Question about Raymarine C80 GPS Receiver
Boat on screen does not point the direction the boat is going e-80 series also chart will not go course up or heading up like the radar does unit is set in relative motion mode
    Problem Solver:
  • 14 Answers
The direction of the boat symbol is depending on the compass course from the autopilot. You will see that your GPS course (COG) and magnetig heading on the autopilot differs. Solution is to calibrate autopilot compass. Will advice you to not use course up, stick to north up or heading up.
Posted on Sep 23, 2009
I installed a Raymarine compass sensor in a GRP sailing boat underneath the chart table at least 50 cm away from metal and magnets. It is connected to a SP X-5 computer unit and a ST6002 autopilot...
If I were troubleshooting this, I'd manually adjust the orientation of the compass sensor until it matched the true heading. Once that was done, I'd move it side to side to ensure it's changing in the correct directions. If not, the unit could be upside down. Let me know how this turns out.
May 21, 2017 | Raymarine Fluxgate Compass Module
Ais and 1920c Furuno chart plotter
n the system setup, under “UNITS” I set BEARING to “MAG” (magnetic). This will cause the unit to display course / bearing information in relation to the Magnetic North and match magnetic compass readings. It is not the same as True North! One has to be careful with this setting. There are a number of areas where the earth's magnetic field is locally disturbed, sometimes very significantly. Your GPS may not account for it. - again, under “UNITS” I set “METRIC”.
Sep 02, 2008 | Furuno NavNet vx2 1920C GPS Receiver
Tip
Furuno VX2 Radar heading alignment
Please take the time to rate this tip!
This tip applies to all VX2 radars from Furuno. Models Include 1724c, 1734c, 1824c, 1834c, 1934c, 1944c, 1954c, 1964c, 1724cnt, 17234cnt, 1824cnt, 1834cnt, 1934cnt, 1944cnt, 1954cnt, 1964cnt, and 19XXBB series black box radar processors.When the picture is "crooked", "rotated" or "needs re aiming" you need to do the radar heading alignment. In order to do the radar heading aligment, you must access the installation menus, available only in installation setup mode.
Press and hold "MENU" during power on.Continue holding menu during start up, at least until the boat appears.
Choose , "Installation Mode", Choose "Menu", "System Configuration", "Installation Set Up" "Radar Set Up".
Here is where people get lost! Choose "Next Page", Choose "Heading Alignment". You will be prompted to place the dotted line on a target "dead ahead". Follow instructions and then, do not forget to press "SET". Press Return Return Return or Menu to exit and resume normal operation.
Note that the installation menus disappear if they are not accessed for five minutes!.
Please take the time to rate this tip.
That is all there is to it.
Please "Optimize Radar Video" in same menu (Radar Set Up).
847-746-0100
www.technicalmarine.com
on Jan 17, 2010 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
Furuno radar
Your antenna seems to be mis alighned. Its ZERO point must be readjusted.
Aug 30, 2008 | Furuno Navnet 1834C/NT vx2 Radar C Map Nt
Won't open the overlay screen
You must have a heading sensor input for radar/chart overlay. (i.e. PG500)
Jun 19, 2010 | Furuno NavNet vx2 1934CBB/NT GPS Receiver
Furuno 1942Mk2 Problem
it cannot determine a heading, have you also damaged an internal antenna or positioning / gps device inside it? It is unsure which direction it is pointing in but uses triangulation to determine this.
That requires either an electronic compass unit, or gps to achieve correct heading and hence correct orientation of the radar image
Nov 14, 2009 | Furuno 1942 Mk2 Radar
Furuno 1622 doesn't work, water coming out cable at screen!
yes the cable should be replaced if you are lucky, the unit is still OK (display) Try the new cable, draped across the boat before rigging. If fault exists with new cable, replace system, or find a new display on ebay
Nov 17, 2008 | Furuno 1715 LCD Radar System GPS Receiver
RAYMARINE
With the charts page up, start by hitting the find ship softkey at the bottom of the screen.If that find the boat on the chart all is good.If not you need to check you have a GPS fix. Go to GPS screen and see you are seeing satalites.
If all is good when you hit find ship and the boat disappears again from chart while underway you will need to go into the chart setup menu and see if the screen amplifier is turned off. If off turn on.This is first place to start. Hope that helps
Jul 13, 2008 | Raymarine A65 Combo GPS...
Furuno navnet 1723 C
go into installation mode (hold menu during power on) find radar setup, go to next page, do heading alignment. also tune video, your unit was reset!
Jun 09, 2008 | Furuno NavNet vx2 1920C GPS Receiver
Orientation
It is not likely that there is a software error that could cause that problem so I'm going to cover some basic information first. Forgive me if I'm covering stuff you already know. There are 3 chart orientation modes, North Up, Heads Up, and Course Up. North Up you already know! In Heads Up mode, the chart will only orient heads up when the boat is moving. Unless you have an electronic compass interfaced to your GPS it has no way of knowing which way you are facing. Once you start to move, it compares your new position to the old position to determine which way is heads up. If you are not moving, the map defaults to North Up even if you are in heads up mode. Course Up mode is commonly mistaken for Heads Up. In Course Up mode, the GPS orients the top of the screen toward a waypoint that you have told the GPS to go to. If no waypoint is selected, the GPS will default to North Up orientation. So I guess what I'm saying is, make sure the boat is moving, and make sure you're not in course up mode (unless you want to be).
In the unlikely event that there is a software error causing this problem, it can easily be fixed by getting an update from Standard Horizon. You can either get them to send you an update chip, or download it online and copy it to a blank C Map card. When you turn the GPS there will be a message on the opening screen that identifies you software version. Get that information before you call Standard.
Feb 13, 2008 | Standard Horizon CP-1000C GPS Receiver
Raymarine C80 GPS Receiver Logo
239 people viewed this question
Top Raymarine GPS Experts
Steve
Steve
Jon Piercy
Are you a Raymarine GPS Expert? Answer questions, earn points and help others
