Question about Generac 100 Amp 120/240-Volt Transfer Switch #RTSN100A3
10kw Generac Guardian not cranking, shows rpm sense loss
After installation, followed installation guide's instructions for manual test. Utility power off. Breakers on Generac panel off. Generator's breaker off. Generator's mode switch set to off. Manually operated transfer switch to down position. Switched generator's mode switch to Manual start ... readout ''cranking, attempt 1'' for a few seconds ... but no cranking whatsoever, whole unit is silent ... then ''RPM Sense Loss'' message.
Verified natural gas pressure is present. Battery's brand new and shows full charge. 12 volts present at lug under red cap by starter. Fuse is good.
  • bobsykora Sep 08, 2009
    The Mode switch has three settings: MANUAL, OFF, and AUTO. The step-by-step installation guide tells me to put it at OFF till utility power is disconnected and manual transfer has been thrown, then switch to MANUAL.
    BTW, when I put the Mode switch to AUTO and disconnect utility power, the readout tells me it's going through a utility disconnect delay, then says it's cranking (it isn't), then gives the same RPM SENSE LOSS error message that results when I go through the manual test.
    Sergeant:
  • 384 Answers
Sounds like Generator mode switch should be "ON".
Posted on Sep 08, 2009
WHAT DOES SENSE LOSS MEAN
RPM Sense loss means that the generator controller hasn't received a valid signal from the ignition coils for 3 seconds of attempting to start. Probably a dead or low battery or bad ignition coil. Replace the battery and try again. Call dealer if problem persist.
Aug 20, 2015 | Generac Power Systems Centurion by 16000...
We have a generac 10kw pad mounted generator and the battery has blew up two times now, what would cause this to happen? The entrie battery blows up into pieces. The generator has proper...
The battery is overcharging either by the external charger or by the engine alternator. This is causing the battery to "boil" realeasing hrdrogen gas. One spark or high current demand from cranking can cause this. Have it checked by a pro
Aug 10, 2013 | Generac Guardian Guardian 28" Battery...
I have a 10 KW Generac Guardian Stand By withe a prwired EZ transfer swithc. Everything works except the 12 volts battery charger. What could be the problem. Only have three weeks innstalled.
Your generator is equipped with a battery trickle
charger that is active when your unit is set up for
automatic operation. The trickle charger is
designed to help extend the life of your battery by
maintaining the battery when the unit is
not running.
you will need to review which circuit bord controls this and have that board replaced or serviced some of these gen heads have this built in and it will be the rectifier in the gen it self it will be a black 1x1x3/8 inch with a mounting hole in the center and 4 lug post for the wires replace this and your issue should be solved but consult your dealer for witch unit you have as to a control board external or the built in rectifier hope this helps.
Aug 11, 2010 | Generac Guardian Series 5502 10 kW...
Generac 4456 does not start on power loss
I install and work on these everyday. If you hooked up the transfer switch you probable have a control wire wrong. check the utility power sense wire. That lets it no when to start in auto. it could be a relay or fuses. or a control board.
Jul 01, 2009 | Generac Guardian 200 Amp Transfer Switch...
Guardian generac 10kw model 5502 does not output correct voltage
the instructions says the voltage regulator is automatic/digital. when you check the voltage is there any load on the generator? if applying load to the generator doesn't help, you can manually change the motor speed where the governor connects to the carborator, but it may change the frequency, but the regulator may fix it
Apr 12, 2009 | Guardian Electrical Supplies
10kw Generac shut down overspeed
Make sure that the throttle linkage is all there and not damaged/misadjusted, then get a manometer and check your inlet gas pressure. Gas pressure should be 8 inches of water column and stay there running or not.
Carl
Apr 06, 2009 | Guardian Electrical Supplies
Generac 100 Amp 120/240-Volt Transfer Switch #RTSN100A3 Logo
3,638 people viewed this question
Top Generac Electrical Supplies Experts
Craig Butler
Craig Butler
dennys23601
Don  Farrell
Don Farrell
Are you a Generac Electrical Supply Expert? Answer questions, earn points and help others
