Question about Coleman Powermate DuraBuilt 1400 PSI Pressure Washer
Where can i find a replacment attachment for my pressure washer gun
    Sergeant:
  • 384 Answers
Any hardware or home improvement store.
Posted on Sep 08, 2009
Why is there no water flow through on pressure washer?
Sounds like a pump failure. Does yours freeze in winter? Need to winterize like cabin plumbing.
Repair/replacement of pump could be close to new unit.
Aug 19, 2014 | Powerboss 2600 PSI Gas - Cold Water...
Where can I find a replacement for the trigger handle for task force 2000
There are quite a few replacement guns and hoses. If you do a search; " replacement power washer guns" you will have many sites wit numerous guns that will work.
  • Sorry, this item is not available in
  • Image not available
  • Amazon com Powerwasher 80012 Universal Electric Pressure Washer...
    Jun 03, 2014 | Task Force 2000 PSI Electric Pressure...
    Doesn't stop spraying after trigger is released
    Dear Peggy,
    You can have a problem with the valve at the gun which is sticking open. This valve can be OK without pressure, but with pressure it can stick open. It is very easy to make sure, by attaching a good gun or a new gun. In simple words...replace the gun.
    Regards,
    Fulltech.
    Feb 27, 2014 | Karcher K3.68MR Electric Pressure Washer
    Engine runs , not getting any water flow when trigger pressed.
    Disconnect hoses.
    Look for kink in water hose.
    Check incoming water connection for filter washer
    Replace filter washer
    If you don't have a filter washer, put one in.
    Hook up water, and turn on
    Water should come out other side of pump.
    Turn on machine.
    Do you get pressured water out of pump.
    If no pressure, then pump is suspect
    Hook up washer hose without gun
    Does pressure come out of washer hose
    Finally, the gun trigger may be bad.
    We had to buy guns now and then.
    Search for pressure washer guns
    Following link shows guns we used:
    http://www.ultimatewasher.com/pressure-washer-trigger-guns.htm
    Oct 25, 2010 | Karcher G2650HHR Gas Pressure Washer
    I bought this about 2 months ago i have used it twice in the middle of rinsing my truck off the high pressure got really faint now it is not spraying hard at all what could be going wrong
    We had problems like that before with our power washer. The pumps go bad. Even on new equipment. What's your warranty look like?
    Another thing is the water gets stopped up.
    Remove gun and hose.
    Turn on machine and see if you get full pressure shooting out of pump.
    Next, check the incoming water line.
    Most power washers have a screen washer >>> replace screen washer, then fire up again without hose attached.
    Gun triggers also fail. I think we had to replace guns when they went bad.
    As a rule, I always read the manual front and back.
    There are interesting things in the manual that neither of us know right now.
    The manual may give you a hint.
    If you need more help, answer back and I will look up the manual if available and see if together we can troubleshoot the problem further.
    Oct 24, 2010 | Honda Black Max 2600 PSI Pressure Washer
    How do we get the cleaner to go up the hose
    We used to add a clorox mixture when we power-washed
    There is a special fitting that goes on the power washer line
    The fitting is a T with 2 quick connects that match your pump&hose quick connects
    The T fitting attaches to pump >> the power washer line attaches to T
    The T fitting has a short extension where you attach a plastic hose that goes to your bucket of clorox
    The T has a small one-way ball valve that only lets clorox enter the power washer line, but power washer pressure doesn't escape into the clorox
    The small ball will clog over time, so when you buy a T, see if you can get replacement part
    When you pull the trigger, the pump pressure shoots water out of the gun
    The water pressure shooting out of the gun creates a suction that draws up the clorox
    The clorox enters the line and gets shot out of the gun
    The same basic idea is used on shallow well pumps
    We discovered after a few years that is was easier-to-control and cheaper to apply the clorox with a pump-up hand sprayer. We could apply more clorox. The machine was not exposed to chemicals.
    Remember the engine draws-in surrounding vapors and those vapors can chew up the metal parts of any combustion surface.
    Oct 19, 2010 | Black & Decker Garden
    Water does not come out of the lance when I squeeze the trigger
    HI it sounds like you may just have a blocked jet on the end of your lance. Please remove and clean.
    May 31, 2010 | Northstar Professional Series Pressure...
    I have an electric power washer k3.99M. I just replaced the pressure hose and now the washer will not turn on. If I remove the unit from the water hose, it works, but when I hook everything back up, it...
    This sounds like the hose is plugged or the nozzle itself is plugged. If the water cannot get through, the washer senses that the trigger is off and will not turn on the pressure. First just attach the hose without the gun and nozzle. If it pumps water, you know the hose is OK. Then attach the hose and gun ant try it. If it still works then you know it is the nozzle.
    Aug 25, 2009 | Karcher Garden
    Coleman Powermate DuraBuilt 1400 PSI Pressure Washer Logo
    121 people viewed this question
    Top Coleman Garden Experts
    John Trevino
    Simon Flummox
    Simon Flummox
    Are you a Coleman Garden Expert? Answer questions, earn points and help others
