Question about Dishwashers
The water is not draining out of the bottom during a wash. when the wash is done 2 inches of remain in the bottom. I tried the drain button on the dishwasher and nothing happened.
  • 6,784 Answers
HI. check the following areas for faults.
1. Air gap / Drain hoses
If there is an air gap (located in the sink, near the faucet), check to see if it is clogged. Unscrew the top cap and see if there is anything blocking inside. Note: If there is no air gap installed, the dishwasher might not drain properly.
If the drain hose is clogged, the dishwasher would not drain. If there is an air gap installed, it is very common that a hose going from the air gap into the garbage disposer is clogged. Remove and clean the hose. Make sure to reattach the hose before starting the dishwasher.
Note: If you recently had a garbage disposer installed, it is common to overlook removing the drain plug.
2. Broken belt
Some dishwasher models use a belt to drive the pump. Replace the belt if found broken.
Note: Sometimes the belt would just come off the pump. Even though it might not be broken, it is recommended that you replace the belt, because it is probably too stretched out.
3. Pump
Some models have two impellers inside the pump - one, wash impeller, takes care of the wash cycles, the other, drain impeller, drains the water out. If the drain impeller is broken (broken blades, shaft), the dishwasher would not drain. Replace any broken pump components.
4. Drain solenoid
Some models (for example most GE dishwashers) use a drain solenoid to drain water out. Sometimes the solenoid gets stuck, preventing the water from draining out. Try to free up the solenoid. If unsuccessful, you might have to replace the pump assembly.
5. Motor
If the motor is stuck, it is sometimes possible to free it up by manually spinning the motor.
Replace the motor if defective.
6. Timer/Control
Replace if defective (note: uncommon problem).
Posted on Sep 08, 2009
Why is there water standing in the bottom of my dishwasher after it has completed the wash and dry cycles.......
If water remains in the dishwasher after the cycles end, check the kitchen sink drain to make sure it's not clogged. If there's no clog, try pressing the Cancel button; most dishwashers run the drain pump when the Cancel button is pressed.
Check the dishwasher drain line, drain path and drain pump.
Oct 25, 2017 | Dishwashers
I have a bosh washing machine WFO2462 and my problem is that: washing solution does not completely drain. I have cleaned the pump several times but the problem still remains and every time I want to use...
I believe that it's on the front bottom right side of the machine. Press the tab down and open the little door and you'll see a hose and a circular cover. You need to place a little towel on the floor and a shallow pan. Pull the drain hose out just about 6 inches and pull off the end plug. This will drain the remaining water in the washer. Put the cap back on the hose and tuck it back into place. Unscrew the round cover and pull which will be the filter. Should be clogged and rinse out the filter at the faucet and reinstall. That should do the trick.
Apr 21, 2017 | Washing Machines
Water in the bottom at the end of the cycle
check the drain spigot under the sink to see if there is a blockage.also you can fit a check kit to the drain hose.you can get it from asko
May 31, 2010 | Asko D1706 Built-in Dishwasher
Water is not draining completely from the dishwasher. About 1-2 inches remain in the bottom. Seems to drain most of the water during the wash cycle, but a bit remains. Thoughts on how to fix this?
either the check valve on the end of the drain hose that connects to the drainpump motor is closed shut or sometin is clogged inside the drain hose..... also maybe you pump motor assmbly is faulty... u prob need wet/dryshop vac and drain it out from inside then check that hose... hope this helps... possibly may need to replace that drain hose,,, prob not worth reparing if its a pump motor depending on which brand some had 5 yr part warranties on the pump motor assembly
Jan 30, 2010 | Kenmore PRO 24 in BuiltIn Dishwasher with...
Water will not drain out
It sounds like the drain tube is partly clogged.
If you have a shop-vac you could try that. Try to set dishwasher back on discharge,see if water gose out the second time. if it still dont go out it is clogged. goodluck
Aug 12, 2009 | Whirlpool DU850SWPB
The only button that works is the cancel drain
Sounds like a keypad malfunction or the control board has gone bad.
Feb 13, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
AWM 8121 NOT DRAINING OR SPINNING PROPERLY
that isn't a good model number,open the door,look around the opening where you put the clothes in and next time send the model number off of the machine,if you can't get it to drain and water is in the machine get a shop vac,suck out the water from the tub,then go to the pump,loosen the center of the pump until water starts to come out vac it up until no more water comes out,remove the center catch and see if there's junk in there,if so this is your problem,stick the nozzle of the vac inside and clean out the inside,put it back together and see if it will drain
Sep 29, 2017 | Whirlpool AWM6120 Front Load Washer
Water not fully draining during washing dishes. Stays approx 2 inches.
heres some few other simple checking & steps, that will guide you to the process...
1st
Remove the cover from the air gap at the top of the sink (usually a short chrome domed cylinder that sits at the back of the sink) and, using a wire, clean it. Also check the entire length of the drain hose for kinks and blockages, especially at the drain connection to the disposer or drain line.
2nd
Once the dishwasher is cool, shut off the power to it, and--if your dishwasher is made to allow this-- remove the strainer, located under the bottom spray arm at the base of the cabinet. Unscrew the hubcap, lift the spray arm off, and remove any clips that hold the strainer to get it out. Scrub it clean with a brush, then replace it.
3rd
Determine whether the sink trap or house drain line is clogged
4th
If it still doesn't drain properly, the drain hose may be clogged or the drain valve may need replacement. At this point, it's usually best to call a repair person. You can check the drain hose for obstructions, but this sometimes involves pulling the dishwasher out from under your counter to access the hose, disconnecting the hose at both ends, and flushing it out with a faucet or garden hose.
Let me know..
Thanks
Apr 19, 2008 | Dishwashers
Dishwashers Logo
21 people viewed this question
Top Dishwashers Experts
