Question about Whirlpool 24 in. DU951PWB Free-standing Dishwasher
D/W not running
Dishwasher fills and you can hear the timer working. Motor sounds like it is trying to start at beginning of wash cycle than D/W turns off. Can not get it to wash or to drain.
  • 833 Answers
Roger, this sounds like a clogged pump or a bad motor. Not something you're going to be able to do yourself. I have the same general unit and I bless it every day that it works.
Posted on Dec 09, 2007
Kenmore washer 110.16112503 works in wash & spin cycle but not rinse. After wash cycle finished I hear a humming sound and the machine does nothing until I manually start spin cycle. Broken timer?
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
Sep 18, 2016 | Kenmore Washing Machines
Kenmore classic dishwasher washing cyle doesn't start
It sounds as if you need to replace the timer. The reset motor is separate from the primary motor--that is why one type of "cycle"--diagnostic-- seems to work but the regular cycle(s) do not.
Jan 30, 2013 | Dishwashers
I have frigidaire dishwasher,starts cycle,can hear water entering dishwasher,checked level of water,does not get to 1",machine starts washing by the sound of motor, but dishes are not clean,water drains...
Depending on your dishwasher, it fills either by a timer or by a water probe or float. I will assume its a timer as a probe or float wouldnt exhibit this behaviour. I would say you have a restriction in your water supply line. Check your valves, any screen filter in the water line for sand/scale/silicate/etc, pressure regulator if applicable. Another posibility is a poor magnet in your fill valve.
Dec 19, 2009 | Frigidaire Dishwashers
Item: Whirlpool Ultra Dishwasher Age: 3 yrs Problem: Not enough water to effectively wash the dishes. State: When the dishwasher is started, the fill valve opens as normal. Only about 1/2 the amount of...
The float is generally for overflow conditions and will interrupt power to the fill valve solenoid.
If you are not filling completely in the time allowed by the timer, it is most likely a flow restriction in the water supply. Barring other obvious restrictions, the fill valve has filter screens on the inlet side of the fill valve, which is generally the cause of your symptoms. Be careful if you attempt to clean the screens, as the fill valves are very sensitive to debris, and can become stuck open if sediment gets past the screen. I usually replace the fill valve to avoid future problems.
Hope this helps.
Oct 30, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwasher not working. lights come on but dishwasher will not start. when you hit cancel/stop, 2 minutes appear and there is a huming sound and it counts down and goes off. When u turn on the wash cycle,...
the dw is probably full of water because the motor didnt pump it out
because the impellor on the motor has stripped thread and not drainning the water when u hit cancel /stop the timer is asking the d/w to drain and end the cycle. If u wait 2 mints after u start the machine do u then here a hum from the motor trying to wash
if the d/w dosnt have water in it and you turn it on it should fill or there is a problem with the inlet water valve or timer or no power to the water valve a appliance tech should determine this probably more than normall person should attempt
( solv ya prob)
Oct 18, 2009 | Kenmore Dishwashers
I have a maytag washer (model -dependable care) and when we start the wash the motor just hums, the water does not fill, if we move the timer switch to rinse the motor engages and the unit works entire the...
Check your fill tubes remove the hoses and see if the filters are plugged, you are not hearing the motor humming. You are hearing the watervalve humming, the motor will not start until the tube is full of water.
Jul 16, 2009 | Maytag MDB6650A Built-in Dishwasher
Dishwasher just started not filling enough water to wash dishes.
It does sound like a circuit board problem but lets not rush out and pay an exorbitant service fee yet...I checked the user manual and this model does have a timer often timer go out and many people think the problem lies elsewhere...but when a timer goes out or a couple of teeth no longer engage then you could have any number of problems...I doubt the solenoid is bad or it would not initiate at all to begin with,,,,,so here is a little test......turn the DW on and cycle the timer to where it starts the water the timer to see that it turns and disengages. the solenoid...How quick was it? (if under your accustomed 2 mins... problem with timer). Another test is to do the same and hold the timer tightly preventing it from turning and see if you can force the fill valve to stay open longer (if so...bad timer).
I hope this helps...please rate me....The Fang
Mar 12, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Whirlpool 24 in. DU951PWB Free-standing Dishwasher Logo
78 people viewed this question
Top Whirlpool Dishwashers Experts
Oloyede Monsuru
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
