Question about Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer - Blue
Time it takes to dry ,Then we had fire !
We had same problem with dryer taking to long , samsung sent out someone to repair , he told us the venting system was wong (was use ok for the last 25 years ! ) so we change it as they told us to and we had a dryer fire , after many emails and hours on the phone , the results are I'm buying another one after 14 months . Lowe's was not much of a help either .
  • 1,531 Answers
The venting that the dryer hooks up to and leads out of your home does have alot to do with the proper operation of the machine if the ducting is blocked or restricted this will cause the dryer to take longer to dry the clothes.I do not understand why you had a dryer fire and am sorry to here that.also make sure the dryer is not pushed back to far against the wall and the flexable ducting is not to long and kinked in any way. good luck i hope this helped
Posted on Sep 19, 2009
GE Dryer DBSR453Eb2WW takes twice as long to dry clothes
A clogged or partially clogged vent will reduce the air flow through the dryer and greatly increase the drying time. I assume you checked the drying time again after you cleaned the vents. Have you also checked that the lint trap is clean? Make sure no lint has found it's way around the lint trap and has jammed the intake.
I would be very suspicious of the 240 v breaker double breaker feeding the dyrer; maybe the dryer is only running on 120 vac instead of the full 240vac. The motor would be getting full power, but the heating element would only be getting half power.
Mar 26, 2013 | Dryers
My Dryer not that old, takes all day to dry a small load.
Check the following areas thoroughly to address this issue.
1. Venting
Make sure the dryer vent hose, as well as the rest of the vent duct, is not clogged.
Unless regular maintenance is performed, chances are there is a lot of lint accumulated inside the dryer. This might affect the drying time and could be a fire hazard. Make sure to have your dryer cleaned regularly. Because this might involve taking most of the dryer apart, it is recommended to have a qualified appliance repairman perform this task.
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat.
3. Heating element
A heating element might only be partially burned out, in which case it would still work but will take longer time to dry the clothes. Replace the element if found defective.
Aug 31, 2009 | Whirlpool LER5636P Electric Dryer
Taken to long to dry
IF ELECTRIC
1. Venting
2. Thermostat
3. Heating element
IF GAS
HI, Check the following to address this issue further.
Note: Normal drying time for a dryer is about 45 minutes (some may take up to an hour).
1. Venting
2. Thermostat
There are a couple of cycling thermostats inside the dryer. If one of them breaks down, it might affect the dryer's performance. Replace the defective thermostat. These thermostats are located in the dryer vent duct and sometimes mounted on the blower assembly as well.
Aug 21, 2009 | LG Dryers
Dryer is not working in normal time it us too take to dry now it takes three times the amount of time. was purchased in 9/1999 new whirlpool supreme 7cycle.4temp
Check the following to address this issue.
1. Venting
2. Thermostat
Jun 24, 2009 | Whirlpool Dryers
Does not completely dry clothes in the time it used to
For Electric Dryers, check the following---
1. Venting
2. Thermostat
3. Heating element
For Gas Dryer, Check the following---
1. Venting
2. Thermostat
Jun 01, 2009 | Maytag Dryers
Gas dryer not drying clothes
Hi, Dryers are simple machines to fix yourself so the main reasons dryers do not dry cloths is listed below.
1. Make sure the vent is clear from obstruction of lint built up by taking off vent and make sure the vent flap is opening when dryer is on, beware most house fires are caused by neglect of dryer vent!
2. People allot of times overload machine which causes cloths not to dry.
3. Electrical Repair Needed: one of the thermostats in the dryer are defective
May 02, 2009 | Dryers
Will not dry clothes fully. the machine heats fine but it takes two or more cycles to fully dry a little load. someone told me about a part that may need repaced around the lint trap.. Any ideas?
Your lint exhaust is blocking the heat flow.
Remove the vent from the rear of the dryer and run a timed cycle load for 40 minutes.
If laundry is dry, repair the outside vent.
If not dry,open the dryer cabinet and clean the inside lint and heat vent.
Mar 05, 2009 | Kenmore Dryers
I am currently having a problem with my Kenmore Dryer. It is running but it is not heating up to dry the clothes. Someone told me to take the back off and check the heating element but I can't find the...
I would check your vent if I were you disconnect the vent and run the dryer to see if it works better. also clear the vent line. good luck
Jan 10, 2009 | Dryers
Takes a very long time to dry a load
95% chance the vent is clogged.
When te vent and /or pipe is clogged, the moist air has nowhere to go and it will take longer to dry. Clogged vents/pipes are also a fire hazzard.
Find where the vent exits the home, and look inside. They often get clogged with lint, birds nests etc. There should be a flap or grid to prevent entry of birds and other critters, but they often break off.
Cloggs can also occur at the dryer where the vent exits the dryer.
IF THE VENT PIPE IS PLASTIC you should replace it with a metal vent. Flexible is OK in most areas, but it should be metal.
The plastic pipes have been deemed a fire hazard in many areas.
Check your local codes to be sure of your requirements
Dec 04, 2008 | Dryers
Samsung 7.3 Cu. Ft. 9-Cycle Electric Dryer - Blue Logo
568 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
