Question about Bosch Solar Indoor Gas Tankless Water Heater 1600PS Propane
Can you send me book of how slipt water solar is made
    Champion:
  • 248 Answers
Wolsley group will order best of luck
Posted on Oct 31, 2009
Solar hot water not hot
Solar hot water giving you cold showers? Eight tips to warm you up.
Eight tips to get the most from solar hot water
We argue that policy needs to look beyond installation and that installation practices need improving, but what can you do to get an effective installation?
First, seek out independent advice from sources such as local sustainability events and organisations. They can help you understand what suits your circumstances and what characterises an effective installation.
A good organisation is theAlternative Technology Association. They provide free advice to members, sell a solar hot water guide, and organise open house events where you can see and discuss domestic sustainability technologies.
Second, consider whether solar hot water is the best option. It may be that a hot water heat pump or an instant gas system is a suitable choice, depending on where you live, how much cloud cover you have, or what sort of building you are in.
Third, make sure all your hot water pipes are insulated, especially the pipes that go to and from the tank and solar panels. You typically need insulation to be 15 mm thick. Without proper insulation you could lose half the energy you are trying to collect.
Fourth, get a booster switch installed in a convenient place inside, so you can easily turn the booster off if there is plenty of sun, or on if it's cloudy or you need more hot water.
Fifth, if you go solar, install a system that has a sufficiently large tank matched with a sufficiently large solar array for your needs. Water is very good at storing heat. A large tank could help you store solar energy for those rainy days.
Sixth, you may need to change electricity tariffs if your booster is electric, to ensure the sun gets a chance to heat the water before the electricity does.
Seventh, you may need to change your peak hot water use habits so that the tank water is at its coldest after morning use, after which the sun can then heat it during the day. The booster can "top up" overnight, ready for morning showers.
Eighth, before you install solar hot water, examine and discuss household expectations around hot water use. Will they need to change? Are members of your household prepared to make that change?
This may be the most profound change you can make, but also perhaps the most challenging.
Oct 30, 2016 | Water Water Heaters
Can I pressurize a solar hot water system to town pressure
You need to install a home hydroneumatic sistem. You should ask a specialist. to provide the equipment
Jun 06, 2015 | Water Water Heaters
Leaking relief valve on solar panel
I had to replace mine a few years ago. Just look on line. Search for pressure relief valve, or add solar. You will get a lot of responses. Comparison shop and buy. On line auctions work well also.
Mar 07, 2014 | Caleffi Solar Collectors
How long will it take Rheem solar hot water to heat up
read manual:
http://www.rheem.com.au/Assets/1294/1/Rheemsolarlolineelectric511series.pdf
Usually electric element heats about 20 gallons per hour.
It appears the element is controlled by thermostat and automatically kicks ON when tank falls below thermostat set point..
This will be handy since element will continually heat the circulating water when outside temperatures turn cool... of course it will also be wasteful if thermostat is set high.
Jul 11, 2013 | Water Heaters
No hot water
10-22-12
Copy following links to help identify product and download possible troubleshoot resources:
Tank-type gas
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
Tank-type electric:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Rheem tankless:
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Other types of water heaters include boiler, tankless electric, indirect, solar-assisted, solar, hybrid electric, heat pump, wood-burning, gas hybrid, 3-phase commercial electric.
Oct 21, 2012 | Rheem Water Heaters
How to design and calculate the solar heat panel for hot water system for the concentrated 100 nos. staff toilets and changing rooms of commercial building in Beijing. What is the basic and ancillary...
Usually toilets do not require hot water.
Is the plumbing divided into hot and cold water pipes?
If toilets are hooked to hot water, how many flushes and how many gallons per flush per day.
What is the expected consumption per each worker?
What is the latitude from equator, and expected solar input. Further north, and hazy atmosphere reduce input. Beijing has smog I believe.
How often is the solar panel going to cleaned of smog and dirt for maximum collection?
If the area has hard water, then the entire system is prone to sediment build-up and failure unless water is artificially softened.
Solar water heater temperatures can exceed 180 degrees at times. This temperature will damage storage tank that is not made for that temperature.
Most solar water heater systems have pressure regulating valve and expansion tank to accommodate occasional high temperature and pressure.
A good fellow to contact might be at following website:
http://www.builditsolar.com/Projects/WaterHeating/water_heating.htm
Solar collectors are usually connected to a circulating pump, and then the heated water is stored in a tank.
The pump circulates water continually from solar collectors through a storage tank.
This type of system would use ordinary tank-type water heater for storage.
Most of these systems also utilize a back-up heating element inside the tank.
More complicated systems circulate special liquid through spiral tubes inside the water heater.
This type of heater would be an indirect water heater.
Indirect heaters are used for solar collectors, and used with boilers, or any outside heat source.
http://www.bockwaterheaters.com/Products/products_coil_tank_water_heaters.html
http://www.hotwater.com/products/residential/cirrex_solar.html
http://waterheatertimer.org/images/solar-water-heaters-on-roof_lbiRv_5784111-500x282.jpg
Oct 05, 2011 | Water Heaters
Problem is i have a gravity fed system and yesterday connected a cold water line for an evaporative cooler to the cold water line coming of it. now there isnt any hot water
water will always find its own level and take the path of least resistance. if your hot water tank inlet is higher than the swamp cooler this may be your problem. you can try a line resrtiction at the cooler or a twelve volt rv pump with a battery and solar charger and an on off switch.know someone with this set up and it seems to work well.
Nov 28, 2009 | Water Heaters
Low Water Pressure Gas System but High Pressure when Solar Water
if you have a gate valve on the unit from the hot water tank it could be as simple as the valve on the gas system being clogged going to that bathroom,, from how it is described it sounds like that would be the problem check to make sure all valve are not stuck in the on position ans change the valve if it is frozen in place
May 22, 2009 | Water Heaters
Bosch Solar Indoor Gas Tankless Water Heater 1600PS Propane  Logo
76 people viewed this question
Top Bosch Water Heaters Experts
Colin Stickland
Colin Stickland
Donni Steen
john h
Are you a Bosch Water Heater Expert? Answer questions, earn points and help others
