Question about Toshiba Satellite A105 Notebook
Toshiba a105, wont power up, clicking sound
I bought an used toshiba a105 without the ac charger power supply and no battery. i try to use 12v direct,(done this with other laptop for years,no problem) laptop tried to lite up a couple of time but after that is dead, not ligths, then i bought the generic power supply but now only hear a faint click sound, still dead, no lds. I bougth a processor, same result. Bought a diferent motherboard, same result.
I seem to have the same problem. I have an a105-4134. Ive had since June of 2006 and ive kept it clean and have replaced several components throughout its life.
I was working on it few days ago until it just shut off. Confused, I press the power button thinking maybe the power adapter wasn't plugged all the way in and the battery depleted and it shut off. So now the computer will now power on. It lights up but shuts off within 1 second. Keeps doing this over and over.
My first thought was the dc jack as ive read it is common to be faulty after long use. I ordered a new one and unfortunately it was not the culprit. I then suspected the cheap aftermarket power adapter which replaced the dead oem power adapter. Bought a new one and experienced the exact same symptoms yet again.
Now I'm digging deep removing all components one by one. With each one I remove, I gain a few seconds of time that it will stay on before shutting off on its own. I powered it on with only the motherboard and cpu and it does the same thing.
From the original problem in this post, the cpu and motherboard were swapped out and same symptoms still occurred. This being the case, the only component left undiagnosed is the power board itself.
This is where I noticed that the computer will power up and run on battery power. The adapter plugged in will charge the battery but not power the computer while running. With this discovery it means that it cannot be any of the main components causing the problem.
Back to the power board, an obvious problem area seeing how this is tied in with power components. From the looks of it, it seems like a simple switch board but i may be wrong. My next step is to order a new power board. I will let you all know how it turns out.
Posted on Apr 13, 2010
  • cplum Feb 06, 2011
    what happened? i'm having the same problem. Did you replace the power board and if so, did it work? where did you get one and how much was it?
This just happened to me yesterday. First my touch pad was not responsive. Then I started to hear this clicking sound. I turned off the laptop (big mistake) and tried to boot it up, I received boot failures like mad. I opened up the DVD drive, the cover fell off and the piece slid right out. I know shopping can be strenuous but c'mon man. So I cannot get it to boot up at all, terrible clicking sound so I'm going in.
Posted on Nov 25, 2011
    Novelist:
  • 110 Answers
Try taking the Hard drive out... will it boot up? If it does, get a new Hard drive.
Try taking out the memory... does it give you a 'beeping' sound? If it does, then try reseating or replacing memory. If you have two sticks, try one at a time.
Take out as much stuff as you can, like the wireless card, Hard drive, memory, everything but the motherboard, processor and LCD.
Maybe you bought a bad or non-compatible A/C adapter....
Posted on Sep 08, 2009
I need a replacement Power pack 12V-3A 36W. Can you please tell me where I could get one from?
Cherryl, You could try local stores that sell computers and electronics, Walmart, the source, staples etc. Check the attached links,for power pack/charger, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Premium 4 8 1 7mm Replacement Power Supply Cord Laptop Battery Charger...
Genuine Asus LCD Monitor 12V 3A 36W Ac Adapter Charger ADP 36EH
Laptop AC Adapter 12V 3A 36W 1 7 4 8mm
Amazon ca power supply 12v 3a
Apr 28, 2016 | Computers & Internet
My friends Toshiba Satellite A105-S2719 dropped to the floor while it was connected to the changer. In noticed the charger was damaged so i used mine it will not turn on Motherboard maybe. i replaced...
When using other charger for a laptop, you should mention CAREFULLY the volt and ampere for the new charger.
But first, if you have other laptop similar, you can use it's battery to test the dropped one.
Please tell us your results
Good Luck
May 13, 2011 | Toshiba Satellite A105-S2719 PC Notebook
Hi there.I ve got this strange problem with my satelite Toshiba A200 1AB laptop.the problem is with the battery actually it wont charge when I plug in the charger with battery in it.But when I extract the...
Is the AC Power adapter the original adapter of the laptop? If it is, try to drain the battery and charge it for 8-12 hours without using or opening the laptop just charge it. After charging, remove the power adapter as you open your laptop. Make this way a habbit of using and charging your laptop to make the charging and battery life last long.
Mar 11, 2011 | Amstron Toshiba Satellite A200-1AB Laptop...
Cannot find the charger for my vectorlite 1.5
Hi sast.
I found this on amazon: HQRP AC Adapter Charger for Black Decker VEC119SH TYPE 1 VEC120 TYPE 1... It says that fits, but anyway contact the seller and ask.
Hope this was helpful.
enjoy
Feb 28, 2011 | Vector 1 Million Rechargeable Spotlight
Unit failed to boot and observe the followng; - No start-up display - No CMOS boot-up display - Hard disk clicking sound and OS won't start
Turn the computer off.
Disconnect the AC power supply.
Remove the battery.
Remove the disk-drive.
Reconnect the AC power supply.
Turn the computer on.
Put any "data" disk into the CD-drive.
Does it display the CMOS boot-up display?
Can you hear the PC try to spin that "data" CD, i.e., trying to "boot" from it?
If it works "better" without the disk-drive attached, the disk-drive is the problem.
Jan 11, 2011 | Toshiba Satellite A105 Notebook
Battery will not charge, replaced battery and still will not charge, computer shuts down when ac is unplugged.
ok.. today some store sell a external battery charger. or external power supplie.. You need to check your power settings in control panel.. there are some option to power up the laptop. In ebay you found the external device a tell you in case you can`t fixed
Dec 25, 2009 | Toshiba Satellite A105 Notebook
A105-S4254 is dead!
According of your description, If you already changed the power suply, and the battery, and still no signs to power on, your laptop has some issue at power connector in the motherboard and need to be serviced.
Jan 23, 2009 | Toshiba Satellite A105-S4254 Notebook
Toshiba satellite p105-s6217 will not power up or charge.
Larry,
  1. Unplug the laptop and remove the battery.
  2. Press the power button down and hold for 10 to 15 seconds.
  3. Press the power button 5 more times quickly.
  4. Plug the power back into the laptop without the battery and press the power button.
If the laptop powers on just put the battery back in.
Dec 16, 2008 | Toshiba Satellite A105 Notebook
Problem with laptop- no power
The battery needs to be taken out once in a while. It is possible to use the ac adapter and power cord without the battery to power your laptop. Please press on the power button for 10 seconds for your computer to turn on. Check if you can see any message on the screen.
Sep 04, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105 Notebook Logo
990 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
