
Freezer works fridge does not
Needs to be completely thawed for 2 days. Or wlse the circulator fan under the freezer panel inside freezer is not working. Take the plastic bottom of freezer out and let thaw. Then plug in fridge and check if the fan is running inside there. Do not poke around inside there or fridge will be punctured and ruined.
Jan 28, 2011 | Roper RT14DKX Top Freezer Refrigerator
Maytag msd2454gr side by side. The evaporator coils freeze up and the fridge gets warm. This happened about a year ago and I thawed it out and everything was fine. It happened again about a week ago so...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
Aug 30, 2010 | Maytag MSD2454G Side by Side Refrigerator
Freezer doesn't freeze Food is thawing in the freezer
if the compressor and freezer fan are on and not getting cold, check the condenser coils under the fridge. clean them out with a vacuum. if they can't release heat, the freezer won't cool. also check the fan in the back. replace it if it is not running. if the inside coils are frozen up, there is no air flow. defrost them and check the fan. otherwise you have a freon leak.
Nov 13, 2009 | Refrigerators
Our refrigerator/freezer will stop working (not cool or freeze) then days later will begin to work again.
i find it hard to believe the compressor is going out,if the fridge is staying cold,put a thermometor in the fridge and it should stay about 32 degrees,ideally around 40 is a good temp.if the freezer isnt staying below 32 degrees then it sure sounds like a thermostat problem.But i have heard of computers in these newer refridgerators but havent worked on any just yet.
May 09, 2009 | Roper RT18DKXKQ / RT18DKXKT Top Freezer...
Coils freeze up,refridgerator and freezer stops working
The defrost cycle is not working properly, there are three things involved in system. #1 Defrost timer in refrigerator #2 Thermostat on coils to tell if unit is frozen #3 heater element located under coils thaws coils when frozen. the defrost timer if it is manual < located at the front of light assembly panel in top of refrigerator there will be a hole with a plastic piece that resembles a screw strait screw head> it turns and every 8hrs aprox. it stops operations and starts defrost cycle by allowing voltage to the thermostat and if thermostat is frozen it allows power to element for thawing coils. If defrost timer is manual look for direction it is facing and mark edge to see if timer is turning< very slow turning and is easiest way> if you can get an ohm meter ohm the element on high setting< if it has continuity element is operable> check wiring just to be sure not problem. If you find the timer does turn and doesn't stay in one position over 40 minutes then the thermostat is bad.If element fails tesing then the element is bad and if timer stays in one position then it is bad. If unit is equiped with electronic defrost timer and element is good in would replace timer and thermostat to guaranty that resolved problem
Apr 22, 2009 | Refrigerators
Need to unplug drain tube in 2005 roper fridge I have a Frigidaire frs26zgh. I have ice buildup in the bottom of the freezer too. I pulled everything out of the freezer including the shelves and the back...
you can thaw it out by pouringboiling water down the drain trough, or use a hairdryer to assist you, ( i actually use the steam machine bought form the t.v.) afte clearing the ice, water will flow down the tube normally
Nov 09, 2008 | Refrigerators
Whirlpool GS6NBEXR Side by Side Refrigerator Logo
172 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
