Question about Samsung T220HD LCD Monitor
No instruction manual
How do i change the order of the channel i have found?
  • 1 more comment
  • magicdice99 Sep 09, 2009
    thank for the advice.
    let me check tonite if i can change the order and if i have the same problem i will let you know.
  • magicdice99 Sep 10, 2009
    through manual tuning i have found some let's say 50 channels. my problem is that they are scattered from channel 1 to 890; i would like instead to put them in order from channel 1 to channel 50.
    when i manually tune it seems i cannot choose where to place the channels i have found.
  • Farhan Jabbar
    Farhan Jabbar May 11, 2010
    You can change the order only with manual tuning.. Dont forget to rate plz
    Scholar:
  • 53 Answers
Http://safemanuals.com/user-guide-instructions-owner-manual/SAMSUNG/T220HD-_E
Posted on Sep 10, 2009
When I put the batteries in the remote it would turn the tv on,I followed the directions for putting the code in and after doing that it won't even turn the tv on.
I've not had much luck with "provided" codes, probably because there are just so doggoned many TV models out there. Most remotes have instructions on how to let the remote itself find the code. I found the manual online
(http://tv.manualsonline.com/manuals/mfg/ge_appliances/24991.html). Adapted from the manual:
1. Make sure you have batteries correctly inserted in the remote.
2. Turn ON the TV manually.
3. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
4. Press and quickly release the desired mode button [TV, in this case]. The red indicator blinks off once.
5. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks off with each button press.
Code Search starts from the currently stored three digit
number under that mode. Sometimes the first code that "works" with your device may only allow limited functionality (e.g. the MENU button might not work).
There may be a code that performs more functions.
Continue the code search process until the best code is
found.
Press the DOWN button to backtrack through the library
until the device changes channel. Pressing
CHANNEL UP changes direction to forward
again.
6. Press and release ENTER to install the code.
Oct 09, 2015 | GE Universal Remote Control 3 Device Model...
I have a Bellsouth 2-way radio model #2290 and can't get them to communicate with each other. Can you help?
In addition to the Channel, we also call the Frequency, there are sub tones on each channel. You must have the channel and sub tone match in order to "hear" each other. I found a manual:
http://www.scribd.com/doc/3783989/Bellsouth-2231-frs-gmrs-radio-instructions
Jul 03, 2014 | BellSouth Radio Communications
I have a Orion Standard television. I have hooked up an antenna but no channels are being found. Why can't any channels be found?
check the settings in the tv, select 'AIR' in the option. if still no channel receive and it has only a raster like a snow the cause would be a bad tuner board.
Dec 02, 2012 | Orion Televison & Video
Lots of interference , how do I pick another channel on the router ?
In order to change the channel of the router, you will first need to know how to log into the web interface of this router.
To help save you some time, I have found you the manual in a web PDF version.
Here it is: http://static.highspeedbackbone.net/pdf/D-Link-DIR-615-Manual.pdf
Aug 27, 2011 | D-Link DIR-615 Wireless Router
Midland alan 42 multi CB Radio
The user manual can be found in PDF form here: http://www.alan-uk.com/cb/manuals/42%20multi%20manual.pdf
Feb 26, 2010 | Midland Radio Communications
I have re-tuned my TU-CT20 Panasonic set top box several times, successfully in that I have a new list of stations, but every time BBC1 and BBC2 are omitted. It starts with ITV1 at channel 1.
If you have all the cahnnels updated then you will have to manually edit the station list and change the order of the channels. refer to your manual for instructions.
Oct 01, 2009 | Panasonic Televison & Video
Child lock password
Tv made for Australia. Cool
More like the master password found in the owner's manual.
The password is 962326
You can get the manual here:
http://www.sanyo.com.au/support/instruction-manuals/lcd-32xr1-instruction-manual
May 18, 2009 | Sanyo Televison & Video
Programming TV-channels on old Samsung VHS video recorder VB-520T
I tried another position of te range switches and scanned again and again and then I found the tv channels finally.
Mar 25, 2009 | Televison & Video
How do I get BC144XL channels into the scanner
Ok answers to both of you questions. First, in order to get you booklet go to:
http://www.scribd.com/doc/2056189/UBC144XLT
I found your booklet right there in black and white. The programming instructions are on page 11 of the viewer and page 9 in the manual itself.
Here is how to program a channel.
1. hit manual to stop the unit from scanning.
2. Input the Channel # you want to program.
3. Press manual again to go directly to that channel.
4. press the frequency you want on that channel, remember the decimal point.
5. Press "E" to save or "Enter" the frequency.
6. Lastly assure that this channel is not "Locked Out" by seeing that the L/O is not illuminated on the display when you are on this channel.
Hope this helps,
elijam1@ameritech.net
Jan 14, 2009 | Uniden BC248CLT Base Scanner
Samsung T220HD LCD Monitor Logo
214 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
