Question about Dryers
Electric dryer. no heat but heating coil not broken
    President:
  • 1,776 Answers
Check the thermal fuse. It's about an inch long and is usually located inside the rear of the dryer attached to or near the exhaust duct. It can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity means a bad thermal fuse. Hope this helped and best wishes.
Posted on Sep 08, 2009
Dryer warms..... but not enough heat to dry...about 10 years old 80 series Kenmore electric dryer
Probably has a broken heating coil...as the temperature goes up it expands and moves from natural position of touching....that would give the false indication of continuity in the coil when it cools back down and touches again. Visually inspect coil.
Nov 02, 2013 | Kenmore 800 7982 Dryer
Hotpoint dryer model DLL2650BFLWH not heating
If this is an electric dryer, your heating coil has broken and is no longer conducting current and heating.
Oct 27, 2012 | Hotpoint TDL15 Electric Dryer
Dryer starts but knocks out circuit breaker almost immediately
Hi, The heating coil has broken and is shorting out...
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 15, 2011 | Whirlpool GEW9250 Electric Dryer
Not generating heat and dosnt stop automatically
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101 ,..,
Apr 03, 2011 | GE Dryers
My dryer stopped heating but still goes through the cycles.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 11, 2010 | Whirlpool LER5636P Electric Dryer
Dryer does not heat, but does tumble clothes and blows air., what is wrong?
Check the electric heating element. This is a long coil, looks like a long spring. That spring (coil) could be broken. If it is broken, you can just take it and twist the two halves together and put it back in. OR buy a new coil spring.. This is in the bottom of the dryer.
Sep 08, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Dryer does not get hot
There are a number of things that can go wrong on an electric dryer that will make it not heat...
Check out this tip that I wrote about that problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Mar 31, 2010 | GE DBSR453EBWW Electric Dryer
Doesn't heat up
Sheri, This says that you have an electric dryer and that it fails to create hot air. It can be 2 issues. (1) the electric heating coil (behind a panel in the lower back of the dryer) has broken and must be replaced or (2) the air duct work inside the dryer is clogged and the heated air is unable to pass through the dryer.
If you are sure that air is flowing, the it is the coil and to replace it, remove the panel screw and locate the 2 mounting screws for the heating coil. Remove it and take it to your local appliance parts place and ask for another. Insert that, connect and fasten as the original and you should be of and running
Nov 22, 2009 | Whirlpool Dryers
Whirlpool dryer model LER3624jq0 has no heat but spins and works fine besides that..fuses are good, the heat coils are getting electricity but just wont heat up.. seems like everything is workin fine just...
They could get electricity but when the coils are broken into the will not heat. Diaphram is at AppliancePartsPros.com I dont actually know them but I found my parts there.
Oct 10, 2009 | Whirlpool Dryers
Kenmore 64942300 Electric Dryer runs, no heat
This may seem too simple of an answer based on your extensive troubleshooting thus far, but the most common reason for cold air running of any electric dryer is a broken heater coil. This is simply a coil of wire that is heated to warm the air in the fan duct. These often overheat and break if the vent duct is blocked, too long, or has odd bends that can restrict flow. Recommend replacing heater coil and use smooth wall vent pipe. Avoid coil type flexible duct.
Jul 03, 2017 | Kenmore 64942 Electric Dryer
Dryers Logo
Top Dryers Experts
