Question about HP Office Equipment & Supplies
All lights flashing
Error message 0x886@69f6
beloow that ????etc
  • Anonymous Feb 14, 2008
    Hp 1600C Two lights flashing. One is the paper light and the other is the ink light
  • jhassen1 Feb 18, 2009
    HP Officejet 7310 All-in-One: all lights flashing. Requires a reset (unplugging the power). May be driver or software related. Happens most often when running i tunes.
  • 619 Answers
The ink you install are genuine ?
The paper tray are loaded?
Check the paper loading tray if their is any foreign object such small pieces of papers or coins.
Replace w/ genuine HP ink
Posted on Jan 05, 2008
My dell inspiron mini 10 won't boot.There is just a flash of white light then a flash of amber light when I press the power button. That's it, nothing else.
Remove the main battery and try again, also! the power adapter charger should be checked for correct voltage, if okay! pull one stick of ram and test, and the second piece not forgetting to put the first one back and power up, if all this fails you will need to get it assessed.
Mar 25, 2012 | Dell Inspiron Mini Netbooks
Machine stopped mid cycle and green light flashing under green start button
Many modern washing machines display error codes if they detect a fault, but not all washing machines display a readable error code, some indicate an error by flashing, or lighting some of the lights.
Hotpoint, Indesit, Zanussi error codes
Hotpoint, Indesit washing machines and Zanussi washing machines are some common appliances that display coded error codes. On their more expensive models, they display readable error codes but basic models (without digital displays) use flashing lights to convey the error fault code.
If your washing machine malfunctions and you can see some of the lights flashing, or one or more option lights have lit up, then make a note of which lights are flashing and which option lights are lit. NOTE: the error code list engineers have only shows the option lights by number and not by name. Therefore you need to report the lights as LED 1 and 3, or 2 and 4 etc. and NOT "delay timer" and "extra rinse". Count the lights from the left (or from the top if in a column) and report as "led 1 and 3" etc.
No Option lights?
With basic washing machines that have no option indicator lights, count the number of flashes. For example, the door locked indicator may flash 7 times, pause, and flash another 7 times in a constant cycle which would indicate error code 7.
This information is vital, and needs mentioning when reporting a fault.
Jan 18, 2011 | Zanussi FJS1225W Front Load Washer
One red light flashing crashing of games and dvd's e73 or e74 error
Call Xbox support1800-426-9400. The error message it's trying to give you depends on WHICH light is blinking, top-left, top-right, etc.
Jul 17, 2010 | Microsoft Xbox 360 Console
Error message F-01 & flashing lights etc I have a Hotpoint aquarius, WMF740. Suddenly returning to the kitchen I noticed an error message - the machine was switched off - which says F-01 and flashes...
Error code F01 indicates a short circuit motor triac.
You need to check connections on the motor, the motor plug and the module.
Having said that, you really should ring the manufacture, as the washer is still obviously under guarantee, and should be fixed at no cost to you.
The point to bear in mind is that if you do anything to it yourself, then in theory, you could invalidate the guarantee.
So, unless it is anything obvious, then I would advise you ring the manufacturer.
Hope this is of assistance to you.
Please rate my solution.
Dec 21, 2009 | Hotpoint Washing Machines
Amber light is blinking, error message when printing
Generally means that you're out of ink in your ink cartridge. Note that the NUMBER of times it flashes is significant: if it's 2 or 3 flashes at a time, then it's a paper problem (jam, out of paper, etc.), otherwise it's an ink problem (replace the cartridge).
Oct 14, 2009 | Canon PIXMA iP1600 Printer
When trying to send a message, I can't - told to go to adobe,etc.
you need Adobe flash player support in your web browser.
Download Adobe flash player, below is the download link
Note: you may not be able to install Adobe Flash Player if you keep the browser open.
Close all your Internet browser like Internet Explorer, Opera or Mozilla Firefox etc. and install the software.
your's problem will be solve.
Rate this Solution.
Sep 02, 2009 | Facebook Social Network
Epson TW10 Projector displaying "error in epson cinema filter"msg
What is the error message? Are there lights flashing on the panel? Keep us posted. thanks!
Nov 29, 2008 | Epson EMP-TW10H Multimedia Projector
Will not function on front feed
check all paper paths for little pieces of paper
Apr 23, 2008 | Canon PIXMA iP4200 InkJet Photo Printer
Lights flashing
the flashing lights is an error message, the flasshing may be a sequence of flashes, which designates an error code. speek to the tech support from the manufactur to decode the message & see if there is an easy solution
Oct 04, 2007 | Canon PIXMA iP4200 InkJet Photo Printer
Print head jam
Iv'e seen these problems a 100000000 times with this printer and I found a little article you may wanna read before going farther with this machine!!!! Go to
Apr 19, 2006 | Epson Stylus C80 InkJet Printer
523 people viewed this question
Ben Johnson
