Question about ASUS NCT-D Dual Xeon/E7525/64Bit/FSB800/PCI-Express/ATX Motherboard (MOTAS51)
Memory upgrade I have installed the memory and the computer give me one long and 2 short beeps
  • 590 Answers
I am sure that, this is problem with your memory module only.
possible solutions:
1. Check the RAM which you installed is compactible with your motherboard.
2. Try removing and reconnecting your memory module again to your motherboard and restart you system. keep trying this for atleast 6 or 7 time. your system may become alive in any of the attempts.
3. remove dirts which present in the connecting terminals and again try.
4. try connecting the memory modules to any other system to find out any problem with your memory or not.
I hope this is helpful to you
Posted on Sep 08, 2009
3 log beeps on power on
Gigabyte doesn't list 3 long beeps as an error code, so I'm not sure if you're actually getting 3 short beeps or maybe 1 long and 2 short or... But, for reference, Gigabyte's error code list is as follows (depending on whether you have an AWARD BIOS or an AMI):
(AWARD BIOS)
1 short beep: System normal
2 short beep: CMOS Error
1 long beep and 1 short beep: Memory error
1 long beep and 2 short beep: Graphic card error
1 long beep and 3 short beep: AGP error
1 long beep and 9 short beep: Memory Error
Continuous long beep: Memory not correctly installed
Continuous short beep: Power supply unit failed
(AMI BIOS)
1 short beep: Memory Error
2 short beep: Memory parity check error.
3 short beep: Basic memory 64K address check error
4 short beep: Real Time Clock malfunction .
5 short beep: CPU error
6 short beep: Keyboard error
7 short beep: CPU interruption error
8 short beep: Graphic card error
9 short beep: Memory error
10 short beep: CMOS error
11 short beep: CPU cache memory malfunction
It might not be a lot of help, but it's somewhere to start... and at least this way you'll know what to be listening for.
Nov 30, 2013 | Gigabyte Computers & Internet
My laptop gives 3 beeps and then doent want to start up .. what can i do?
2 Short Beeps Your computer has memory problems. First check video. If video is working, you'll see an error message. If not, you have a parity error in your first 64K of memory. First check your SIMM's. Reseat them and reboot. If this doesn't do it, the memory chips may be bad. You can try switching the first and second banks memory chips. First banks are the memory banks that your CPU finds its first 64K of base memory in. You'll need to consult your manual to see which bank is first. If all your memory tests good, you probably need to buy another motherboard. 3 Short Beeps Basically the same thing as 2 beeps. Follow that diagnosis above. 4 Short Beeps Basically the same thing as 2 beeps. Follow that diagnosis above. It could also be a bad timer
Mar 08, 2013 | Computers & Internet
Ibm 8215 beep codes
Here is a list of beep codes, this may help determine the problem wit your system.
1. Keyboard
2. System Board1-4-X Error detected in first 64 KB of RAM.1. Memory Module
2. System Board2-1-1, 2-1-21. Run Setup
2. System Board2-1-X First 64 KB of RAM failed.1. Memory Module
2. System Board2-2-21. Video Adapter (if installed)
2. System Board2-2-X First 64 KB of RAM failed.1. Memory Module
2. System Board2-3-X1. Memory Module
2. System Board2-4-X1. Run Setup
2. Memory Module
3. System Board3-1-X DMA register failed.1. System Board3-2-4 Keyboard controller failed.1. System Board
2. Keyboard3-3-4 Screen initialization failed.1. Video Adapter (if installed)
2. System Board
3. Display3-4-1 Screen retrace lest detected an error.1. Video Adapter (if installed)
2. System Board
3. Display3-4-2 POST is searching for video ROM.1. Video Adapter (if installed)
2. System Board41. Video Adapter (if installed)
2. System BoardAll other beep code sequences.1. System BoardOne long and one short beep during POST. Base 640 KB memory error or shadow RAM error.1. Memory Module
2. System BoardOne long beep and two or three short beeps during POST.(Video error)1. Video Adapter (if installed)
2. System BoardThree short beeps during POST.1. See "System board memory" on page 62.
2. System BoardContinuous beep.1. System BoardRepeating short beeps.1. Keyboard stuck key?
2. Keyboard Cable
3. System Board
Nov 29, 2011 | IBM ThinkCentre M52 8215 - P4 531 3 GHz...
My hp-compaq dx2300 microtower restarts automatically when working. It is installed on win xp sp3. Please let anyone help if solution is known.
Hi names Rui, i question for you does your PC give a beeping sound when you turn it on? if does can you tell me how many beeps it gives?
if it give a designated number of beeps this might be the problem i will give you a chart so you can differentiate the warning beeps you hear.
warning beeps:
1 Short Beep DRAM refresh failure
2 Short Beep Parity circuit failure
3 Short Beep Base 64k RAM failure
4 Short Beep System time failure
5 Short Beep Process failure
6 Short Beep keyboard control gate A20 failure
7 Short Beep Virtual mode exeption failure
8 Short Beep Display memory read/write test failure
9 Short Beep ROM BIOS checksum failure
10 Short Beep CMOS shutdown read/write error
11 Short Beep Cache memory error
1 long, 3 short Beep Conventional/Extended memory failure
1 long, 8 short beep Display/Retrace test failed
hope this will determine the problem if none of this warning beep is heard try reseting the power botton in you PC cause sometimes the power botton will loosen cause of continuous use of the botton.
hope this will help you.
Jul 20, 2011 | HP Compaq dx2300 Microtower - RT950UTABA...
