Question about Dryers
I have a kenmore elite HE2 dryer and it takes 2 or 3 times before the clothes are dry
    Sergeant:
  • 244 Answers
Know this may seem simple, but the lint filter needs to be cleaned after every load- some times twice- 'specially if you have cats, or heavy blankets, or lint prone fabrics. might try using vacuum cleaner to clean vent tube, or check external vent louvers. blocked or repressed airflow can really slow the drying process!
good luck!
Posted on Sep 09, 2009
Clothes with pin holes are seen afetr washing/drying with He2 plus/He Washer dryer combination
Are you over loading the dryer? I know those combo machines can't dry a lot at once
Apr 28, 2012 | Kenmore HE2 Plus Front Load Washer
Take 3 or4 time to dry cloth in kenmore elite dryer gas
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Sep 27, 2010 | Kenmore Elite Oasis 7808 Gas Dryer
Dry take hours to dry
need to check hi limit thermostat on element make sure it is not cycling to soon
Apr 13, 2010 | Kenmore Elite HE4 Electric Dryer
I have a kenmore HE2 dryer and matching washer. It is 3 years old. It works and eventually clothes do dry. It does heat up. But it doesn't heat up as hot as it used to and it takes twice as long to dry...
Make sure you check your exhaust line and where the air blows to the outside. If your exhaust vent or hose is bent or restricted it will take a very long time to dry the clothes. Sometimes the vent flap on the outside exhaust is stuck shut. Clear dryer exhaust venting is critical for proper operation. Several companies offer a vent cleaning service where they completely clean out the exhaust lines.
Feb 02, 2010 | Kenmore HE2 Plus Front Load Washer
Kenmore Elite He3 dryer..fine on timed but leaves cloths wet auto
find the metal sensors in the drum
scratchem up with sand paper
especially if you wash rugs, sneakers , or anything with acyrlic
Oct 05, 2009 | Kenmore Elite HE4 Electric Dryer
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Kenmore Elite HE3 Dryer clothes not dry after cycle
it sounds like a clog in vent.if yours vents up thru roof you may need to have a chimney sweep come out and sweep vent.check and make sure the vent hose is net kinked or full of lint.
Mar 06, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore HE2 door bellow
he 2 are a little similar to all H E washer ,, it has spring clamps (2) remove and install them same way
Dec 12, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
193 people viewed this question
Top Dryers Experts
