Question about Hotpoint Aquarius WMA42 Front Load Washer
Machine drum full of water - Hotpoint Aquarius WMA42 Front Load Washer
  • 139 Answers
Blocked filter or pump,, access from the rear of the machine from a small panel at the bottom.
pleae rate if this help
wash doctor .
Posted on Sep 09, 2009
Fisher and Paykel washing machine Aquasmart during cleaning cycle alarm indicating fault code 12 - drum full of water
If the drum is full of water your drain pump is not functioning correctly. Could be a bad pump but more likely it is a clogged drain hose (hose between tub and drain pump) or filter basket on the pump if it has one.
Jan 11, 2013 | Washing Machines
Mav4757aww leaks water during spin cycle with full loads only
Thanks for the quick responses.Pulled front cover,ran a load on high level, no leaks .Ran a load on super level and when drum spins when full of water water level rose and poured out of left front side on top of drum. Pulled plastic ring on top of drum and and found piece of seal missing where leak occured .Ordered upper tub seal, should solve problem
Jul 27, 2012 | Maytag Ensignia MAV4757AWW Top Load Washer
Spin cycle does not fully spin out water
The drum might be too full and thus too heavy to spin out all of the water. Many machines have a system like this to stop the drum coming off. Take out some of the load and try again.
Feb 03, 2010 | Washing Machines
Water accumulated in drum while machine off and door open.
The water valve may not have closed completely or may be leaking. You can copy and paste this link in your address bar for more great repair info and feel free to ask any other quesitons:
http://home.howstuffworks.com/how-to-repair-a-washing-machine3.htm
Oct 14, 2009 | Kenmore Elite 45986 Front Load Washer
Hotpoint aquarius wma58 1400. Full of washinh. Full of water.
pull your washer out. put near door if poss then put the waste pipe down to floor level to empty the water. if there is to much water in the drum it will not spin try your pump
Jun 21, 2009 | Washing Machines
WASHER DRUM IS FULL OF WATER
check water filter first,then pump
Feb 16, 2009 | Maytag Washing Machines
Kenmore:Noise; agitator not working; drum full of water...HELP!
Sounds like you have a broken motor coupler, check the tutorial at www.shop.washermd.com dave
Jan 12, 2009 | Kenmore 15944 Top Load Washer
Hotpoint WF321 during rinse and spin, will not go into full spin as machine keeps filling with water.
you should check your pressure switch hose for a pin hole or better still just replace the hose and it should sort your problem out good luck hamstel
Nov 05, 2008 | Washing Machines
Washing Machine Hoover H100M fills too much water in the drum.
this is 1 of 2 solutions  2 this problem the first thing to check is the vacuum system or it is a split in the pressure switch hose
Mar 05, 2008 | Hoover AAA140 Front Load Washer
Hotpoint Aquarius WMA42 Front Load Washer Logo
67 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
