Question about Garden
Problems starting Husqvarna brushcutter. Starts then cut out has spark to plug and petrol and ideas model R26
SOURCE: Mk1 Cortina engine starting problems
Change the oil. Thick oil winter can cause it, or over diluted oil too. Got similar issue with my mark 1. Bought it but never ran more than 30 secs. Just drained 8 litres of oil out!!! Glad I changed the carby now. Hope you changed the condenser too. Once the plugs are fouled (may look OK) they are no good so might have to change them again.
Posted on Aug 11, 2008
SOURCE: 1998 Husqvarna 265RX Brushcutter Service/Repair Manual
Fixya does not have the manual I'm looking for.
Posted on Nov 27, 2008
  • 334 Answers
SOURCE: husqvarna small chain saw won't stay on and now won't start
check your pick up coil . i had one it done the same thing to and that what it was
Posted on Apr 02, 2009
  • 3567 Answers
SOURCE: My 1999 gilera runner 50cc cut out on me,now it won't start
Remove the water trap bowl at the bottom of the petcock, (gas valve). Is there any water or trash in the bowl? Drain a cup of gas from the tank. Is there any water or trash in the cup? Dump it and clean it. With the gas valve turned off, does gas still get past the valve? If it does, then you need to replace the valve. Re-mount the bowl, ( not all bikes have a water trap bowl ). Always turn the gas off when not riding the bike. If the valve will not fully shut off the gas then a leak-down condition can occur and cause gas to get to the exhaust pipe.
Drain the carburetor. There should be a screw on the lower side of the carb float bowl. Remove the screw then replace it after the fuel drains. Turn the gas back on and wait a minute for the carb to fill with gas. Install a new stock NGK spark plug and try to start the engine. If the bike doesn't start and run properly then shut off the gas and remove the carburetor from the engine.
Remove the float bowl and clean the entire carb with a spray carb cleaner from the auto parts store. Wear protective goggles to avoid getting spray in your eyes. Spray into all the little airways and fittings in the carb. Remove the idle screw and the air screw on the outside throat of the
carb and spray into the screw holes as well.
< < READ CLOSELY > >
Be sure to put these two screws back in the same hole they came out of. IMPORTANT > do not tighten these two adjusters down. Only screw these in until they LIGHTLY seat. Now turn each adjuster one and one half turns outward. Put the rest of the
carb back together, clean the air filter and install the carb. Let the float bowl fill then start the engine. This process should get you back on the road.
Please rate this solution. Thanks!
Posted on Apr 28, 2009
SOURCE: Husqvarna ranger 55 chainsaw starts but quits
I too have a rancher 55 and had what sounds like the same problem this week. It would start fine but run for only a few seconds at a time. I took it all apart today and found the problem - a cracked fuel line. In the places where I could see the hose it looked fine, but it wasn't until I removed the fuel tank that I found the crack...right where it exits the tank and then goes thru the housing above it. You don't need to remove the tank to replace the hose but it is easier that way. You do have to push it thru a grommet at the top of the tank. I read some other posts about checking the tank vent to see that it's not plugged up. Mine was ok so I knew it had to be something else. The vent is in a hole about the size of a pencil and is recessed about an inch into the tank on the upper right side. Its partially covered by a plastic cap that's part of the vibration damper, which can be removed to gain access to the vent. The vent tube can then be pushed out from inside the tank with the use of long needle nose pliers, but be gentle. I just loosened it then pushed it out with a finger. I put it all back together with a new hose and its running like new again!
Posted on May 31, 2009
HOW TO FIX PETROL MIXER STARTS THEN CUTS OUT
problem will be dirt or water in the carby that is blocking the main jet
overhaul the carby,
check for fuel flow to the carby
Jun 25, 2016 | Belle Group Minimix 150 Gas
Husqvarna 65l starts racing after two cuts then cuts out
Hello John , I would suggest you remove the muffler. Between the muffler and the cylinder is a spark arrester screen. Hold the edge of the screen with a pair of pliers and burn off the carbon from the screen with a propane torch. Reinstall muffler and screen after it cools down. I hope this helps.
Mar 12, 2015 | Husqvarna 65 385 395 Hv24-50pa-fb
Husqvarna problems
There are so many reasons for this it could take all day! First check the safety cut-out switches: seat, brake, drive lever and blade control, etc. Then check the battery leads and connections are clean and tight at the battery, starter solenoid and starter. If still no luck make sure the engine will actually turn over by removing the spark plug(s) and turning the drive pulley. Good luck!
Jul 15, 2014 | Husqvarna Garden
My brush cutter keeps cutting out why
Is your fuel mixed correctly.? Do you still have good compression.? Is the choke leaver stuck on.?
May 21, 2012 | Stihl String Trimmer Brushcutter Service...
Husqvarna 40 Chain Saw The saw has been unused for about a year -- before that, always served well. I purchased fresh petrol and a new spark plug, cleaned air filter etc. The I noticed: no spark at all,...
The model 40 has a single piece electronic ignition, it cannot be repaired it will have to be replaced, before replacing, check the air gap between the flywheel and the ignition unit, this should be 0.3mm, also diss connect the earth cut out wire from the terminal on the unit and try for a spark again, this will rule out any fault with the wire or the switch, the ignition works off speed of rotation so you will have to crank the start as if you were starting the machine.
May 13, 2011 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
I have a honda o h c push lawnmower it starts easy but cuts out in about 30 secs
I have the GVC160 motor....same problems....just found this info (see link),...and it turned out that Honda used a NGK spark plug that was defective,....I couldn't believe that is all it was...after changing the carb (new),...adjusting valves....etc.. I just went down and bought a new spark plug.....and it runs great!!
BEFORE go thru all of the advice and look at most other Honda web info.....go and buy a brand new spark plug and start with that! It appears Honda used a NGK spark plug in the past that fails after some time....giving the syptoms of problems with the carb, sticky valve, etc. Do not try to clean and use the old spark plug!! Check this out....it was the answer I was looking for after hours of work, reading, and talking to Honda dealers - http://forum.doityourself.com/outdoor-power-equipment-small-engines/261743-honda-lawnmower-starting-then-cutting-out.html
Sep 05, 2010 | Husqvarna 160 CC Honda OHC Engine 21 in
Brand new Husqvarna R53SV 53cm Petrol Mower wont start. We put petrol and oil in it. Connected the spark plug put the choke to on, Pulled the starter string. Nothing happend. After trying a few times you...
Buy some starting fluid and spray some in the carb or air cleaner intake port, if the machine is flooding do not choke while using the starting fluid, make sure you do not have too much oil in the mowwer.
Jul 15, 2009 | Husqvarna 160 CC Honda OHC Engine 21 in
Husqvarna 385
Sounds like dirty carberator or carb needs adjustment. How is the spark plug?
Jun 22, 2009 | Husqvarna Chain Saw 20" Bar
Garden Logo
67 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
