Question about RCA OPAL M4001 MP3 Player
Mp3 player has no more memory and shuts down.How do I erase existing memory to start over?
  • 496 Answers
Try reflashing the firmware for your device you can find the latest firmware and flashing utilitys from the manufacturers website
Posted on Oct 05, 2009
As mp3 player
An MP3 player is a solid piece of memory and an interface with a small amplifier. As such it is prone to fail after a while. You can try connecting it to a computer and see if you can format it or use a program like recuva to attempt to resuscitate it. However all may be lost.
Dec 05, 2017 | Audio Players & Recorders
Sandisk Sansa c200 displays "Memory full, free some memory" and doesn't function
Player needs to be reformatted - checked my "tips and tricks" on Reformatting
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
May 27, 2008 | SanDisk Sansa c200 MP3 Player
Memory troubles
-Tha Mp3 Doctor
May 26, 2008 | SanDisk Sansa e250 MP3 Player
Lost Memory
You will need to reformat the GoGear in Windows Media Player, but do a firmware upgrade first - open the Philips Device Manager and click on the Update tab. Then click the update button. After the firmware upgrade is done, open windows Media Player.
REFORMAT FOR WINDOWS MEDIA PLAYER - Erases Everything: Connect your GoGear to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Philips Go Gear SAXXX" (wording may vary slightly), and then select "Format." - this should erase everything, and make your player properly read in Windows Media Player.
-Tha Mp3 Doctor
Apr 05, 2008 | Philips GOGEAR SA6045 MP3 Player
Won't Install
1) Disconnect from computer, turn it off, hold in volume + button and reconnect it to your computer - continue holding volume + until the Found Hardware Wizard comes up.
2)
REFORMAT FOR WINDOWS MEDIA PLAYER - Erases Everything: Connect your iLo player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "ILO 2GB" (wording may vary slightly), and then select "Format." - this should erase everything, and give you a fresh start.
Mar 05, 2008 | iLO (2 GB) MP3 Player
Built-in memory
-Tha Mp3 Doctor
Nov 10, 2007 | SanDisk Sansa e250 MP3 Player
Recording
Not sure what you mean by "Windows media" . Are you trying to erase items on your player because the memory is full? If so press and hold your toggle switch until the menu shows, toggle down to "Settings" and press it once, then toggle down to "Delete File" and then toggle to the file you want to erase, select it and then toggle to "OK" to delete. Not sure if this helps. To clear everything and start over you can also toggle to settings,system,format and reformat the memory.
Oct 18, 2007 | Samsung Yepp YP-T7JX MP3 Player
Help
RCA TH1100 Series:
The following procedures will erase all songs on the player.
Check if the file system is NTFS. If yes ,format it to FAT or FAT32. - Connect player to computer, click my computer, right click on icon of mp3 player and select format.
You can also format the player in Windows Media Player tiself.
Connect your Mp3 player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "name of Mp3 player here 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
You may also want to check
http://support.rcaaudiovideo.com/downloads.aspx?product=25
for any firm updates - the above procedures in some cases undo the original formatting on the player, and a firmware upgrade will be required to replace the Mp3 player's formatting.
-Tha Mp3 Doctor
Oct 13, 2007 | RCA TH1101 MP3 Player
Freezing mp3
This may be the mp3 player that is wired badly. However, you may taking the battery or disconnecting it from its power for 10-30 seconds. Also, power down the computer1.gif and wait for 10 seconds -30 depending on the amount of times the computer has been shut down for the week. Try downloading its driver so that the computer will recognize this hardware1.gif.
May 25, 2007 | RCA M1001GB (1GB) MP3 Player
RCA OPAL M4001 MP3 Player Logo
35 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
