Question about Fusion FEW12PK Car Subwoofer
I have a fusion sub and amp and have no instructions on how to wire this can somone please help ive got green wires red wire and a small thin blue wire
  • 655 Answers
Hello nicole_murra,
The green wires are for signal input to the included amp and should be connected to a pair of RCA preamp outputs on your head unit. The thin blue wire connects from "remote" on the amp to a switched 12V output on the head unit (usually blue or blue/white). The red wire is for power and goes through the fuse to positive battery. You also need to connect the amp terminal marked "ground" to the metallic chassis of your vehicle, within a distance of about 1/2 meter or less. There's usually a short piece of wire with black insulation included in most amp wiring kits. If your Fusion sub did not come with such a wire, you can use any wire that is the same gauge (or bigger) than the red power wire.
Hope this helps.
Posted on Sep 11, 2009
Fusion AT 1100 Flashes green power light once and then shuts down. Hiya I have checked all the wires again but no luck. I love this sub and do not have money to buy another one. Please help :-(
Amp is going into protect mide. This means either the amp has an internal fault or the speaker is blown. Pull the speaker out and disconnect the wires from it. Make sure they don't touch. If the amp powers up fine you know the speaker is bad. If it doesn't the amp is bad.
Jul 26, 2016 | Fusion Car Audio & Video
I urgently need a Clarion cd1500r installation manual or wirng color codes
Hello, here is Clarions wire codes.
FRONT Right SPKR: +Gray -Gray/Blk,
FRONT Left SPKR: +White -White/Blk,
REAR Right SPKR: +Purple -Purple/Blk,
REAR Left SPKR: +Green -Green/Blk
Brown Wire = Phone Mute Lead (If applicable)
Yellow Wire = 12V battery lead in (Connect directly to battery)
Red Wire = 12V Ignition wire (Connect to Acc switch)
Blue/White Wire = Amp turn on lead
Black Wire = Chassis Ground
Orange/White Wire = Illumination Lead (Connect to dimmer switch)
Blue Wire = Auto Antenna Lead (lowers power antenna Do not use for Amp Turn on! Use the Blue/White Wire for Amp,EQ, Ect.. turn on wire only
RCA Connectors if applicable:
Black RCA Harness:
White RCA = Rear Audio Left Sub Output 1
Red RCA = Rear Audio Right Sub Output 2
Gray RCA Harness:
White RCA = Front Left Audio Out to amp
Red RCA = Front Right Audio Out to amp
Oct 19, 2010 | Clarion Car Audio & Video
My sub has all bin wired up proberly the sub works for about 30 secs then the green light goes out and no power to the sub at all
Green light on amp?? Seems like your amp is going into thermal overload. Check your power connections, and make sure there are no shorted wires. Hope this helps.
Apr 21, 2010 | Fusion FEW12PK Car Subwoofer
How do i wire a fusion 12'' active encloser up to my car?
OK. (1) The RCA's plug into your audio-In on your amp and the other end of your RCA's plugs into the back of your cd player's audio-out. (2) The small blue wire is the "Remote wire" the one end is wired together with a blue wire in back of cd player other end to amp..To attach wire "remove some of the rubber insulator on wire about a 1/2 inch then twist wires together and put electrical tape to cover or wire nut if you have one." (3) "Ground wire" this is the black wire one side to "amp - neg" and the other end to frame of vehicle. " find a bolt in trunk and put the end of the wire around that and tighten bolt" but before putting bolt on take sand paper to the metal frame where the bolt hole is and sand all the paint off! (4) Last Power wire the "red wire". Cut about 12 inches off power wire plug one end to "amp + pos" the other end to the fuse...Now with the rest of the Power wire plug the one end to the otherside of fuse and run that threw car either driverside door or underneath the dash to the "+ pos red" side of battery.
Then your done! Good luck! and wire in that order and you want blow anything! Give me a thumbs up if you like!
Sep 24, 2009 | Car Audio & Video
1994 ford escort stereo wire colors?
1994 Ford Escort Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Blue/Red
Car Radio Accessory Switched 12v+ Wire: Blue/Black
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Violet
Left Front Speaker Negative Wire (-): Blue/Orange
Right Front Speaker Positive Wire (+): Blue/White
Right Front Speaker Negative Wire (-): White
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Blue
Left Rear Speaker Negative Wire (-): Red/Blue
Right Rear Speaker Positive Wire (+): White/Green
Right Rear Speaker Negative Wire (-): Blue
PLEASE RATE THIS INFO AS A FIXYA! IF YOU FIND IT IS WHAT YOU NEED, THANKS ALLOT.
Oct 08, 2008 | Ford Escort Cars & Trucks
Fusion sub n amp dont work
didi u check ur fuses in the amp..if not there check the fuse under the hood on your power wire.i had the same problem
Jul 27, 2008 | Car Audio & Video
I cant instsall the whole system, does anyone have any ideas??
bagman Fat Red wire from batter + to Fuse. Fat Red wire From Fuse to Amp +. Amp- Fat Black wire to body Ground. RCA cable run from Head unit RCA jacks down opposite side opf car from power wires. To Amp RCA inputs. Wire Speaker REd terminal to Plus on Amp. Balck Terminal to Minus on amp. Blue Wire is REmote, and wires to Blue on head Unit. Remote on Amp.
Oct 03, 2007 | Fusion FEW12PK Car Subwoofer
Fusion FEW12PK Car Subwoofer Logo
403 people viewed this question
Top Fusion Car Audio & Video Experts
Matthew Spark
Matthew Spark
Tygh Duval
Tygh Duval
Are you a Fusion Car Audio and Video Expert? Answer questions, earn points and help others
