Question about Sharp Twin Energy EC-T5980 Bagged Upright Vacuum
No suction on the EC-T5980
I have the EC-T5980. It has very good suction from the hose but the rug cleaner works horribly. The roller spins so that is not it either.
    President:
  • 1,673 Answers
Check the inlet by the brush roll, it may be clogged.
Posted on Jan 29, 2008
My Eurika 4D bagless upright will not pick up anything. The belt is not broke but the roller won't spin and there is verry little to no suction. Still makes all the notice but won't roll as easily
You say the belt is not broken and the roller does not spin. Does the motor that spins the belt turn. If the belt does not spin and the little drive motor spins then you will burn the belt out. Try to turn the roller by hand. Could be plugged up with dirt and the roller seized. The little drive motor could be burnt out. Take all hoses and areas out that any dirt could be in. No suction means something is plugged. Even your main suction hose could be plugged.
Mar 15, 2017 | Vacuums
My dyson 07 has no suction
Possible Problem #1. The first problem is extremely common. In fact, we probably see between 2-3 of these problems every week. It mostly happens after people take the bottom plate off the vacuum in order to clean the roller brush. What happens is when they reinstall the bottom plate, they put it on on incorrectly. It's actually very easy to do. When the bottom plate (soleplate) is installed wrong, there will be a gap between the bottom plate, and the agitator housing, or the purple tray the roller brush sits in. This will cause the soleplate to be a few inches higher off the ground then it should be, preventing the brushes from even hitting the carpet. This makes it seem to the user that vacuum has lost suction power because without the brushes hitting the carpet, the machine will not pick up very well on floors, but when they use the attachment hose there's plenty of suction power.
Here's a picture of the WRONG way to install the bottom plate. Notice the gap in between the two housings:
Here's another picture, that is the RIGHT way to install the soleplate:
I would say probably 6 times out of 10 this is the problem with the customers machine. If you checked the soleplate and it is installed correctly, move on to the second possible problem.
Possible Problem # 2. Turn the vacuum cleaner upside down so the brush roller is facing upwards. I found the easiest way to work on it is to put it on a counter top or work bench. On the left hand side behind the roller brush you should see a flexible transparent hose that goes from the motor to the agitator housing. This hose actually has a lot of strain on it when the vacuum cleaner is in the reclined position. When the first few series of Dyson DC07 models came out, they didn't make this hose long enough, so when the vacuum was in the reclined position, it would put too much stress on the hose, and cause the hose to actually crack, usually right where the end of the hose that goes into the agitator housing. Examine your hose and see if you have any visible cracks in this hose. If you need to you may just remove the entire hose assembly by pulling on it. It will easily come right out of the machine so you can inspect it better. Here's a picture of where the hose usually cracks:
This would also explain why the vacuum works fine when using the attachments, but not on the floors. The attachment hose uses a different suction channel, and when the machine is in the upright position, no suction goes through this hose. If you do find a crack in this hose, the this hose needs to be replaced. Here's a direct link to that hose on our GoVacuum website.
Dyson DC-07 & DC-14 Upright Replacement Internal Hose Part # 904219
Possible Problem #3. I would suspect that this may not be the problem, but if neither of the solutions above worked, then try this one. Dyson's in general are prone to clogging. There are a few clog ports throughout the vacuum cleaner that were added there due to Dyson prototypes becoming clogged at these points. Here are pictures of how and where to check for these clogs. Simply remove the suction port covers at both of these locations:
Possible Problem #4. If none of the above solutions worked for you, try this last one. The Dyson DC07 models use a clutch mechanism that stops the roller brush from spinning when changed from carpet mode to bare floor mode. This clutch mechanism is a notorious problem with all Dyson models, in fact they were such a problem that Dyson had to redesign the DC07 model to a non-clutch system. Even if yours is one of the newer ones that don't use a clutch, yours still has a belt inside. You can tell if your model uses a clutch or not by the shape of the roller brush. If your brush is a perfect cylinder shape, yours does NOT have a clutch. To check and see if the clutch or the belt have gone bad, first release the handle on the vacuum as if you were vacuuming carpets. Make sure the machine is set to carpet mode. Now while the handle has been released, turn the machine upside down and see if the brushes are spinning. If the brushes are spinning then turn the vacuum right side up and put the brushes on the floor. Can you still hear the brushes spinning when they are hitting the carpet? If yes, then this is not the problem. If the brushes however are NOT spinning, this indicates either your brush roll, clutch, or belt have gone bad.
