Question about Dell 946 All-In-One InkJet Printer
Dell AIO 924 printer says low ink levels. Just
Dell AIO 924 printer says low ink levels. Just replaced with new. Not printing correctly.
Missing lines of print
hello
You either have to change the ink cartridge or try to clean the ink cartridge nozzles as described in the user manual;
http://support.dell.com/support/edocs/systems/924/en/om_en/om_en.pdf
On page 54 it states the following:
To clean the ink cartridge nozzles:
1 Load plain paper. For more information, see "Loading Paper" on page 19.
2 In Windows XP, click Start-Control Panel-Printers and Other Hardware-Printers and
Faxes.
In Windows 2000, click Start-Settings-Printers.
3 Right-click the Dell Photo AIO Printer 924 icon.
4 Click Printing Preferences.
The Printing Preferences dialog box opens.
5 Click the Maintenance tab.
6 Click Clean Print Cartridges.
7 If the print quality has not improved, click Print Again.
8 Print your document again to verify the improved print quality.
9 If you are not satisfied with the print quality, wipe the ink cartridge nozzles, and then print
your document again.
hope this helps.
Feb 17, 2012 | Dell 924 All-in-One InkJet Printer
Dell Photo AIO Printer 924 - Printer Busy
Might need a new printer. Lexmark printers can be troublesome.
Jul 14, 2009 | Dell 924 All-in-One InkJet Printer
Low Ink Message
Try taking it out clean the contacts with a pencil eracer and reinstal . work a try.
Your printer support site with troubling shooting link:
http://support.dell.com/support/topics/global.aspx/support/product_support/product_support_central?~ck=ln&c=us&l=en&lnki=1&s=gen
Jan 30, 2009 | Dell 924 All-in-One InkJet Printer
Wrong ink color Dell 924 printer
run a nozzle clean, perform the following steps:
  1. Verify the All-In-One Printer 924 is powered on and connected to a computer.
  2. Verify that the paper support (input tray) has clean, plain white paper loaded.
  3. Press the Menu button.
  4. Press the Down button until Mode: Maintenance appears on the LCD screen.
  5. Press the Menu button.
    The Dell 924 Maintenance Menu appears on the LCD screen.
  6. Press the Down button until Clean Cartridges appears on the LCD screen.
  7. Press the Start button.
    The AIO 924 prints the cleaning page. This process cleans the ink cartridges and resolves many print quality issues.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 25, 2008 | Dell 924 All-in-One InkJet Printer
Dell 924 all in one will not print magenta
Thanks, Joe
Nov 19, 2008 | Dell 924 All-in-One InkJet Printer
Wont print black
clean the contact on the printer and the ink cartridge. do not use paper towel. use coffee filter.
Oct 20, 2008 | Dell 924 All-in-One InkJet Printer
Problem with Dell ink jet refill....
Are you using the Dell software to replace the cartridge?
If you where just replacing without running the software then it wont know you have replaced the cartridge.
Let me know.
Zod
Apr 24, 2008 | Dell 924 All-in-One InkJet Printer
Low warning annoying me
Dell's proprietary grip on its printers causes this message to appear with any non-Dell or refilled cartridge. The messages/ink filled levels will only be reset if you buy a new Dell ink cartridge or have a way to update their encoding strip.
The good news is that you can still use refilled cartridges just minimize the level warnings to the task bar and ignore them when they come up. Everything should still print fine.
Nov 29, 2007 | Dell 924 All-in-One InkJet Printer
Low ink reading
Thats a cartridge problem. Office max, staples and office depot do not have very good dell compatibles. I've heard since lexmark makes them, they use generic ink for all dell/lexmark. take it back, and go to cartridge world. They have specific inks for dells.
May 26, 2007 | Dell 924 All-in-One InkJet Printer
Dell 946 All-In-One InkJet Printer Logo
191 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
