Question about Garden
I need an assembly manual for the gearbox of a 8443D, does one exist? Regards Jim.
  • jimcorcoran9 Sep 08, 2009
    Hi, no good I need a diagram of the internal gearbox assembly, how it is assembled.
    Regards Jim.
    Top Expert:
  • Garden Master
  • 76,846 Answers
Make and model please
Posted on Sep 08, 2009
  • 601 Answers
Check this link . This will help you.
http://www.makita.de/uploads/media/Makita_8413D_8433D_8443D.pdf
Thanks
Smith.
My 307 cc wont go into 3rd gear all the time
Hi Andrew you have a gear selector fault inside the gearbox your options are to replace the box with a secondhand box. Otherwise find a reputable shop that can rebuild your own. Regards Jim...
Apr 17, 2016 | Peugeot 307 Cars & Trucks
Pronto M51. Why is it leaking oil?
hi James ,this is a power-chair right ? if so then the oil must be coming from one of the gearboxes, if possible run your finger inside the wheel where the axle goes into the gearbox ?
Regards
Rob
Feb 02, 2016 | Invacare Health & Beauty
Trying to locate the reverse switch & any help would be appreciated
Hi you will find the switch usually on top of the gearbox/transmission near where the gear select linkage is located. Regards Jim...
Apr 04, 2015 | 2000 Kia Sportage
Liteway 4 scooter
hi John, i can't remember what the coupler looked like, so lets recap, your mechanic has fitted to a new gearbox to the existing motor right using the existing coupler ??? , grease or no grease do they connect okay ???
Regards
Rob
www.facebook.com/gewizrepairs
May 26, 2014 | Health & Beauty
What is the best way to disconnect the oil line to the radiator on a 2002 GMC Savana cargo van?
Hi Jim, You can join the two pipes with the correct sized pipe. My question is why would you want to? The oil in your gearbox needs to be cooled or warmed, depending on ambient temperature. If it is not you may end up with major gearbox problems. Regards and happy new year John
Dec 31, 2012 | Cars & Trucks
Oil leak from driveshaft n/s
not sure if you can interchange the manual & aut shafts, but you should check to see if there is excessive play where the shaft enters the gear box if so the diff bearings my be worn, if there is no play or noises from gear box when driving, remove the shaft again an try the seal on the shaft to check it's a proper fit, before fitting seals it is a good idea to leave them soaking in oil for a few hours prior to fitting
hope this helps
Regards
Jim
May 29, 2010 | Hyundai Motor S Cars & Trucks
Badger plus auger runs, but the auger doesn't spin
Here's a online free manual you can download and print for a Tanaka post hole digger, as your title stated that's what you have.
http://www.tanaka-usa.com/pdf/manuals/TIA-340-350S.pdf
However, I noticed that you wrote you have a Badger Plus auger, so I tried to find info on that, but a manual doesn's exist outside the manufacturer, you can call them to see if they'll mail you one.
I's suggest you look at the gearbox, as it sounds as if you've sheared a key inside the gearbox on the main drive shaft, based on your description. The gear box is straightforward with a simple 12:1 gear reduction ratio and uses only two (2) gear wheels and shafts.
I couldn't attach the picture but here's a link that will show the gear box, just scroll down once it loads. It should be easy to open and repair the gearbox, as there isn't much to it. Drain the gear oil and separate the halves and you can check for a sheared key on either of the gear wheels and replace the broken one. They're designed to shear to prevent damaging the more expensive gear wheels, etc.
http://www.gemplers.com/docs/IS/RFM100.pdf
Hope you find this Very Helpful and best regards!
Aug 22, 2009 | Tanaka TIA-350s Post Hole Digger -...
Type of oil to use on an xtype manual gear box
hi, you should only use the correct oil for this type of gearbox, available from the jaguar dealer, for the price of posibly damaging the gearbox with the wrong oil you may as well pay a little more from the dealer. regards mark.
Feb 11, 2009 | 2003 Jaguar X-Type
Oil Change queries SUBARU IMPREZA RS 2.5 2005 MODEL non turbo
I am confused - I have a simple query and logged on to your site as you offered free advice! Do you not offer the service as described on your website. I definitely don't need a team of experts to answer my very simple question.
Regards
Vic Fenn
Jan 25, 2009 | 2005 Subaru Impreza
How do i remove a gearbox from a 2004 mini
I don't believe you are able to remove just the transmission , you may have to remove both as an assembly.
Dec 18, 2008 | 2004 Mini Cooper
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
