Question about HP Pavilion dv6775us Notebook
Right click does not work
Right click/context menus do not work.
    Novelist:
  • 110 Answers
Probably have a bad mouse button on your palmrest. Try using an external mouse... does it right-click? If it works fine then you have a bad mouse button and will probably need a new palmrest to fix it.
If it still fails to right click with another mouse, then it is just a software setting in your PC, check your settings in control panel in the mouse options.
Good Luck.
Posted on Sep 08, 2009
How do you cancel print jobs in Windows 7?
1. Click Start, Devices and Printers
2. Right-click the printer whose job you want to cancel, and select See what's printing from the context menu.
3. The print queue will pop up. Right-click the runaway print job, and then click Cancel from the context menu.
hope this helps
Apr 14, 2014 | Dell Computers & Internet
Tip
How to Enable Right Click on Desktop-Fixed
If you are having troubles with the context menu (right click menu), right clicking on the desktop doesnot do anything then most probably you have your group policies set to not displaying the context menu in windows explorer. You can change it in two ways. One from the group policy editor and one from the registry editor.
1- From Group Policy Editor
To re-enable your context menu from the group policy editor, go to Run –> gpedit.msc –> User Configuration –> Administrative Templates –> Windows Components –> Windows Explorer. In the right hand pane, find “Windows Explorer’s default context menu”, open its properties by double clicking it. If it’s enabled or not configured, disable it and your context menu will be back as soon as you apply this policy.
2 – From Registry Editor
To re-enable your context menu from the registry, go to Run –> regedit –> HKEY_CURRENT_USER –> Software –> Microsoft –> Windows –> CurrentVersion –> Policies –> Explorer. In the right hand pane find “NoViewContextMenu”, set its value to 0 if it exists. If you still can’t right click your desktop, then you can look for the same key here: HKEY_LOCAL_MACHINE –> Software –> Microsoft –> Windows –> CurrentVersion –> Policies –> Explorer
on Dec 02, 2009 | Computers & Internet
How to unlock desktop icons windows 7
Have you installed any soft prior to your problem?
This problem may occur if you disable the Remote Procedure Call (RPC) service.
Many Windows operating system procedures depend on the RPC service.
http://support.microsoft.com/default.aspx?scid=kb;en-us;830071
Try This. Right click on the Start button and click on
Properties.
. Click on the Start Menu button.
. Click on Customize
.Check Enable Context Menus and dragging and dropping
Did you downloaded Refresh PC (first answer link) and run it?
Aug 04, 2012 | HP Computers & Internet
Right click doesn't work
Right click opens a context menu. That can be stopped by Group Policies from a work computer or any business computer. I cant remember how to resolve the issue, but look up explorer context menu registry keys and a solution should be out there. Explore is basically windows!
Thanks
Http://simontodd.com
Mar 11, 2010 | Microsoft Standard Wireless Optical Mouse
When i right click on any folder the particular window freezes saying not responding for atleast 5 min but i can access all other application or icons from desk top. im using win xp sp3
This issue is usually due to a bad context menu handler. When you right click on an object the context menu is called and any installed handler objects are called also. If one of the these additional objects are broken or missing, it slows the whole process to a crawl.
There is a utility that will allow you to see what context menu handlers are installed and it will also allow you to disable the individual context menu handler components.
As there are potentially numerous items, there can be a lot of choices. In my professional experience, if you have an older version of Office installed (Office 2000, Office XP, or Office 2003) sometimes the Microsoft Picture Manager can break the context menu.
Also look for any context objects that reference a tool but display "File Not Found" under the "Filename" column of the utility, as the operating system is trying to load something that is not there to load.
The utility is called ShellExView, it is created by NirSoft and can be found here at http://www.nirsoft.net/utils/shexview.html
Feb 24, 2010 | Microsoft Computers & Internet
HOW,DO I RESTORE MY TOOLS VIEW FILE HELP BUTTONS
You don't write in which application did your menu bar disappear.
Perhaps you entered "full screen mode", which removes menus and stuff to maximize the viewing area. Depending on application, try F11 key on the keyboard or F9.
If this is not the case, then perhaps you have accidentally dragged the menu bar somewhere - in new applications the standard "File/Edit/View...." menu is movable.
In Internet Explorer you might have turned the menu off by accident. Right-click the menu area, and you will see a context menu, showing a list of bars/strips that are enabled (with a checkmark) or disabled (without). If you see something else, choose a slightly different spot to right-click. If the option "Menu bar" is not checked, just click it and the menu should appear.
Nov 18, 2009 | Audio Players & Recorders
The left mouse button on my Studio 1535 no longer works. The right one is fine. Can I fix it or do I need to replace the whole assembly?
Try to configure it as a mouse for left handed persons and see if it responds to your clicks.
In any case you should go to Control Panel, Mouse Properties. By pressing a button, the picture on the screen should show you if it is activated. If it does not then there nay be some hardware problem.
If you do not need the Context menus (right click) try setting the right button as the one to perform the usual click.
But nothing beats a new fancy mouse.
Hope this gives you so solutions.
Aug 28, 2009 | Dell F3534 Touchpad
ALPS POINTER DEVICE
the left button is used to "Select" or "Execute" while the right button displays the "Context Menus" like copy and paste
Jul 27, 2009 | Compaq Presario 700 470024-192 Notebook
Context menu continually pops up - mostly when left mouse button is clicked sometimes when keyboard is used. Context menu key doesn't work.
I think the mouse setting is set to left handed and the right clicker is the main clicker and the left is the context menu key. Knowing this, you should follow these steps.
1. Go to "Control Panel"
2. Click "Printers and Other Hardware"
3. Click "Mouse"
4. Go to the "Buttons" tab and switch the setting to right handed
Jan 31, 2009 | Compaq Presario Notebook
Desktop Right Click Problem
This is generally an error from the registry, namely the context menu handlers (which is a shell extension handler that adds commands to context menus) If you can isolate when it started to occur and then maybe you can link it to a program you installed.
Are you having any having any other problems with your system emptying the bin, media apps??
I can suggest a progam that you can download that will allow you to see what extensions are in use and hopefully from this you will see if there are any left over commands from bad unistalls
Jul 10, 2008 | Dell XPS 200 PC Desktop
HP Pavilion dv6775us Notebook Logo
239 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
