Question about Motorola Mobility RAZR V3
For texting there is not an option to create a message
Create email signature
  1. From the main Microsoft Outlook window, on the Tools menu, click Options, and then click the Mail Format tab.
  2. In the Compose in this message format list, click the message format that you want to use the signature with.
  3. Under Signature, click Signatures, and then click New.
  4. In the Enter a name for your new signature box, enter a name.
  5. Under Choose how to create your signature, select the option you want.
  6. Click Next.
  7. In the Signature text box, type the text you want to include in the signature.
You can also paste text to this box from another document.
  1. To change the paragraph or font format, select the text, click Font or Paragraph, and then select the options you want. These options are not available if you use plain text as your message format.
  2. To add an electronic business card - vCard - to the signature, under vCard options, select a vCard from the list, or click New vCard from Contact.
  3. Click Finish when you are done editing the new signature.
Aug 15, 2014 | Microsoft Office Outlook 2003 for PC
How do i put a signature on a pantech link
Text message signatures are the post scripts at the end of text messages. Some people use text message signatures to provide an unrelated, off-top status update to the recipients of their text messages. Other people use text message signatures to attach a favorite quote with every outgoing message. If you own Pantech's Link handset, you use the device's messaging templates to attach a signature to your text messages.
steps:
  • Press the right "-" button to access the Link's menu. Use the handset's directional pad to navigate to "Messaging" option in the menu. Press the center of the directional pad, the "OK" button, to select the "Messaging" option.
  • 2
    Select the "Templates" option from the "Messaging" menu, using the directional keypad. Select "Options" from the "Templates" menu, using the left "-" button and then select "Add New."
  • 3
    Key in your text message signature using the Link's QWERTY keypad. Select "Options" with the left "-" and then select "Save" from the "Options" menu.
  • 4
    Press the red "End" button to exit the "Templates" menu. Press the right "-" button to return to the Link's main menu. Select the "Messaging" option from the menu.
  • 5
    Select the "Create Message" option in the "Messaging" menu. Compose your message with the Link's QWERTY keypad.
  • 6
    Select the "Insert" option before sending your text message. Select the "Templates" from the "Insert" menu. Select your text signature from the list of available templates and then select the "Send" option to transmit your text message.
  • Dec 02, 2011 | Pantech Link P7040 Black Rubber Feel Hard...
    How do i switch off predictive text
    if you press # key prediction will go or create a new message go to options->dictionary ->dictionary off or again create a new message go to options->prediction options->prediction -> off ........ok.
    Oct 21, 2011 | Cell Phones
    Can you save a text template to be put on your texts every time
    Yes, it is actually called a signature. Go to your message settings and you should see signature option, select that and then add the text you want to be on your messages. But make sure that your signature is turned ON in your message settings. Hope this helps!
    Mar 28, 2010 | Samsung Propel A767 Cell Phone
    How do i create a group for group text
    you can find list option under message tab , using that first create a list , then add your contact details in that list ,while sending message you can opt to send to group or list ,so that you can send to many at same time using group text
    Jan 07, 2010 | Lands Phones
    I need help with my nokia 5610
    adding a signature feature is not available on the nokia 5610. To get around the problem you can create a blank template for SMS and use it everytime you send a message.
    1.Go to create a message, in the blank text you would create what ever you wanted to say without adding a recipient, you would then go to options, scroll down and you should see save message, after it should give you three option and pick template and you should be done
    Thanks for using fixya
    Proton
    Aug 14, 2009 | Nokia 5610 Blue Quadband 3.15MP A2DP +...
    Krzr won't stay on t9 text
    open a new text message go to "options" select "Text Setup" and change the primary text: to iTap English instead of TAP English this will fix ir :]
    Mar 07, 2009 | Motorola Mobility KRZR K1m Cellular Phone
    Change text message language in Samsung SGH-U900
    Try holding down the # key and a menu should pop up with the various typing styles. I changed mine to T9 abc and it works fine now
    Nov 14, 2008 | Samsung U900 Soul Cellular Phone
    Create personal signature and save as file
    If you are talking about using Outlook as your email client, then here is the directions for creating a signature.
    Create a signature for messages
    If Microsoft Word is your e-mail editor, see Word Help. Word offers the most customization options for signatures.
    6. Click Next.
    7. In the Signature text box, type the text you want to include in the signature. You can also paste text to this box from another document.
    8. To change the paragraph or font format, select the text, click Font or Paragraph, and then select the options you want. These options are not available if you use plain text as your message format.
    9. To add an electronic business card — vCard — to the signature, under vCard options, select a vCard from the list, or click New vCard from Contact.
    10. Click Finish when you are done editing the new signature.
    Once you've created a signature, you can insert a signature in a message
    Jun 12, 2008 | Microsoft Windows XP Home Edition
    Text messaging
    try going into create message, choose new message, choose options, choose text set up and choose TAP english under primary text. then exit, thanks.
    Feb 25, 2008 | Motorola Mobility MOTORAZR maxx V6...
    Motorola Mobility RAZR V3 Logo
    13 people viewed this question
    Top Motorola Mobility Cell Phones Experts
    Virgil Wolter
    Level 1 Expert
    vince
    Rami Obeid
    Level 1 Expert
    Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
