Question about Indesit Washing Machines
MY indesit IWME12 won 't spin or pump out and there are lights flashing - the one with the picture of drops of water going into a bucket and the one with a T shirt symbol. Have tried switching ooff and on and restarting but no luck
    President:
  • 1,865 Answers
Unplug the machine for a few minutes to reset the controller, then replug
Posted on Sep 08, 2009
Indesit Iwme12 fills with water then nothing else, i took it apart then got it spinning but same has happened again??
Is the belt badly worn? When you "got it spinning", did you have to help the motor to start? If so... that motor is probably at the end of its life. If not, what did you do to get it spinning?
Aug 08, 2014 | Washing Machines
Lights keep flashing
I would check the water pump for a blockage, there could be something in the pump preventing it from doing its job as the machine cant go to the next cycle until the water has been expelled before the machine can continue eric
Jan 16, 2018 | Indesit Washing Machines
Indesit model widl106 won't spin after the first wash. Lights flash.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Jan 23, 2013 | Washing Machines
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
How to rid of mould on and underneath rubber seal by door as making washing smell musty,model is INDESIT IWME12, thanks
when coming across this problemn i just tell my customers to put the machine on its hottest wash with a capful of bleach instead of powder this works ok good luck.
Jun 07, 2011 | Indesit Washing Machines
Washing machine is not draining and lights keep
It is likely that the pump/filter has blocked thus preventing the water pumping out.
You would need to check and if so unblock it. The location of the pump/filter varies with the brand but sometimes it is behind a flap at the lower front of the machine whilst on others you have to get the back off to locate it.
Jan 23, 2010 | Indesit Washing Machines
How do i remove the soap drawer from an intergrated indesit iwme12 1200 spin 5.5kg washing machine please?
Hi, I had the same problem, Open the drawer fully by pushing the right hand side in to release.
With the tray fully open, hold the white front bit steady and pull drawer bit, hard towards you. Quite a lot of force is needed.
Its held in by a plastic clip that clips onto the hinge part of the front cover. Hope this helps took me 3 months to take the courage to pull hard enough.
Oct 11, 2009 | Indesit WA 115 Front Load Washer
Power light is on but nothing happens - indesit iwme12
If the door does not lock at this point it probably needs door lock replacing
Sep 05, 2009 | Washing Machines
Indest wil103 has 3 flashing lights the power one and to green ones stain remover and extra rinse and want spin what is wrong please help
If the machin isnt able to evac the water, it wont spin. It will indicate error with 2 flashing lights + lock led. Check pump, drain hose.
Jul 26, 2009 | Indesit W 123 Front Load Washer
Indesit washing machine not spinning - fault code timer and dor lock light flashing
my indesit washer/dryer wd12x programme dial goes all the way when it reaches spinning
May 30, 2009 | Indesit W 123 Front Load Washer
Washing Machines Logo
624 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
