Question about HTC G1 Smartphone
Phone light does not light up - HTC G1 Smartphone
Screen stopped working today. phone rings but I can't see anything on the screen Can I fix it?
Cell phones are VERY hard to service. The problem with your phone is most likely related to the back light. Time for a new phone.
Feb 12, 2016 | Cell Phones
What happen when a adsl line work with a phone but not with a router
The phone line does two jobs. Voice phone which is what it was originally used for and ADSL modem which works at a high audio frequency.
Somewhere between the phone socket and the modem should be a filter splitter. One part goes to the phone and the other to the router. Make sure you have that.
The modem will have a power light and several additional lights. Assuming the power light is on we are interested in two of them; The ADSL light and the Internet light. When you switch the modem on you should first see the power light flash then go solid. Then the ADSL light will flash and then this should go solid. If this light does not come on then you have not plugged the phone wire in properly. If this light just keeps flashing slowly then the modem can't see an ADSL signal on the phone line. If you have a spare router you could try it and see if the ADSL light goes solid on that.
If the ADSL light is fine then the modem has locked onto the signal on the phone line, sync'ed. If not then this is the problem you must solve. Ask your ISP if service is set on your line.
The next light is the Internet light, this maybe a symbol like an i or a world. This light will begin flashing then go solid. It will flash with Internet traffic. This means you have Internet, as far as the modem is concerned. If this light does not stay on then your ADSL account name and password maybe wrong. You can correct this but that's a different question you need to ask.
Feb 18, 2015 | D-Link Dsl-2750b Adsl2 Verizon N Wireless...
My phone's keypad just lights up for few second the moment i turn it on then turns off again without a light on the screen .can you help me fix this problem?my phone is a razr v3 model.
Hi,when a Razor v3 has a light issues isuaully caused by the flex of the phone.
The flex of the phone is located inside the phone, it controls the functions of the screen an also the keypads of the phone and the light.
The flex is a thread like object that is located inside the phone. To see the flex, you will need to disassemble the phone to get to the flex of the phone.
After replacing the phone flex, your done.
You can get a replacement flex from any of the phone repair stores around you.
Hope it helps.
Thanks for using fixya...
Aug 17, 2011 | Motorola Mobility RAZR V3
HOW TO REPAIR
I think the light bulb of your phone keypad is dead.
Loose the phone and clean the phone board with methylated spirit, allow it dry and test if the light would come up.
You could also use a tiny wire to connect light from the screen to the keypad. But this could be done, if you are a phone expert.
Maybe you should just give the phone to an expert of fix the fault for you.
Take care.
Dec 28, 2009 | Nokia 6030 Cellular Phone
Just bought a Philips Digital Phone Model No.CD135. Is THERE NO BACK LIGHT on this phone as it is difficult to read screen even in daylight. I would not have purchased it otherwise. If not do you have a...
Hi
I contacted Philips by phone and the told me that there is no back light on Model No CD135. I think that is stupid as you can have a back light on the cheapest mobile phone. All handset phones should have a light so it can be used in bad light.
Frank
Sep 26, 2008 | Lands Phones
My phone will not show it charging and will not turn on, red light flashing
i cant charge my phone using a charger
when i put the head phones in the same port, my phone does not pick up the signal
BUT when i connect my phone to the pc using a usb cable, it charges fine and i can transfer data
WHAT IS WRONG WITH MY PHONE????
Apr 19, 2008 | Cell Phones
Lights on the numbers are not lighting up
Hi,Most phones will have that option in the display settings. You can mess with the lighting and timers on the main lcd, the front lcd (or led), and the keypad.If that doesn't work, there's most likely something wrong with the phone. Take it in to a corporate store to get it replaced with a working model.
Gizmo1
Oct 14, 2007 | LG KG800 Cellular Phone
Phone charging indicator light
register phone instuction
May 22, 2007 | GE 25861GE3 Phone
Service Light Will Not Turn Off!!
have the phone check by a mobile tech or type *2767*3855#
Mar 10, 2007 | Samsung SGH-e315
HTC G1 Smartphone Logo
648 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
