Question about Toshiba Satellite A105-S1013 Notebook
No display on laptop
A few months ago, my laptop just stopped working. when i turned it on, whether plugged in or not, i got the hd light for about two seconds, but that seemed to be it.
after taking it apart and checking the connections to the mb, i put it back together with the same results.
thursday last week, i removed the hard drive and re-set it back again. i also removed the battery and re-tried that. flipped the laptop over and powered it up...AND IT WORKED. the next morning i tried to power it up, only to be greeted with the same no display scenario. please help before i toss this thing!
  • 1 more comment
  • derrick1623 Sep 08, 2009
    it stays on until i turn it back off. it does not display when hooked to an external monitor either. i have no video card, just onboard video. if it was the motherboard, wouldn't it have not came back on when i tried on thursday?
    when i took out the hd, i wiped it off with my t-shirt, then re-sat it into its cradle, lining up the sata connector.
    i have built and repaired countless computers in my day, but this is driving me crazy. i know it works because it came on the other day. i will try to do the things you mentioned, and see where to go from there. thanks.
  • derrick1623 Sep 09, 2009
    okay, i'm starting to think it is the motherboard afterall... if i power it up with no ram, i get no beeping error code, the leds ARE normal. this is driving me crazy, i've NEVER had a computer that i couldn't fix within a few days.
    i assume there is no easy fix at this point, unless you have any other suggestions. if it turns out to be the mb for sure, then it's nothing more than a paperweight, because i can get a laptop for the price of a new mb.
    i will try the keystroke thing tonight when i mess with it again.
  • 700 Answers
When it worked it simply say it is good.Try to clean the battery terminal post or its connector with soft eraser.
Then how about cleaning also your memory card. Its edge connector the one with a gold plated that having electrical contact, using a soft eraser gently rub it to clean its contact.
But first be sure to unhook the battery pack and the external power source before doing this.
That could be contact problem.
goodluck
Posted on Sep 08, 2009
    Novelist:
  • 110 Answers
Is it actually turning on and staying on?
You have to isolate whether it is the LCD screen or the actual laptop(motherboard or video card). Try using the VGA connection to plug it into a external monitor.
If it works on an external monitor then you need a new LCD screen. If it fails, then you may need a new motherboard or video card.
Good Luck
  • print-or-die Sep 09, 2009
    Motherboard can cause weird issues. Just caus it worked once when you discharged all the caps, doesn't mean the motherboard is good. It is turning on everytime, but you just don't have video 99% of the time... then it is the onboard video on your motherboard(as long as when you hooked it up to an external monitor you did it properly). Memory issues, would give an error like flashing lights or beeps. If it shows the LED's all normal, then it is powering up properly. Try holding down a keystroke after you turn it on, you should get constant beeps because you are holding a key down and the PC wants you to stop... if you hear beeps then it is ON, just no video.
    which would isolate the problem to video, as long as you properly hooked it up to an external monitor and switched its primary display and it still wont show video, then its the onboard video on your motherboard.
My panasonic plasma TV screen will light up, but no picture shows.
Have you tried replacing the cable? They can cause all sorts of trouble.
Oct 19, 2015 | Panasonic VIERA TC-P50U50 50-Inch 1080p...
My tefal avanti stopped working
something had been gone short due to the power socket.let the socket be ok but sometimes due to heavy voltage this could possibly happen.just check if somme parts is burnt ,turned black or smelling foul oudor,or when you on the machine now it passes burning fumes from some where.
Aug 11, 2008 | Tefal OT806000 Avante Elite 1600 Watts...
Computer not charging
Sounds like you got a bad battery probably need a new one. Click here for tech support
Mar 26, 2013 | HP Pavilion Computers & Internet
Rear window wiper works for a few days or weeks
Check the plug is completely plugged into the motor. Maybe a bad connection in the motor itself. Also check the switch, try wiggling it when turning on.
Mar 06, 2010 | 2003 Oldsmobile Silhouette
Gateway MX6438 will not power on
if your battery is dead and your not able to use the adapter to keep it going, its probably a dead ac adapter. is the light where its connected ? light on the box (if it has one), the outlet you are plugged into have power to it ? try another plug
Dec 29, 2008 | Gateway MT6730 Notebook PC
Power connection, but no Data (Mac)
The first and simple thing to do is to try a different data cable and see if it works. If it doesn't work then may be it has crashed and you can probably recover it using a recover tool like Recoversoft Data data rescue Pc. Th trial version will let you determine whether you can recover or not. If the differnt cable thing wont work then let me know and i will walk you thru the data recovery process using Recoversoft Data data rescue Pc.
Jul 10, 2008 | FireLite (USBFLB80) Hard Drive
Toshiba Satellite A105-S1013 Notebook Logo
66 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
