Question about Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin
Recoil has hung up twice on new saw never got to use it
  • 5,438 Answers
Yes these saws run well if you can ever get one started. Very hard to crank and recoil mech is all plastic junk. I hate mine and will never buy another Poulan product.
Posted on Jan 14, 2015
    President:
  • 2,220 Answers
Return it to the bix box store where you purchased it; get a refund. Find a chainsaw shop that sells and services their product.
Lou
Posted on Sep 08, 2009
Mccullugh MCC1840 18" chainsaw. Gas pouring out bottom of saw. How do I get to the gas tank?
The fuel tank is part of the rear handle support body.
The fuel line to the carburetor goes into the top of the tank.
You will also find a return line from the air purge primer bulb. More than likely, one of these lines has broken or cracked. Gain access to some of the lines be removing the recoil assembly.
1) Remove the Air Filter and Filter Cover
(which you have already done)
2) Remove the recoil assembly to gain access to the primer lines.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Feb 14, 2017 | Garden
How to fix my Tanaka chainsaw rope to recoil back?
replace teh recoil section as there is a problem with the spring or the pulley section holding the cord.
Apr 26, 2015 | Tanaka TCS33EB/14 32 cc Gas Powered 14-in...
Recoil spring problem
I have the same chainsaw and have never had a problem with it.
If you have changed the starter rope or recoil spring in the past, it is important that you hold the new spring with needle nose pliers and install it correctly. Once the spring is in make sure wind the rope correctly-clockwise. If not the new spring will be damaged.
Sep 14, 2014 | Poulan Pro PP5020AV 50 cc Gas Powered...
Ryobi ss26 trimmer puller cord won't retract
It appears that the recoil spring has broken and you will have to pull it apart to replace it
Jun 17, 2013 | Ryobi Multi-Volt Battery Charger
What's the trick to installing a flat coil spring into a chain saw recoiler without having it spring out
If you are having to recoil the spring after its come out. Roll it tightly with your hands then use vise grips on one side pinching it together then you can place it in the retainer/pulley. release
Oct 18, 2012 | Craftsman sears 18" Chain Saw Chain (...
Can not start the ms180 chain saw, tried new plug, new gas, starting fluid etc. suggestions ran this morning, and now will not start. only been used twice
Remove the plug and then plug into plug wire. With the spark plug laying on top of engine pull the recoil a couple times and you should see spark at the plug. If all is good and there is the proper mixture of gas/oil ratio in saw then >>With trigger depressed fully and choke on, pull until it fires and then shove the choke in. /////If no spark and the saw is new, I would return to retailer.
Sep 25, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Homelite model No. 10609. 1H2100076 My pull rope won't recoil.
Not that i know of, take the cover off and rewind by hand, use greese on the coil and pull the rope in and out, if the rope doesnt recoil you are going to need a new pull start assembly
Apr 28, 2010 | Homelite ZR10926 16 Chain Saw
Recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Jul 04, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chain saw starter rope won't recoil
recoil spring is broke. homedepot has a new one
May 23, 2009 | Garden
Pull cord all the way out, and will not recoil
I started to take mine apart but when i loosened the 4 screws on the yoke the string rewound so ive been running it like that.
May 16, 2009 | Homelite Mighty Lite Lawn Trimmer
Poulan Wild Thing 2375 18" Gas Chain Saw 2.5 Cuin Logo
94 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
