Question about Whirlpool LSR5132PQ Top Load Washer
The water was filling and it stop , and the washer would not wash or do anything after that. now it will not finish the cycle.
    President:
  • 1,865 Answers
Most likely problem is bad timer, you can purchase and replace it yourself
Posted on Sep 08, 2009
The washer does not stopping rinse cycle.
are you saying there is no water or it keeps filling
if no water change the cold water valve
Feb 04, 2014 | Magic Chef Washing Machines
Washer will not stop filling no wash cycle.
You may not have to change the complete water valve. Just check if there is anything blocking your thin pressure hose at the bottom end, and see if the pipe is not kinked or has holes in it. When you blow thru the lower end you should hear a click in the switch above - denotes it is fine.
Apr 28, 2013 | Kenmore 24032\24036 Top Load Washer
Why wont my amana washer start at all?
My washer will notwork it will not let the lid lock are fill with water
Jan 20, 2013 | Amana NTW4501XQ Top Load Washer
Agitator starts at begining of cycle before washer is full
Please be carful as running the agitator without enough water will overheat and kick out the motor, however it should be ok when it resets itself.
Yes, the machine should stop agitating when you lift the lid so this too is part of the problem.
After looking at the print I can only suggest that the cam contacts in the timer ( contacts 12 and 14) that start the motor are burned and stuck together.
Quentin
Sep 17, 2009 | Frigidaire FEX831CS Top Load Stacked...
I HAVE A KENMORE WASHER THAT I BOUGHT BRAND NEW IN 2002. AFTER IT FINISHES ITS INITIAL WASH, IT DOESN'T DRAIN LIKE IT SUPPOSE TO, AND CONTINUES THROUGH THE REST OF THE (ENTIRE)CYCLE, UNTIL IT REACHES...
Change the main controll, the one behind the dial that you turn. About 75.00. bucks. Clean hose from lint build up at pump exit inside washer.
May 12, 2009 | Washing Machines
Washer will not fill
not your timer / if anything its eather the water valve or the water slector switch
Nov 23, 2008 | Kenmore 24032\24036 Top Load Washer
Fills with water and that's it
ck the water pump, only if it agitates but doesnt drain. If it completely stops after filling, ck lid switch(should here clicking noise from sw.)
Oct 21, 2008 | Frigidaire FEX831CS Top Load Stacked...
Kenmore washer model 110.49722990 it will not go into the drain or spin part of the cycle, just sits there and hums, won't do anything. It will fill with water and wash,but thats all it won't finish the...
Does it fill with "cold" water?Will it spin?Drain?If the machine will fill up with cold water,will the timer advance by itself to finish?Or if you place the timer in spin cycle will it spin?First off if your not getting "Cold" water to fill inside :Replace the water valve (because when the timer stops after the agitation cycle it wont advance because it cant fill up with cold water.
May 23, 2008 | Kenmore Washing Machines
Whirlpool LSR5132PQ Top Load Washer Logo
26 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
