Question about OKIDATA ML590/ N 24PIN NARR 360CPS PAR/ ENET 120V; COMES WITH 6FT PARALLEL CABLE Printer
My Oki ML590 prints symbols and advancing labels longer than befo
I was messing under the menu setting and pressed Print, Set, Item, Group separately and did not get out of the menu function when someone else printed a label. The label printed garbage combo of letters and symbols and skipped a lot of labels than it should. How can I bring back the settings it had before and also make it skip only one label?
I print labels with my Microline 320 Turbo. I put a new ribbon in and the labels are so wet and bold and after sitting for awhile they bleed until you can't read them. I have the lever on the print head...
This results from theway the print head is striking the paper. If you have it set to NLQ. it will be heavy, you can set it to a draft mode or SSD:
Print the Menu Settings, to see what your settings are:
Printing the settings is the only way to have a record of
the settings.
1 Make sure paper is loaded in the printer.
2 Enter the Menu Mode (SHIFT + SEL).
3 Press PRINT (PARK key).
Print Quality
! Important!
Front panel settings for print quality and character
pitch are overridden by software commands.
The lights will always reflect the printer's state.
Press PRINT QUALITY to select:
NLQ: Near Letter Quality
• Highest quality, slowest speed
• Courier or Gothic fonts
• Recommended for correspondence
UTL: Utility
• Medium quality, medium speed
• Gothic font only
• Recommended for internal documents and high-volume
data.
HSD: High Speed Draft
• Lower quality, faster speed
• Gothic font only
• Recommended for drafts.
SSD: Super Speed Draft
• Lowest quality (12 cpi only), fastest speed
• Gothic font only
• Recommended for fastest output of drafts.
Super Speed Draft
To use Super Speed Draft (SSD), enter the Menu Mode and
make changes as follows:
1 Press SHIFT + SEL.
2 Press GROUP twice.
3 Press SET until DRAFT prints as the setting for the Print
Mode.
4 Press ITEM.
5 Press SET (SSD prints).
6 Press SHIFT + SEL to exit Menu Mode and save your
changes.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 01, 2011 | OKI MICROLINE 320 Turbo Matrix Printer
I have an I Mac 10.58. I have typed into an Address Book 62 addresses that are stored on an Address on an a group labeled "Xmas Group." Separately I have typed into "labels" the #8167. What is the...
Have the group selected and then select print from the file menu.
Make sure that the arrowhead next to you printer name is pointing upwards.
Under the from to page selector it should say Address Book.
Below that is should say Mailing Labels
On the next line down select the 'Layout" tab.
Check that you have selected US letter then select 8167.
Then hit print.
That's all there is to it. I just tried and it printed 4 columns of 20.
Dec 20, 2009 | Computers & Internet
Oki 320 turbo, serial interface, how do I change
To change the settings, make sure you have a good ribbon installed.
Press the MODE button. The SEL light will go out. Menu light will come on.
Press the GROUP button until the printer prints something like:
Serial Interface Parity None
To change the Parity, press SET. A new line will print as:
Serial Interface Parity Odd
Press SET until the Item is the one you want.
Then Press the ITEM button. It will then print:
Serial Interface Serial Data 7 or 8 bits 8
Again if you want to change it, press SET. Otherwise go to the next Item.
Continue using the ITEM button to choose the item you want to review or change and the SET button to change the selection.
When you have made all the changes verify by going through all of the items with the ITEM button. When you are satisfied, Press the MODE button to save all of the changes. (The Menu light will go out.)
If you have any trouble Comment back.
Thanks for using Fixya.
Aug 11, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
OKI Microline 591 prints extra page of paper everytime
There is a setting on most printers to print a separator page at the end of print jobs. You can check the settings of your printer by going to the control panel and clicking on printers. Select your printer, right click and go into properties. The setting for this is usually located in the advanced settings. See if the printer is set up to print a separator page, if it is, uncheck it, press apply/ok button and close out printer window.
Jul 10, 2009 | OKI MICROLINE 591 Matrix Printer
Microline 320 Turbo Print Quality Settings
You need to set it in Menu Mode -
Press MODE - the SEL light will go out. The menu light goes on. Press Group and the first line of the menu prints.
Gropu of related items keep pressing group until you see the print mode menu printed - once on the line press SET - keep until the printer prints the setting you want.
After you are finished press MODE to save the changes
Jun 19, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Printing a label 4x 1 7/16
Try setting the page lenght using the printer panel
To do this, enter MENU mode by pressing SHIFT+MENU
press GROUP button until prints REAR feed or BOTTOM feed ( depend on where you load the forms from )
Press ITEM button until it prints form length
Press SET to change length as required
To exit, repeat SHIFT+MENU
All the best
KM Hoo
Feb 11, 2009 | OKI MICROLINE 590 Matrix Printer
Setting up printer for reports & checks
Press SHIFT+MENU together to enter MENU mode
press GROUP until it prints EMULATION - make sure it doesn't shows UTILITY
Best Rgds
KM Hoo
Dec 28, 2008 | OKI MICROLINE 590 Matrix Printer
Language
Enter the menu,
Change Language set to American. It is under symbol sets. Also change code page to usa.
Menu Mode
1. Verify that paper and the ribbon are installed.
2. Power ON the printer.
3. Press SELECT and place the printer OFF-LINE (SELECT will not be lit).
4. Press QUIET to enter Menu Mode.
5. The line shown below will print.
Printer Control Emulation Mode Epson LQ 6. Go to Step A to print the current menu.
Go to Step B to change the menu.
Step A
Press PRINT to print the current Menu.
Press EXIT to exit Menu Mode.
The printer will go ON-LINE. (SELECT will light.)
Step B
Press GROUP to move through the groups of the Menu.
A line prints, showing the Group.
Press ITEM to move through the items in a group.
A line prints, showing the Item.
Press SET to change the setting for an item.
A line prints, showing the Setting.
Feb 15, 2008 | OKI MICROLINE ML-395 Matrix Printer
Problem with oki microline 395
Enter the menu,
Menu Mode
2. Power ON the printer4.gif.
5. The line shown below will print4.gif.
Step A
Step B
A line prints4.gif, showing the Group.
Trouble with changing the size of letter
Press the select button so light would go off than press 2 buttons marked menu than press print,this will print out the menu settings .When done press the group button till rear group prints than press item till page lenght prints,now press the set button till the desired page length is reached,than press exit button to save setting and exit from menu.Power off the printer then power back on should be ok .Hope this helps.
dezzi
Feb 04, 2008 | OKI Pacemark 3410 Matrix Printer
54 people viewed this question
Top OKI Office Equipment & Supplies Experts
WTF Chuck.....
WTF Chuck.....
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