3 medium beeps on pc; repeating
Hi John. If you already swaped the Memory, it's the video card. I'm giving you what the beep means according to the different types of BIOS, because basically Ascent is a clone PC. I hope it helps.
(you will have to open the computer to see the BIOS type.)
BIOS AWARD
1 long beep and 2 shorts -- Video error
2 short beeps -- non-fatal error.
1 beep corto -- OK.
BIOS AMI
1 short beep -- Memory error.
2 short beeps -- ECC error.
3 short beeps -- Memory error.
4 short beeps -- change atery
5 beeps cortos -- bad processor.
6 beeps cortos -- bad keyboard.
7 beeps cortos -- video memory bad.
8 beeps cortos -- video bad.
BIOS PHOENIX
1-1-2 beeps -- Problem with cpu/motherboard.
1-1-3 beeps -- Cmos issue.
3-4-1 beeps -- Video issue.
BIOS IBM
1 short beep -- Post normal, ok!.
2 short beeps -- POST error, will show on screen.
NO beep -- CPU issue or Expansion card issue
1 long and 1 short -- motherboard error.
1 long and 2 shorts -- Video issue.
1 long and 3 shorts --EGA video issue.
3 longs -- Keyboard error.
Apr 29, 2010 | Systemax Ascent Pro A20 (988185) PC...
Upgrading from amd 3500+ cpu to 3800 duo
2 short beeps is memory parity error. Does the motheboard support dual core? Did you buy the correct socket type processor to match the mb?
Feb 19, 2010 | ASUS Computers & Internet
I am getting three short beeps while booting
The beep codes below may help you identify the possible computer problems. However,
they are only for reference purposes. The situations might differ from case to case.
gAMI BIOS Beep Codes
*Computer gives 1 short beep when system boots successfully.
*Except for beep code 8, these codes are always fatal.
1 beep Refresh failure
2 beeps Parity error
3 beeps Base 64K memory failure
4 beeps Timer not operational
5 beeps Processor error
6 beeps 8042 - gate A20 failure
7 beeps Processor exception interrupt error
8 beeps Display memory read/write failure
9 beeps ROM checksum error
10 beeps CMOS shutdown register read/write error
11 beeps Cache memory bad
g AWARD BIOS Beep Codes
1 short: System boots successfully
2 short: CMOS setting error
1 long 1 short: DRAM or M/B error
1 long 2 short: Monitor or display card error
1 long 3 short: Keyboard error
1 long 9 short: BIOS ROM error
Continuous long beeps: DRAM error
Continuous short beeps: Power error
Nov 03, 2009 | Gigabyte GA-7VKML Motherboard
Hi, i have an acer aspire 1640z i upgrade my bios from 3a18 to 3a24. after installing my notebook restart and i hear 3 beeps ( 1 long, 2 short) and my lcd doesn't turn on the motherbord work fine. Please...
1 long, 2 short beeps indicates a video error has occurred and the BIOS cannot initialize the video screen to display any additional information.
This issue can be caused by any of the below situations.
  1. New hardware conflicting with old hardware.
  2. Bad or failing hardware device.
  3. Connections not connected or connected properly.
  4. Recent electrical storm that caused a surge that damaged computer.
  5. Other hardware issue.
Disconnect the RAM from the Motherboard and turn on the computer. If the computer has a different beep code or if your computer was not beeping and is now beeping turn off your computer and try the below suggestions. Making sure to turn off the computer each time you're adding and removing the memory and then turning the computer back on to see if the suggestion resolves the issue.
Re-insert the memory into the same slot.
  1. If you have more than one stick of memory remove all but one stick of memory, try rotating through each stick.
  2. Try one stick of memory in each slot.
If you're able to get the computer to boot with one or more of the sticks of memory it's likely you're dealing with some bad memory. Try to identify which stick of memory is bad and replace it.
If you're able to get memory to work in one slot but not another slot. You're motherboard is defective you can either workaround the issue by running the memory in a different slot or replace the motherboard.
The RAM is located under the laptop behind a hidden panel.
Good luck and let me know how you get on and if you need any more help or advice.
Jul 20, 2009 | Computers & Internet
Upgraded RAM in D51C, from 256 to 2GB, got 1 short beep, 2 long
Remove all the memory, start up, it will beep. shut down, place in one memory and try starting up. IF it still beeps count the beeps short and long and let me know.
Thank you
iWillFixIT!!
Nov 15, 2008 | Compaq Evo D500 PC Desktop
Dell Dimension 8250 Memory Question
Computer Memory Information Upgrade Questions Troubleshooting Memory Diagram Upgrade Help Buying Tips · Memory definitions. MEMORY ABCs. Memory, which is commonly referred to as RAM
Installing PC computer memory Additional information and help with isntalling PC computer memory. ... Installing a PC computer memory. Question:. Installing PC computer memory.
Determining type of hardware within computer Reference, Issue / Question. Memory, Information and help with computer memory. CH000149, How to determine system resources / RAM available?
Buying tips on computer memory. How much memory should I get? This question really depends on the type of computer user you're and what type of programs you plan on running on the computer
Determining what type of memory to use in a memory upgrade. Determining what type of memory to use in a memory upgrade? Question:. Determining what type of memory to use in a memory upgrade.
E-mail CHID: 5683
Good Luck read and follow instructions will find your answer.
Good Luck, Please dont for get to Vote/Thank You.
Dec 20, 2007 | Dell Dimension 8250 PC Desktop
Computers & Internet Logo
32 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
