Question about Belkin Computers & Internet
I can not remember my password so other devices can be used at my home
  • 497 Answers
You can reset all the setting including password by Resetting the Router.
To reset the Router, press the reset button with a sharp pointed object located at behind of the Router near wireless Antenna or Aerial.
Good Luck!!!!!!!!!!!!!!!!!!!!!!!!
Posted on Sep 08, 2009
My device has stopped working. I can't get on wifi -- don't remember my password.
Passwords are case sensitive. Modem passwords are usually strong and a mix of uppercase, lower case and numbers. Make sure they are as shown. It is often better to get someone to read them out to you.
Failing that, find the reset button on the back of the modem, reset it and then set up a new password using your computer. Print off the password and stick it to the back of the modem after removing the old passwords. Remember that you will have to change the password on all your devices. You could also check that the modem options on the computer show you the password in text rather than dots or asterisks.
Jun 09, 2015 | Amazon Kindle Fire HD
I have a Kocaso M736 and I can't remember my password to get it started again.
Cant. Have to factory restore it. This is done by holding home button, power button and volume up button at the same time while device is off. Operate with volume keys and power button for select. Back up everything on
Jul 24, 2014 | Kocaso BRAND NEW M736 7" High Resolution...
Reset vigo android
This works with devices having physical home button:-
1. Press the power button and the home button together for a while, long enough until the screen appears with Android bot and a progress bar which shows that it's formatting the internal memory.
With NO physical HOME button:-
2. In case your device does not have a physical home button, press the power button and both the volume keys together for few seconds.
3. Press gently the "reset pin-hole" present generally on a side of Tablet. Use a clip-pin or similarly fine thing to gently push inside to reset your device to factory settings.
or you can Check my blog how to reset your tablet lol,
http://pcgadgetdeni.blogspot.com/2013/02/forgot-passwordpattern-unlock-of.html
Feb 18, 2013 | Android Flytouch 3 8gb 10.1 Inch Super Pad...
If my ipod says disabled and i have charged it how can i fix it? and how do i reset my password I have an ipod touch and cannot remember the last password I used
you are going to need a computer with the latest version of iTunes on it and unfortunately this fully race all data on the device
So with the device plugged into your PC, iTunes open, if it shows up in iTunes eject it, or cancel the prompt to restore a device in recovery mode.
Hold down the Power button for 3 seconds
Without releasing the power button, also hold the Home button for 10 seconds
Without releasing the home button, release the power button and keep holding the Home button for About 20 seconds.
iTunes will detect an iPod in recovery mode, let off button and set down device and hit RESTORE in iTunes.
Hope this helps!
Sep 20, 2011 | Apple iPod touch
I want to close down my Facebook account, but can't remember my password. Actually I donj't even remember making a password.
Hello, for a facebook account, there must be a password on the account for it to be active. If you remember the email address you used to make the account you can attempt to reset the password. Click on the forgot password link on facebook's home page right near where you sign in.
Thanks for using FixYa!
Aug 08, 2011 | Computers & Internet
I have zoom on my home pc and now I would like to add my ipad to use the zoom network, but I can't add it since I don't remember my password. Can you help me?
you should try reset to factory settings, may be you should look behind your zoom device, there is small hole or something that have words "RESET". All password will be empty, but you should reconfigure for your zoom device
May 10, 2011 | Zoom X6 Adsl Wireless Gateway Rohs Router
How do i connect my wireless d-link to my internet?
Using a LAN cable connect the router to your internet modem. Usually use LAN port 1 on each unless indicated otherwise.
Login in using your browser and go to the wireless settings and set-up a wireless password/key. Remember the key because each device will now need it to connect. You can also turn OFF Broadcast SSID and your network name will not be shown on anyone's device. You must remember the network name when using this method.
The using the setup wizard, configure your WAN according to the requirements of you modem PPPoE, Dynamic, etc. In some case the router will sense the correct set-up.
Feb 07, 2011 | D-Link DIR601 WirelessN 150 Home Router...
I want to put a second computer on my 2 wire network. It has the wireless device install.
you need to set up a home network. You did not say which OS you are using but the network wizard will guide you through the process. remember to password protect and keep the password simple so you will remember it.
Dec 30, 2009 | Dell Computers & Internet
I have nokia 5610 xpress music , today i did restore factory settings of handset and fount out that my mmc card has been locked automatically, i did try the default 12345 as password but it did not work......
If you forget your memory card password, there is nothing either you or a service point can do. It is not possible to read the password from the memory card or from the device. Passwords cannot be disabled.
When you lock your memory card with a password, your device will remember it. Therefore, the device does not have to ask for the password every time you access the memory card. However, when you insert your memory card to another Nokia device, you are asked to re-enter the password. The password is asked because the memory card remembers the password protection settings, including the password.
Note: After you reflash your Nokia device and re-insert the memory card, you are asked to re-enter the password, as it has been erased from the device during the flashing process. You have to re-enter the password to get access to the memory card, and after that the device will remember the password again for future use.
If you have forgotten the password but you still want to try to use the memory card, try formatting it. If the formatting process is successful, the memory card is usable but all data on the memory card is erased.
To avoid unnecessary risks, write down your password somewhere and backup your memory card data regularly.
Jun 20, 2009 | Nokia Cell Phones
Computers & Internet Logo
60 people viewed this question
Top Belkin Computers & Internet Experts
Prashant M
Prashant M
Are you a Belkin Computer and Internet Expert? Answer questions, earn points and help others
