1998 Honda Accord Logo
Posted on Sep 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
This the original radiator in a 1998 honda accord
Is the original radiator in a 1998 honda accord 4 cyl ex made of plastic or metal
Anonymous
Level 3:
  • Master 3,600 Answers
  • Posted on Sep 08, 2009
Anonymous
Master
Level 3:
Answers
3600
Questions
Helped
1575427
Points
11774
Why it stalls at stops and low speeds
accord stalling on every stop. (1/2) - EricTheCarGuy ...
www.ericthecarguy.com/.../8.../46884-accord-stalling-on-every-stop
The car runs good but stalls every time i come to a stop. ... a stop then it diesagain.only on the stops does the idle drop very low to the point of stalling.what ... only when I start slowing down and come to a complete stop RPM's go down and the cardies. ... The popular Honda Civic and Accord vehicles share many powertrain ...
1998 Honda Accord loses rpm/ stalls coming to a stop ...
honda-tech.com/honda-accord.../1998-honda-accord-loses-rpm-stalls-co...
Jan 10, 2013 - I just bought a 1998 4 cyl 2.3 L Honda Accord two days ago. ... 1998Honda Accord loses rpm/ stalls coming to a stop. .... Is clockwise high idle or low idle? all in all i probable rotated counterclockwide 1.5 or 2 turns. maybe this ...
1999 Accord, 130k+, stalls when slowing to a stop - Honda Accord ...
www.hondaaccordforum.com > ... > General > General Tech Help
Mar 10, 2010 - My fiancee's '99 Accord EX Coupe 4-cylinder automatic, with 130,000+ miles, has recently (in .... No low RPM & feeling like it's GOING TO stall.
99 Honda Accord - Strange Stalling Issues! HELP!
https://www.2carpros.com/.../1999-honda-accord-99-strange-stalling-issu...
My 1999 Honda Accord is having sporadic stalling problems. I've noticed a pattern. Itstalls while going slow speeds and stop and go traffic, etc. The engine just ...
Stalling or Low Engine Idle Speed Due to Dirty ... - Repair
2009 Honda Accord EX-L 4 cyl Procedures to change exhaust cam shaft
You need a factory service manual
--at least for torque specs
Manual or not-- you can try You Tube Video
has to be there
Honda Accord EX 4 cyl. 1998 has troubleshooting which has the code P1457 . What is this ?
p1457 is an evap code. If you where to bring it to the dealer they would be able to run a complete evap system test and tell exactly what the problem is. I've run this test on over a 100 accords like this and 90% of the time the fault is in the cvs valve. (canister vent shut valve). Its located under the vehicle closer to the rear, on the side of the evap canister. the part runs approx. 100-175 dollars. Good luck hope this helps!
Adding coolant to1998 honda accord purging air pockets
4 cyl Accords have a low pressure, self purging cooling system, so no purging is needed. Add coolant (cold engine) to the normal level. Then, with the coolant tank cap closed, open the radiator cap and fill the radiator completely, close the radiator cap and run the engine for a couple of minutes. Replenish the coolant to the proper level, since it will go down after the air bubbles have been extracted at the coolant tank.
1helpful
1998 honda accord ex air conditioning not cool
Did you check the condensor fan to make sure its working
1helpful
1995 Honda Accord EX 4 Cyl. VTECH Car overheating... does not have a thermostat. Noticed that one of the two Radiator Fans is NOT working... what should I look at? Thank you in advance.
first it should have a thermastat installed, second - the second fan doesn't kick in until the engine reaches a certain temperature
2001 Honda Accord EX-4 cylinder
remove the hose ...this is to the radiator correct just make sure the motor has not been Running or you will get burnt also use a pan to collect the antifreeze and refill the radiator
2helpful
1998 Honda Accord EX sputters for first 30 - 45 seconds
have the compression checked its likely a head gasket is leaking and letting antifreeze back in the cylinder when you turn off the engine radiator would also be a lttle low
HOnda Accord EX 1998 ALARM
Have you tried putting your Valet (original keys) into the ignition and turning it to the II position?
Top Honda Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Honda Expert? Answer questions, earn points and help others
