Question about NetGear WGR614 Wireless Router
So i have my desktop set up online, but i want to get my laptop hooked up as well and i have a router. how do i hook that up to?
  • 8,073 Answers
1.You can hook it up by a network cable from a LAN port of router to LAN port of laptop.
2. You can also use Wireless communications if router is wireless and laptop has a WIFI adapter. Turn your laptop on. Switch WIFI adapter on.
Go to Control Panel Choose classical view. Find Network connctions icon. Click on icon. Look for Wireless connection icon. Make sure it is enabled (NO RED X crossing icon.) Enable it if it is disabled: Right click connection and select Enable or repair.
If there is no WIFI connection, on theft frame Click create a new connection (The Wizard will help you.)
Once finished with this, you will have to configure the security of your network to prevent others from piggybacking on your network.
Hope it helps.
Posted on Sep 08, 2009
    President:
  • 3,278 Answers
On the right bottom corner of your screen, you should see a message/icon about wireless networks.
Select the icon and you should see a list of wireless networks. Select your network, add your password (if you set up a password) and you should be connected.
Open your browser.
Hope this helps.
3 Suggested Answers
  • 85 Answers
SOURCE: I am trying to hook up wireless router, Desktop
Login to http://192.168.1.1 from your desktop PC. This should bring your to a router logon config page.
The default login and password is usually "admin/admin" or "Administrator/Password" keep trying a few different login/password combos until you get in. "Caps/Lowercase"..etc.
Once you get in you can set the WEP/WPA security key for the router. Then apply the key you generate to your laptop.
Posted on Nov 22, 2009
redhaze89
  • 854 Answers
SOURCE: ok i have my router hooked up my laptop will
Checking IP
For Windows XP or 2000:
1. Please click on Start and select Run.
2. Type in cmd and click on OK.
3. In the Command Prompt, please type ipconfig/all then press Enter or Return key.
For Windows 9X or ME:
2. Type in winipcfg and click on OK.
3. Once the IP configuration window opens, click on the drop down box and select your Ethernet adapter (Note: Do not select dial-up adapter, VPN adapter or AOL adapters).
For Windows Vista:
1. Click on the Windows icon and on the Search box type in run.
2. At the upper left pane of the start menu, please click on run and type in cmd on the text box. Then, hit the Enter key or OK button.
3. On the black window, type in ipconfig/all and hit Enter. You should see the following:
IP address:
Subnet Mask:
Default Gateway:
DNS Servers:
For Macintosh:
1. Click on the Apple icon, select Systems and Preferences and click on Network.
2. Choose the adapter that you are using on the Show drop down list. Then, look for the following values:
IP address:
Subnet Mask:
Default Gateway:
DNS Servers:
Posted on Apr 11, 2010
I had to unhook my d-link router DIR615 from my internet and my laptop because it stopped working with my dsl and it caused my desktop to not connect to the internet I have had problems with this router...
Make sure that your computer is able to go online through the modem.
If your computer is not able to go online through the modem then you will need to call ISP first.
If your computer is able to go online through the modem then you need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Click Here for step by step by instructions
Sep 15, 2010 | D-Link (DI-784) Wireless Router
I have just hooked up a linksys wrt54g router. my laptop is connected wireless but internet is not coming through to it or the desktop connected through it? thanks
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
Click Here for more information about the routers and network
Apr 29, 2010 | Linksys Wireless-G Broadband Router
Cant get it to hook up right for some reason?
1.Connect modem to the one separate port of the router on which you would see Internet, Wan or Lan. 2. Connect one of the Four port of the router to the laptop or desktop. 3.Insert the disk that came with the router into the laptop drive and install it. 4. Turn on the wireless services on the laptop by hitting the wireless button the laptop. 5. Now, connect to the available wireless networks.
Apr 15, 2010 | Linksys WRT160N Wireless Router
What do i need to hook up wireless -g 2.4 ghz
I believe the laptop is wireless.
You will need to check the wireless settings of the router.
If your router is already set up and other computers are able to go online using the router then you don't need to change anything on router, you will need to connect to the network only.
Click here for step by step instructions
Mar 15, 2010 | Linksys Wireless-G Broadband Router
Running install disc, says does not support operating system
Are you trying to set up router ?
You can set up your router manually, without the CD.
Mar 03, 2010 | NetGear WGR614 Wireless Router
I have a linksys Wireles-G broadband router 2.4 GHz that i am trying to hook up to a desktop to allow wireless access for a laptop and I cannot get it to log onto the internet. Why?
Then you need to connect the computer to the router and the modem to the router.
Feb 21, 2010 | Linksys Wireless-G Broadband Router
How do hook up a wireless laptop to a router and
Are you trying to install the router.
You can do it manually without the CD.
Then you need to connect the computer to the router ad the modem to the router.
Feb 04, 2010 | Belkin Computers & Internet
Router setup
Jan 28, 2010 | NetGear WGR614 Wireless Router
My router is hooked up correctly on my desktop and my laptop shows it is connected with a strong signal, but I still cannot get online, any suggestions
If you can't get online on either machine, plug your ethernet cable directly from your cable or dsl modem into your desktop. If it shows a network connection and you still can't get online, it may be a service provider problem. I am assuming that your service provider did not ship you a router, only a modem. Hooking up 2 routers on the same connection can be very tricky.
Jul 30, 2009 | Trendware TRENDnet 4-port Switch - 54 Mbps...
Setting up printer on home network
Because your printer is not either wireless or network capable, the only way to get the results you need is to purchase a usb print server, hook it to your router, set it up through it's management console, and if your router is wireless, you can hook up to your router and print to your printer with your desktop turned on or off.
Apr 13, 2009 | Computers & Internet
NetGear WGR614 Wireless Router Logo
83 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
