Question about Nikon D80 Digital Camera
D70 viewfinder went dark all of a sudden
This is unrelated to lens as it is the same with 2 lenses. I agree with other poster saying 50% light
  • 797 Answers
Some things to try.
Go to the menus and reset all of them to default.
Check the camera.
I am not sure this has anything to do with the lens. Diff. lenses may give less light, true.
I am almost sure this has something to do with the settings.
Try above and see if it works.
Posted on Sep 08, 2009
My E 300 works fine with the 14-45 3.5-5.6 lens, bright viewfinder and good photos. However, with the 40-150 3.5-4.5 lens the viewfinder went dark abd photos are overexposed. Problem went back and forth...
I assume this happens while your camera is in the automatic mode. Because if the camera is in manual, you can't assume both lenses give the same light to the sensor.
But I should look if the contacts on the lens and in the camera, ale all clean and shiny. And not one of the contacts is allowed a dent. Not even a little dent. All contacts must be flexible. Then be sure the Aperture setting on the 40-150 must be correct. The camera manual does not say a thing about the settings on the lens, but I should look there too.
Feb 19, 2014 | Olympus EVOLT E-300 (Double Lens Kit)...
The image looks dark
The finished image looks dark or it looks dark in the viewfinder?
If your question is "the image looks dark" in the viewfinder my answer is it's an F4.5 lens so letting less light into the viewfinder and it will look dark. The big difference will be seen if you are coming from lets say a Nikon 50mm F1.8 which is two stops faster then your F4.5.
If it's the finished picture after you taken it I'd say you underexposed the shot.
Dec 10, 2010 | Nikon Nikkor 55-200mm f/4.5-5.6 G AF-S...
Problem with new D90 and old Nikkor 18-200 VR lens
Try a diff lens on the D90 to see if its the body or the lens. Tony
Apr 12, 2010 | Nikon 18-200mm f/3.5-5.6 G ED-IF AF-S VR...
Nikon D80 Dark Viewfinder and Slow Shutter Speed
At first it sounds like a faulty aperture blade that is stuck after your first press. However you mentioned that this happened in other lenses as well. Seems to me that there is a problem with your camera (e.g. mirror lockup problem or something else). Pls have it looked at by Nikon
Aug 13, 2009 | Nikon D80 Digital Camera
Nikon D60 is suddenly taking very dark pictures
I have had "dark pictures" from each of my Nikon DSLR (D70, D80, D200, D300) cameras usually when taking pictures from a tripod and/or the self timer. Situations where you take your eye away from the viewfinder which allows stray light to enter thru the viewfinder and throw the auto exposure way off. Not sure if this is what is happening to you.
Jun 22, 2009 | Nikon D60 Digital Camera with 18-55mm +...
Sigma 28-300mm autofocus problem
You will need the interupter replaced the iris is closed down so the a/f will not lock on
Jun 16, 2009 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
D70 internal flash not firing
Check if something is preventing the flash to pop up 'fully'. Check for some dust or other particles trapped between the flash and the body. Does the screen say 'Subject is too dark'? If so, the flash has not popped up fully.
Nov 10, 2008 | Nikon D40 Digital Camera with G-II 18-55mm...
In the dark
Hey yorkshireboy,
If the viewfinder is dark the only cause of this could be the aperture is stopped down to a smaller opening, which is probably an indication that your lens is not working properly. One way to tell for sure is to bring the camera to a retail location and try out a brand new lens on it, and if the problem persists then your lens is probably fine and the problem is in the camera body. On the front of this camera is a button that stops the aperture on the lens down so the photographer can preview the depth of field, and if this function is broken somehow it might be stopping the aperture down at all times which might be causing your problem. Either way this is a nice camera and I would have the camera or the lens (whichever ends up being the culprit) looked at by an authorized service technician. If the problem is the lens and the lens is a Nikon lens it most likely has a 5 year manufacturer warranty on it and the repair would probably be free of charge. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 12, 2008 | Nikon D70s Digital Camera
Really Dark Viewfinder
That would explain the darkness if the lens is stopped down. It would seem the aperture control is faulty on the camera body. Normally, the aperture remains open until you take the picture. It is only closed down while the shutter is open.
Feb 11, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
Depth of field preeview button
That's a really good question, Denise.
One problem is that a D70 viewfinder is dark to start with. I don't notice this when shooting with mine unless I pick up my old Pentax Spotmatic for some reason, and then I am reminded how bright an optical viewfinder can be. So, in many cases, you will find the DOF preview useless not because it isn't working, but because the scene is simply too dark for you to see the differences.
Second thing is to notice what DOF you are seeing when you DON'T have DOF pressed. I think all modern cameras give you viewfinder at wide open aperatures -- so until you press DOF, you are seeing the focal depth produced by your lens' widest aperature. So don't expect to see much difference if you hit DOF with the aperture set at 2.2 on a F/1.8 lens -- you're comparing very similar lens apertures.
In fact, I notice that with my F/1.8 lens, I don't see any differences in where my focus lies until I have closed the lens down to maybe F/8. But beyond there, I can clearly see that more and more of the scene is in focus.
If you're still curious but not seeing it, try some test shots. Change the aperture and using shutter time to compensate, and see if your photo DOF matches the preview.
Hope that makes sense!
-- eastpole
Nov 28, 2007 | Nikon D70 Digital Camera with 18-70mm Lens
Nikon D80 Digital Camera Logo
104 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