Aug 06, 2014 | Vacuums
Plenty suction from wand, but when you tilt back to vacum no suction at base but brushes are turning
There could be a few things that would cause your Dyson to have no suction. I will give you detailed step by step instructions along with pictures on how you can diagnose this.
Possible Problem #4. If none of the above solutions worked for you, try this last one. The Dyson DC07 models use a clutch mechanism that stops the roller brush from spinning when changed from carpet mode to bare floor mode. This clutch mechanism is a notorious problem with all Dyson models, in fact they were such a problem that Dyson had to redesign the DC07 model to a non-clutch system. Even if yours is one of the newer ones that don't use a clutch, yours still has a belt inside. You can tell if your model uses a clutch or not by the shape of the roller brush. If your brush is a perfect cylinder shape, yours does NOT have a clutch. To check and see if the clutch or the belt have gone bad, first release the handle on the vacuum as if you were vacuuming carpets. Make sure the machine is set to carpet mode. Now while the handle has been released, turn the machine upside down and see if the brushes are spinning. If the brushes are spinning then turn the vacuum right side up and put the brushes on the floor. Can you still hear the brushes spinning when they are hitting the carpet? If yes, then this is not the problem. If the brushes however are NOT spinning, this indicates either your brush roll, clutch, or belt have gone bad. ....
Dec 30, 2013 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Can't get the roller to spin
i suggest taking hose off and declogging it by using a water hose to make sure its free of debris. Plus check your belt first take off bottom plate the you'll be able to tell if belt is broken which it sounds like it is.
if belt is good and hose is clear and still brush wont spin then your brush motor needs replacing. hope this helps.
Mar 05, 2013 | Eureka Whirlwind Litespeed 5740 Bagless...
No suction near brush
Mar 03, 2013 | Dyson DC07 Animal Bagless Upright Cyclonic...
My vac cleaner doesn't pick up.
Jan 13, 2013 | Dyson DC07 Bagless Upright Cyclonic Vacuum
I ran over a big floor rug with my vacuum and some of the strings from the rug got tangled in the roller on the vacuum. It makes a terribly loud noise even now after I have cleared the strings from the...
You will need to pull the roller out and clean it. I think some of the strings are tangle up at the end of this roller. (Most rollers will come apart at the end for cleaning.) Make sure that the strings are not tangle up on the belt pulley as well. I hope this will help you.
Jan 25, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
How can i keep the belt onmy sharp vacuum
If you have a rug that has tassles or open bits of "carpet tassles," this will injur ANY upright vacuum cleaner. Best way to vacuum a rug is to use a hose with a suction only floor head or small tool on the end.
Jan 29, 2009 | Sharp Twin Energy EC-T2630 Bagged Upright...
Roller will not spin
Thank you a friend helped me find the problem. It was actually very simple!
Aug 28, 2008 | Riccar 8850 Vacuum
Main vacuum suction won't turn off
try cleaning out hoses,if that dont work turn it on its side if the roller doesnt spin u need to change belt if it does take the bottom cover and try cleaning out the hole under roller
Nov 22, 2007 | Eureka Altima Upright Vacuum Model 2996AVS...
Sharp Twin Energy EC-T5980 Bagged Upright Vacuum Logo
97 people viewed this question
Top Sharp Vacuums Experts
Marvin
Marvin
jasbo
jasbo
Mike
Are you a Sharp Vacuum Expert? Answer questions, earn points and help others
