Question about Bosch Saws
How I change the blades in the Rs 15 saw machine bosch
  • David Ford
    David Ford May 11, 2010
    Could you please be more specific on the model number, I am having trouble finding that one. Let me know
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 141 Answers
To lock a blade in just push the blade in until you hear it click. This is what engages the blade. To disengage just turn the blade clamp until the blade pops out. This will lock it open until you insert a new blade.
Posted on Sep 12, 2009
Does any one out there know how to put a blade in a Bosch 1581VS jig saw?
video here
How to Replace a Bosch Jigsaw Blade - YouTube
? 1:30
https://www.youtube.com/watch?v=YzpExustLD0
Sep 8, 2011 - Uploaded by toolsandmachinery
Mike will show you the simplicity of changing a blade with the Bosch twist-lock Jigsaw
here is the manual for the 1584
Bosch 1584VS Manuals
Apr 19, 2017 | Bosch Saws
How do i change the blade on a Bosch PFZ550E reciprocating saw? note it is completely different to the 500.
There is only an allenkey necessary( its most inside the machine tucked away ) partnr 37 until part 36 become some loose very simple principle.
Oct 06, 2016 | Bosch Saws
How do i remove a broken blade in the bosch rs 325
Open the chuck and try gripping the bit of broken blade with some tweezers or flick it out with a small screwdriver.
Nov 30, 2012 | Bosch RS325 Compact Demolition...
Bosch b4300 jigsaw blade replacement
To change the Bosch B4300 blade - If the grey knob does not turn to release the broken blade, you need to use a LONG THIN flathead screwdriver down the center hole at the top. Unscrew until the broken blade is loose. Pull out. Replace the new blade and then screw the it tight through the same hole at the top. DONE.
Jan 25, 2012 | Bosch 1581AVSK Top Handle Jig Saw Kit
My 10" Bosch miter saw
I would remove the blade and try the saw again, there is a possibility that you might have gotten a flange on incorrectly or left the spacer out.
Sep 10, 2011 | Bosch 10" Slide Miter Saw
How the h... do i cabnge the blade on the bosch 1582 cutter ??
I am assuming you are asking because you have a CLIC system.
Bosch uses a tool-less blade changing system for its jigsaws that it calls "Clic." The system makes changing blades fast and simple. With the simple blade changing you get with the Bosch jigsaws, it is no problem to change out a dull blade.
REMEMBER: SAFETY FIRST LAST AND ALWAYS!!!
Make sure the saw is unplugged or the battery is removed.
If you have a blade in there:
Hold the saw over a work bench and push the ejector lever to the center of the front of the saw. There is a center stop; you will feel it. The blade will eject and fall out
Insert the new saw blade into the plunger until it latches into place. The teeth should face toward the front of the saw. The back of the blade should rest in the groove of the guide roller. The plunger and the guide roller are between the body of the saw and the plate
If the blade will not go into the plunger, check the positioning of the slots in the blade. They should be at the top. Push the ejector lever and try again.
Give the blade a yank to check that it is firmly seated. Plug the saw back in or replace the battery and proceed with the cut
Use protective gloves when handling blades. They can be sharp and can be HOT.
I hope this helps
Please rate FIXYA
Thanks
Charly
May 20, 2011 | Garden
Bosch 4000 table saw run backward and slowly
I had the same problem with the Bosch 4000.
Changed the field for a new one...end of problem
Apr 28, 2011 | Bosch 4000 - 07 Electric Table Saws
How do I change the blades on a Bosch PST 2000 jigsaw
I couldn't find that specific model number Bosch saw, but here is the link to get user manuals from Bosch in case you mistyped it. (It's a long link that wouldn't all fit here, so I had to put a carriage return in it)
http://www.boschtools.com/Service/ProductServices/Pages/ManualsandPartsDefault.aspx
Or they may have a similar saw under a new model number. Here's the current model number of a very popular saw that has a less-than-obvious blade changing method 1587avsk
Mar 05, 2010 | Bosch Saws
Locking device will not reset and lock blade in holder on a Bosch RS 15 Saw. .The locking device is up against the pin and will not rotate.
try using compressed air to blow out the area and then some WD-40 to loosen it up. They sell the holder as an assembly, You can go to Boschtools.com and download a breakdown for this tool. It is usually some debris or rust that makes them stick.
Oct 06, 2009 | Bosch RS15 1 1/4 Reciprocating Saw
I have a bosch jigsaw I purchased at auction.I can't figure out how to change the blade
There are two types of "quick release" mechanisms on the new Bosch jigsaws, the twist-top handle found on 1587 models, and the lower-lever found on the 1590's.
The "twist-top" is the black cap on the 1587 at the front of the saw. You must first put the orbiting control ( on the side of the saw ) to position number III. This releases pressure on the blade. Then you lift the black cap, rotate three or more turns counter-clockwise ( as seen from the top ) to release the locking mechanism. If the saw blade is cool, you can carefully remove it with a single one-quarter turn using your fingers. If the blade is still hot from sawing, use a pair of pliers, but be gentle. Hot blades can bend easily and jam.
The 1590 models are quite a bit easier. You still want to put the orbit control to position III to release pressure. But the quick-release is a simple flick of the black switch on the front face of the saw.
I still have my 30 year old Bosch with the screw-in blade holder. It still works and the saw still runs smooth as a sewing machine. If you are doing a lot of production work where you need to change blades frequently, the Bosch 1590 is the clear choice for quality and value. In thirty years of using Bosch tools, I have only had to do normal maintenance and had only one minor failure, which was the blade changing mechanism on the 1587 model. I broke it by tightening too far. SO, if you have a 1587 model, DO NOT OVER TIGHTEN. As it is, this non-warrantee repair only cost $16 bucks and took two days.
It should go without saying, but just to be safe I'll say it anyway... OBVIOUSLY, you should UNPLUG the tool when you are changing blades. Good luck!
Aug 03, 2008 | Computers & Internet
Saws Logo
109 people viewed this question
Top Bosch Saws Experts
Parson's Repair...
Parson's Repair...
Jim London
Jim London
Are you a Bosch Saw Expert? Answer questions, earn points and help others
