Question about Sprint BlackBerry 8703e Phone
My blackberry is on but I cannot make any calls or receive any calls. It says that the "radio" is turned off. What does that mean?
    Problem Solver:
  • 13 Answers
On the home screen (the one with all the icons - messages, address book, and so on) scroll until you find an icon that says Turn Wireless On. click on this icon to turn the wireless on. if your battery isn't charged enough, it may not allow you to turn the radio on, which means you would need to charge it to allow the wireless radio function to work.
Posted on Jan 15, 2010
Blackberry 8520 displaying "radio path
hi emily_ashdow go to blackberry dot.com and download the desk top manager on to your computer. The blackberry desktop manager can fix your problem. it will allow you to turn your radio connections
Jun 05, 2011 | RIM BlackBerry Curve 8520 Smartphone
I want to connect my nokia BH-104 headset tp my blackberry bold 9700 phone. Please guide
  • 1
    Turn on Bluetooth headset and Blackberry hand-held.2
  • Enable the Bluetooth radio by going to the options window and clicking on Bluetooth. Click on Enable Bluetooth in that window.3)Add your Bluetooth headset to your Blackberry by clicking on Add Device in the Bluetooth window.4)Find and select the name of your Bluetooth headset from the list that appears. The Blackberry will search for all Bluetooth devices within range, so other devices might show up on the list.5)Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically
  • Mar 20, 2011 | Nokia BH-104 Bluetooth Headset
    I cant receive any calls on my blackberry curve, the callers are asked to check the number n then dial again, pls HELP!! There is a sign on my screen showing the receiver with an arrow pointing outwards
    the receiver with an arrow means that you do not have any signal, which either mean that you are in an area with no/weak signal (go to somewhere else) or your phone have been disconnected (talk to your phone company)
    Feb 28, 2011 | RIM BlackBerry? Curve 8330 Cellular Phone
    Cannot 'pair' the HPBLU H1 to my Blackberry..? Not 'finding' it... need a users Guide... where can I get one...?
    Instructions
    Pair Your Blackberry with a Bluetooth Headset
    Click Activate Bluetooth device if you receive a call and the Bluetooth headset does not pick up automatically.
    Use your Bluetooth Headset with your Blackberry
    Make sure the Bluetooth radio on your Blackberry is turned on before you try to use your Bluetooth headset.
    Use the voice-dial feature to call contacts if your headset has that capability. Not all headsets support voice dialing, but more of the newer models do.
    Press the on/off button on your headset to end a call or use the end button on the handheld.
    Tips & Warnings
    Pair your Blackberry with any Bluetooth-enabled device using the same steps as those for connecting a Bluetooth headset.
    Remove your Bluetooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
    Configure your Blackberry to connect to a paired Bluetooth headset without asking for authorization in the Bluetooth Device Properties window. That will allow your headset to automatically reconnect even if you take it out of range temporarily.
    Only configure a Bluetooth headset to your Blackberry once. Once you configure the pairing between the two devices, the settings are saved and you do not have to repeat the processes each time you use it.
    Turn off the Bluetooth radio on your Blackberry when not in use for security reasons.
    Adjust volume on your headset or hand-held to a comfortable level. Excess volume from in-the-ear headsets can cause hearing damage.
    Feb 23, 2011 | Cellular Innovations HFBLUH1 Bluetooth...
    I AM NOT ABLE TO PAIR JABRA BT135 WITH MY BLACKBERRY 9700. WHAT SHALL I DO?
    Hi,Instructions on how to pair blue tooth device with black berry.
    Tips & Warnings
    Have a nice day .
    Feb 16, 2011 | Jabra BT125 Headset
    Can i use my plantronics 230 bluetooth for my blackberry phone?
    Hi, yes you can use plantronics 230 blue tooth for your blackberry phone.All you would need to do is to pair the device with your phone.that will do.
    How to pair a phone to a blue tooth device?
    Instructions
    Pair Your Blackberry with a Blue-tooth Headset
    Turn on Blue-tooth headset and Blackberry hand-held.
    Enable the Blue-tooth radio by going to the options window and clicking on Blue-tooth. Click on Enable Blue-tooth in that window.
    Add your Blue-tooth headset to your Blackberry by clicking on Add Device in the Blue-tooth window.
    Find and select the name of your Blue-tooth headset from the list that appears. The Blackberry will search for all Blue-tooth devices within range, so other devices might show up on the list.
    Click Activate Blue-tooth device if you receive a call and the Blue-tooth headset does not pick up automatically.
    Use your Blue-tooth Headset with your Blackberry
    Make sure the Blue-tooth radio on your Blackberry is turned on before you try to use your Blue-tooth headset.
    Press the on/off button on your headset to end a call or use the end button on the hand held.
    Tips & Warnings
    Pair your Blackberry with any Blue-tooth-enabled device using the same steps as those for connecting a Blue-tooth headset.
    Remove your Blue-tooth headset from the list of paired devices on your Blackberry by selecting and clicking on Delete Device in the Bluetooth window.
    Jan 06, 2011 | Plantronics Explorer 230 Bluetooth Headset
    Cannot receive calls on my Verizon Blackberry pearl
    Hello parks willia If your having trouble with the pearl look athe radio connection on the phone. Make sure it isn't off.
    If you see it in the off postion you need to go the radio connections on your blackberry and turn it on. If that doesn't work the quickest fix is to put the battery and put it back in the phone. Now then other thing you should do once it boots up is the *228 option 1 and let the phone reprogram.
    Nov 26, 2010 | Verizon Communications BlackBerry Pearl...
    I need help turning on the radio on my blackberry 8350i nextel phone. Just need step by step instructions on how to activate f.m radio
    The 8350i does not come with an fm radio. Whe it says radio it is meaning the cellular radio in the phone.
    Nov 25, 2010 | Blackberry Curve 8350i
    I can't make calls from my Blackberry 7290
    Check on the right hand corner of your device for the vertical signal bars - 5 bars indicate full strength and 1 indicate very low signal. "OFF" indicates the radio is off and need to be turned on.
    In case signal strength is good, you should be able to make and receive calls. In case it does not work, just try taking the battery out and put it back after 15 seconds and try again.
    In case signal strength is low , either you are in a low signal zone or your SIM card is bad. Take the SIM card out, wipe the gold plated surface using a clean tissue, put it back and try again.
    In case the radio is OFF, turn it on by clicking on the icon (Turn Wireless on) on the home page.
    Dec 27, 2008 | RIM BlackBerry 7290
    Sprint BlackBerry 8703e Phone Logo
    105 people viewed this question
    Top Sprint Computers & Internet Experts
    Computer Repairing
    Computer Repairing
    matt
    matt
    Are you a Sprint Computer and Internet Expert? Answer questions, earn points and help others
