Question about Samsung SGH-U600 Cellular Phone
How to add songs from samsung u600 to mp3 player inbuilt in samsung u600?
Add the files in the folder music. but when want play there isn`t files
HI,
It is possible that the problem is it is either you are putting the song in an incorrect folder or your are suppose to use a program to sync music in the MP3 player for it to detect the audio or songs properly.
just like iTunes on an iPod if iTunes is not used then the audio can be put in the folder of the MP3 player/iPod but will not be detected when the MP3 player is used to play the song/music, Same goes for you Samsung MP3 Player I suggest you check for an application or program that you may need to use in order to get the Audio/Song/Music detect when putting them in the Samsung MP3 Player.
I hope this helps.
Have a nice day,
mvincentc
Jul 23, 2011 | Samsung YH-820 MP3 Player
How to put on the songs on it
How to Add Songs on Samsung YP-U3 MP3 Players
The Samsung YP-U3 is an MP3 player that comes in various colors. This device has a built-in USB plug, so it's not necessary to have a cable to transfer songs from your computer. To transfer songs to your device, you will need to use a PC. If you don't have the Samsung Media Center installation disc, you can download the software from the Samsung website.
Instructions
Install the Samsung Media Center if you have not done so. This is the software used to transfer songs to the YU-P3. The installation disc comes with the device. Simply insert it and follow the on-screen prompts.
Insect the bottom end of your device. You'll see a hidden USB plug on the end. Push it outward to extend it. Plug the device into your computer's USB port. This is usually on the front of the tower. The Samsung Media Center will automatically start after a few seconds.
Locate the file you want to transfer to the device. The Media Center's screen will display the MP3 (and other audio) files currently on your computer. When you find a file you want to add, click on it.
Click on the "Right Arrow" button. This transfers the song to the device. Repeat to transfer more songs, if desired.
Right click on the green USB icon on the right-side of your taskbar. Select "Safely Remove." Unplug your Samsung YP-U3 when prompted.
Hope it helped..
Have a nice day...
Feb 22, 2011 | Samsung YP-U3 MP3 Player
How do i delete songs and get new ones on there
Use Windows Media Player to put your songs on your Samsung.
Start Media Player, plug in your YP-K3 into the computer using your cord that came with the player. Media player will show your player, then just add your songs as you wish.
To Delete songs,pictures,ebooks,etc. Follow the directions below:
Hook up your mp3 player to your computer
Go to your desktop and double left click on "My Computer"
When it opens you will see listing that says "Devices with Removal
Storage" your mp3 player should be listed there.
Right click on your mp3 player, and a window will open, right click on
"Open" and now your files/songs should be visible.
Hold the left click down and drag it across all the files/songs that
you do not want this will highlight the files/songs you do not want,
release, right click and then click on "Delete"
Now your mp3 player should be clear of the files/songs you do not want.
Be careful and do not delete files needed to operate your MP3 player.
Please rate me
Dec 23, 2010 | Samsung YP-K3 MP3 Player
How do you download music on this device.
Go to the following link and download "Multi Media Studio Version 5.2.1.2, and install it on you computer.
Once you have it installed you put you music in it (You can scan your computer with the program to find your music)
Once you have your music in the program, make sure the Multi Media Studio is running, then hook up your cord from the MP3 player to the computer.
The MP3 player will show up in the Multi Media program, you can then click on the player and see what songs you have on it.
If you want to add songs, then highlight them by right clicking and draging down on them, then click on "Add to portable device"...(this will show in the Multi Media Program) This will add the songs to your MP3 player.
Good Luck,
I hope this helps
http://www.samsung.com/ca/support/download/supportDown.do?group=&type=mp3players&subtype=mp3players&model_nm=YP-P2JEB&disp_nm=P2%2016%20GB%20Black&language=&cate_type=all&dType=D&mType=SW&vType=&prd_ia_cd=03040200&model_cd=&menu=download
Nov 24, 2009 | Samsung P2 MP3 & Video Player
Deleting songs off mp3. Mp3 is full so i want to add more songs. So I need 2 delete so or all of my songs off my mp3. & i'm 14 so it gets boring havin 2 listen 2 the same songs that you don't even want...
try using windows media player to navigate thru the file on you mp3 player and delete the ones you dont like on it then use the media player again to sync the new ones onto it
Sep 20, 2009 | Samsung YP-U3 MP3 Player
Memory card not readable on mobile
You need a suitable sd card card for your mobile phone.
Jul 14, 2009 | Dane-Elec TA-SD0512-D MP3 Player
Samsung U600 Music Player - Playing from the memory card
Well i have samsung u600 and i had to change all my mp4s in mp3 and that should go into your music player automaticlly, download format factory prgramme it is really good and change them.
I hope i helped x
Jan 22, 2009 | Samsung SGH-U600 Cellular Phone
I found nofiles when trying to play somgs from mp3 player
Instead of dragging the songs directly to the player, use windows Media Player to transfer the songs instead - erase all of the ones that you have dragged on to the player first before proceeeding.
The instructions in these pages, which are largely links, pertain to Windows Media Player 10 and 11 only.
Windows Media Player is made by Microsoft. The general help page for Windows Media Player is:
http://www.microsoft.com/windows/windowsmedia/default.mspx
Through this link, you can enter a variety of search terms that will help you find what you are looking for (exs.: “add files to my mp3 player”; “delete files from my mp3 player,” etc.)
Important Vocabulary:
The code word for “mp3 player” in Windows Media Player is “DEVICE” or “portable device”
The code word for adding files is “SYNC,” “syncing,” or “synchronizing”
The code word for copying files from CD is “RIP,” or “ripping”
The code word for files stored on both My Computer and my Mp3 player (when it is connected to the computer) is “LIBRARY”
To add files (SYNC) to your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windowsxp/using/windowsmediaplayer/wmp10/harrison_wmp10.mspx
To add files (SYNC) to your mp3 player using Windows Media Player 11:
http://www.microsoft.com/windows/windowsmedia/player/faq/sync.mspx
To delete files from your mp3 player using Windows Media Player 10:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/mediaadvice/0085.mspx#EDF
To delete files from your mp3 player using Windows Media Player 11:
My Directions:
1. Connect your mp3 player to the computer
2. Open Windows Media Player
3. Click on the icon of your Mp3 player on the left-hand side of the Library
4. Click on the Songs, Tracks, or other Music Folder
5. Find a song or songs that you want to delete
6. Left-click the song once to highlight it
7. Press the “Delete” button on your computer’s keyboard
To copy (RIP) files from CD to Mp3 player using Windows Media Player 10:
http://www.microsoft.com/windowsxp/using/windowsmediaplayer/getstarted/ripcd.mspx
To copy (RIP) files from CD to Mp3 player using Windows Media Player 11:
http://www.microsoft.com/windows/windowsmedia/knowledgecenter/easystart/mp11guide.aspx#RippingCopySsongsfromCDstoYyourCcomputer
Jul 05, 2008 | Samsung YP-U3 MP3 Player
Samsung YP-T7 MP3 Player
a friend gave a this mp3 player and told me if I can get it to work its mine. I can transfer information, but can't make it play
Sep 25, 2006 | Samsung YP-T7 MP3 Player
Can't add songs
Use different port it will work.
Jun 20, 2006 | Samsung Yepp YP-T7JZ MP3 Player
Samsung SGH-U600 Cellular Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Bill Long
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
