Question about Dryers
No heat in electric clothes dryer
Have a GE electric dryer... DBVH512EFOWW that will not heat. (will run but no heat.) have flipped the circuit breaker to make sure it wasn't tripped. I have also verified that it has good airflow.
I have a mulitester (never used before) but not sure where/what I need to test.
Anyone out there that can help PLEASE.
  • 1 more comment
  • gabbarda Sep 08, 2009
    ok... need help. I unplugged the dryer:)
    trying to open unit. In the back there are 2 screws and a rectangular panel up top (only about 3 in high) or there are screws in the front bottom of the machine.
    Removed the front screws and the entire front panel/door seems to want to come off... but held on at the top by the control panel. There are screws running along the sides on the back but they seem to be holding the side panels on... so, how do you open it up??
    after fiddling I was able to remove the top of the dryer cabinet which exposed the power board but this isn't what I am looking for is it? Don't I need to find the heating coils that would be in the base of the unit? If so how? Thanks so much!
  • Edward Jennejohn May 11, 2010
    UNPLUG THE DRYER!! before you do anything!! if it's 220v it can really fry you! if you're lucky! you'll probably need to remove the back panel. you'll probably see something that wiggly looking wound with flat nichrome wire. it may have insulated screw on wires on each end, or push on connectors. either way, remove the wires, set your multi-meter on OHMS. put one probe on each end of the heating element (where you removed the electrical connections). if the reader remains on 0, then the element is burned out and needs replacing.then think about how old your dryer is, get some estimates for fixing it. after you awaken from your faint- consider buying a new one! electrics are cheaper than gas dryers. good luck! don't forget-UNPLUG THE DRYER!!
  • 532 Answers
Sounds like the typical heating element problem,which is located behind the drum.
Posted on Sep 11, 2009
My general electric dryer DDE5300 is no longer warm so clothes don't dry, though it runs. How can I tell if its the heating element or the thermostat?
You Will have to use an ohm meter and the tub has to be taken out. You can on a GE open the door and push in on the door switch and starte it with the door open and look straight in and see the heater come on but if either the heat element of thermostat is out the element wont come on. If you live in ahouse with fuses instead of circuit breakes or a fuse box between the dryer and main circut box check the fuses an electric dryer will run on one fuse but not heat if this is the case switch the fuses and see if it runs if not one fuse is bad.
Apr 21, 2010 | Hotpoint NVL333EY Electric Dryer
Dryer stops running and displays E1
WHAT IS WRONG WITH YOUR DRYER?
small_8_20.jpg For a detailed Dryer illustration, click below.
redarrow.gif Gas Whirlpool Style Version 1
redarrow.gif Gas Whirlpool Style Version 2
redarrow.gif Gas Maytag Style
redarrow.gif Gas GE Style
redarrow.gif Electric Whirlpool Style Version 1
redarrow.gif Electric Whirlpool Style Version 2
redarrow.gif Electric Maytag Style
redarrow.gif Electric GE Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Electric dryers aren't very complicated. Here are some common symptoms that you may experience with your dryer:
There's an error code on the digital display
It doesn't work at all
There's no heat
It won't tumble
Drying is too slow
It overheats
It seems to run forever
It's noisy
It won't start
The light doesn't work
It blows fuses or trips the circuit breaker
My clothes smell bad!
My clothes are marked or torn
Aug 11, 2008 | Whirlpool GEW9200L Electric Dryer
GE Front loader doesn't dry clothes completely.
Hello there:
f yourdryer won't heat up, it's possible that it is not being supplied withthe proper voltage. Here are three ways to make sure power is gettingto your dryer: First, make sure your dryer is plugged in. Next, checkthe circuit breaker panel to make sure all the circuit breakers are inthe correct positions. Finally, check to make sure no fuses in yourfuse panel are blown. Any of these could explain why power is notgetting to your dryer.
dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heatingelement is defective. Heating elements are irrepairable. If yours hasceased to function properly, you will have to replace it. Open yourdryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributedto a faulty thermal fuse. Once a dryer's thermal fuse has blown, it isno longer of any use. If your dryer's fuse is blown, you will have toreplace it. Open up your dryer's cabinet and locate its thermal fuse sothat you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could bethe reason that your dryer is not heating. Open up your dryer's cabinetand test each of your dryer's thermostats. If any are faulty, replacethem.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up.Test your dryer's timer motor. If it is no longer functioning as itshould, replace either the entire motor assembly, or just its motor.
Jan 23, 2010 | GE DCVH515EF Electric Dryer
My dyer is not heating all of the time no matter what setting I use. I had 2 rollers replaced because they appeared to be rubbinbg and making a noise. The dryer is still not heating and drying the clothes
try flipping you breaker off and on 2 or 3 times (hard and fast) if this don't work check element, timer , thermostats and safety switch on motor (check wiring diagram for pin numbers of safety switch)....if this switch goes bad the motor will still run but it wont let power go to element
Aug 07, 2009 | GE Profile Harmony DPGT750EC Electric...
My GE Driver will not heat
Check the circuit breaker or fuse box it takes two one to run one to heat. Then check thermostats Hi limit may be burnt if it overheated If the venting had been blocked. Hope that helps
Dec 26, 2008 | GE DBSR453EBWW Electric Dryer
I get e01 on ge dyrer panel
There's no heat
It won't tumble
Drying is too slow
It overheats
It's noisy
It won't start
DON'T FORGET TO RATE;
Aug 22, 2008 | GE DCVH515EF Electric Dryer
The drum doesn't rotate and a strange buzzing noise occurs
There's no heat
It won't tumble
Drying is too slow
It overheats
It's noisy
It won't start
Aug 22, 2008 | Zanussi Dryers
Heat and clean vent, but way too long to dry
There's no heat
It won't tumble
Drying is too slow
It overheats
It's noisy
It won't start
DON'T FORGET TO RATE';
Aug 22, 2008 | Whirlpool LGR7646E Dryer
Dryer dbsr453eb3ww
sounds like electric heating element issue to me. Your gas dryer doesn't have electric heating elements which might explain your problem
Jun 26, 2008 | GE DBXR463EBWW Electric Dryer
Dryer no heat but runs
small_8_19.jpg For a detailed Dryer illustration, click below.
Gas dryers aren't very complicated. Here are some common symptoms you may experience with your dryer.
There's no heat
It won't tumble
Drying is too slow
It overheats
It's noisy
It won't start
DON'T FORGET TO RATE:
May 15, 2008 | Whirlpool LGR7646E Dryer
Dryers Logo
296 people viewed this question
Top Dryers Experts
