Question about Baumatic 23 in. BDW13 Built-in Dishwasher
Looking for reset switch
Looking for the reset switch on the baumatic bdw 3w
the water is not heating and i want to give it a reset before
i try a new element
have taken the foot plate off and there is a fuse but no sign of a reset swithc , can anyone help ..
ta d
    Problem Solver:
  • 5 Answers
If your getting `E3` then it cannot be reset, one of the two thermostats on the heater element cannot be reset and has to be replaced, around £18, you can test which one of the thermostats is faulty by using an `ohms` tester, open circuit, faulty, this is a very common problem with these.
Posted on Oct 15, 2009
Hi, I have error message 20 on BDW14 Baumatic. Dishwasher won't start. What does it mean? Thank you..
Error 20 is not a listed error in Baumatic dishwasher. They only mention E1 to E7.
There is a reset procedure for random errors which can be viewed at this page.
http://www.ukwhitegoods.co.uk/help/fault-codes/dishwasher-fault-codes/3305-baumatic-bdw-dishwasher-fault-codes.html
Please check if this helps.
Apr 25, 2014 | Baumatic Dishwashers
My Baumatic B484SS oven started to trip my distribution board. I reset the board and after a few minutes it would trip again. It is now not working at all. I have had an electrician round to look at it and...
Switch off the mains then examine the cable to main switch to see if there is a loose connection.These ovens are usually on the 30 amp fuse.If that looks okay ...you may have an internal wire than is touching the chassis...most internal wires are shielded with heat resistant material ...it may be that one has melted or burnt through and is now shorting on the metal chassis.Look for evidence of burnt areas.finally check the switches...these get oil and water ingress which again will short out the circuit and trip the main board.hope this gives you a starting point and solution.
Dec 16, 2017 | Baumatic B484SS Stainless Steel Electric...
I have Baumatic BDW 3W Dishwasher The programming controller stops rotating automatically at certain points in the revolution. can you advise please.
I have Baumatic BDW 2W Dishwasher The programming controller stops rotating after the first normal cycle revolution. can you advise please.
Aug 24, 2010 | Baumatic 23 in. BDW3 Built-in Dishwasher
Right hand side nylon spring cord guide broken when cord snapped and now door return has no tension.
Searched for a nylon rope guide for a Baumatic BDW 9 but was unable to locate one. I found that many of the components for the BDW 9 also fitted the BDW 10. So I searched for the rope guide for a BDW 10 and found the correct product. Problem solved!
Nov 15, 2009 | Baumatic 23 in. BDW9 Built-in Dishwasher
Our BDW 13 keeps tripping our fuse board
your cicuit is overloaded. hook the DW up to its own cicuit, or at least one that will not overload it. Circuits should not be loaded to more than 80% of their capacity. 15 Amp load no more than 12 amp.
when motors/pumps start they use the most load or power, or when your DW turns on the heat.
Nov 01, 2009 | Baumatic 23 in. BDW13 Built-in Dishwasher
Need door locks for bdw 10 and bdwa where can i get these
You will have to look in ypur local yellow pages or phone directory, and try to find a appliance parts warehouse. They will have or can order what you need.
Oct 02, 2009 | Baumatic 23 in. BDW10 Built-in Dishwasher
Error E1 comes up on dishwasher
E1 error comes up when faucet is not opened. this is shown up when it takes longer filling time.
The solution for this is to ensure that the inlet hose is not kinked or crushed.
Dec 23, 2008 | Baumatic 23 in. BDW10 Built-in Dishwasher
Baumatic BHD5 works then buttons start flashing and it beeps and stops working
Before buying a new control unit, try to unplug the machine for few hours and plug it back in. It might reset the control panel and solve your problem. Good luck!
Aug 01, 2007 | Baumatic 24 in. BFD60SS Free-standing...
High pitched whining noise from bottom of dishwasher
the arms are only turned by water coming out of them thro angled jets, they are not electrically driven. the noise will be coming from the circulating pump, probably one of the bearings. no cure except to replace
Mar 10, 2007 | Baumatic 18 in. BDW45.1 Built-in...
Baumatic 23 in. BDW13 Built-in Dishwasher Logo
967 people viewed this question
Top Baumatic Dishwashers Experts
Oloyede Monsuru
Kolbrun...
Are you a Baumatic Dishwasher Expert? Answer questions, earn points and help others
