Question about Brother IntelliFax-2820 Laser Fax
Brother intellifax 2820 keeps melting the fuser rollers together. replaced with spare fuser i had at shop here. still melted rollers together
    President:
  • 1,126 Answers
Is the triac that controls on/off times of fuser lamp located on a pcb or by itself? I would wager that it is shorted to the always on condition.
Posted on Sep 08, 2009
Paper comes out folded & has started jamming
Clean or chnage the fuser roller and the exit parts rollers.
Dec 10, 2009 | Brother IntelliFax-2820 Laser Fax
2 areas of black smears down the center and to the right of cente
Can you see into the fuser area. That is where the toner is heated and fused to the paper. I think their is a rear door for checking this. If the toner is melted to the teflon roller then it will have to be replaced.
Jun 22, 2009 | Brother IntelliFax-2820 Laser Fax
Paper getting stuck in the rear of Brother 2820 fax machine...
Hi, There are many reasons for jams in the exit of machines and I will list the most common for you damp paper will curl as soon as it hits the fuser rollers... the fix - change paper the fuser rollers are worn (teflon coating is no longer able to deflect toner) and jams are occurring.... the fix - replace the fuser unit
Jun 09, 2009 | Brother IntelliFax-2820 Laser Fax
Fuser melting the roller and "fail to warm up" error
you could will hae a defective thermistor. Check it out
Jun 01, 2009 | Brother IntelliFax-2820 Laser Fax
Fuser error
Only by repairing / replacing the fuser (costly)
May 19, 2009 | Brother IntelliFax-2820 Laser Fax
We havet he brother inteli fax 2820. teh paper keeps jamming when it is tryong to feed through. We replaced the drum and we are still having the problem. IT wont feed any paper through without jamming
IF YOU ARE HANDY, WHEN YOU OPEN THE FRONT COVER YOU WILL SEE THE FUSER SECTION IT SAYS VERY HOT ON THE COVER IT COMES OUT WITH 2 SCREWS THERE MAY BE PAPER IN SIDE HOLDING DOWN A SENSOR. GOOD LUCK BROTHER SR TECH
Feb 03, 2009 | Brother IntelliFax-2820 Laser Fax
I need to replace the fuser on Intellifax 2820.
Check out this link http://www.google.com/products?q=fuser+on+Intellifax+2820.&ie=UTF-8&oe=utf-8&rls=org.mozilla:en-US:official&client=firefox-a&um=1
Apr 19, 2008 | Brother IntelliFax-2820 Laser Fax
Very poor printing
If the prints are light or have white lines it will be related to the laser unit. There is a strip of glass that sits above the drum inside the machine. Clean it. If there is toner on it will cause this problem. Otherwise the laser unit has failed.
If you have dark marks, blotches or reprinting (part of the image repeating lighter down the page). It will be build up on the fuser rollers. Remove the drum/toner and look at the rollers behind, they will look dirty. The only way to resolve this is to replace the fuser unit as it is worn out.
The only other possibility is that the drum contact on the sides of the machine are deformed or out of position. Its hard to tell and fairly unlikely in this model.
Apr 17, 2008 | Brother IntelliFax-2820 Laser Fax
Failure to Warm Up
Failure to warm would suggest the fuser unit is failing and the machine is failing to reach the temperature that toner melts and fuses to the paper. The machine should display error 76 or 77.
Try this ONCE only!! till the after 99 bit. Hit menu, *,2,8,6,4 quickly if all the button flash and maintenance is displayed enter 99. Now if the error reoccurs you need to replace your fuser unit as it failed as opposed to just malfunctioned.
It will melt if there is a problem and you keep repeating this process. So please only once. If it takes you a few goes to get into maintenance modes its ok but the reset of 99 do only once.
Mar 02, 2008 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFax-2820 Laser Fax Logo
128 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
