Question about Asrock P4I45GV R5 Motherboard
Display problem processor heat up. no beet with ram and no beep with ram and no dislplay on agp and pci card but computer poer up.
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Champion:
  • 202 Answers
Yeah it does power up, but that doesn't mean it is booting. Remove your ram, the processor but leave the cpu fcan connected, then power the board for about a minute.then put them back. if it does not boot up change the ram and it this did not work change the processor. i just gave you a free diagnostic of a working board, good luck
Posted on Sep 08, 2009
  • 797 Answers
Problems can be more than we almost can list here.
Check the cpu that it will work in another board.
Check the ram modules that they will work in another board.
When checking the board, remove all cards and try with the cpu and ram installed. Make sure you have the right ram in the right slots. This can make a diff. in some boards.
If your processor and ram are okay, then a problem is existing with the board.
Beep codes
Try taking out the RAM (memory) cards and reseating them. Same with video card (if it's got a plug in(PCI-e/AGP) card)
If it is beeping constantly suspect a fault with overheating on the processor. Is the fan on the CPU working? Might be the thermal compound between the heatsink and the processor has gone bad and needs redoing ...
Oct 14, 2013 | IBM IntelliStation M Pro 6219 PC Desktop
Display problem
remove your processor and the processor fan clean the processor surface with a clean cloth and fix it to the socket apply a thin layer of heat sink compound and fix the heat sink firmly to the processor remove your memory card and clean it with a neat cloth and insert it in the slot and restart the computer still not working remove the memory module and restart your computer you will hear long beeps now insert the memory and restart your computer if you hear only one short beet and display not coming add an pci or agp graphics card if it work the problem is with your graphics section in the motherboard
Nov 15, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Won't post, no beep. No display on monitor. Tried different AGP video card, different memory. I have unplugged everything but the AGP card and hard drive. The monitor works on a different computer so...
Basically, display card, RAM and processor are the ones affecting the display. IF trying different memory and video card doesnot help. Try changing the different processor. Thanx with regards Sajan
Jan 21, 2010 | Abit IC7-MAX3 Motherboard
After pressing POWER button i get 2 long beeps -- thats all -- nothing on the monitor -- nothing at all ... :( ??
Two beeps means that you need to check your RAM. Try changing the RAM module and see if it working? If you have any display card (AGP/VGA/PCI or PCI express) installed then you need to check that it is properly inserted in the slot in the motherboard. Also check for any loose connections in display card.
Dec 21, 2009 | MSI K8MM3-V Motherboard
Need graphic card agp slot?
an agp slot card is the older type the newer one is pci express.
if you are buying a graphics card make sure you dont buy the newer pci express if you board only supports the agp type
May 06, 2009 | Intel Celeron D 355, 3.33 GHz...
My son has my old computer and it needs a video card
Your information is slightly conflicting. Pentium is a type of processor, and AMD is another brand, your computer can't contain both types of processor. Your video card will either be AGP or PCI-e, depending on the model of the computer. If you'd like to leave me the model of the PC, I'll look it up for you.
May 06, 2009 | Compaq Presario sr1403wm AMD Sempron 3000+...
L7vmm mb. display went out. Monitor works on
Dear User. to plug in the AGP card you dont need to check or see the CMOS. if u have pluged an AGP card and problem still persist then the problem is at *********** side or in RAM. just plug out RAM and other hardware except Processor and cables of switches. the switch on it and if it gives beep then your motherboard and processor is OK. there would be problem in your RAM so change RAM. and if it dont give the beep at startup then the problem is in your motherboard or power supply.
Apr 17, 2009 | Computers & Internet
One long beep tow short beep
One long beep and two short beeps mean faulty video adapter.
If you are using a card, like a PCI or AGP video adapter then remove and put back the card in slot.
If you have a motherboard, then the video chipset on motherboard had gone, buy an agp video adapter and insert it in the slot inside your computer to fix the problem.
below an example of PCI and AGP video card:
MSI G4MX4000-T64 64 MB Graphics Card
HP Intel DVI AGP digital display card
ATI Rage 128 Pro 32 MB PCI Graphics Card
Mar 09, 2009 | Computers & Internet
My Computer does not boot
please check whre u have connected ur monitor comm cable, is it in agp card or on borad display card
Apr 21, 2008 | ASUS M2N-MX Motherboard
Asrock P4I45GV R5 Motherboard Logo
244 people viewed this question
Top Asrock Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Computer Links
Are you an Asrock Computer and Internet Expert? Answer questions, earn points and help others
