Question about Refrigerators
FRS26WQH leaks from the front right hand corner of the frig section onto the floor. What is wrong?
  • 4,059 Answers
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Posted on Sep 08, 2009
Testimonial: "What a wonderful and sensible answer. Thank you."
Frigidaire frs26wqh frige side not cold?
most of the time the door that controls air from freezer to fridge is stuck shut or broken shut,,, located in upper left hand corner of fridge side
Jul 10, 2014 | Frigidaire Refrigerators
Water leak on floor under refrigerator
The line going into the dispenser is a 5/16 line. You'll have to remove the front of the dispenser on the door to get access to the line to unclip it. Once you have that done you can pull the line out from the bottom. At this point there are a variety of different unions, compression fittings, etc. to splice the line. After that you just feed the line back through the bottom of the door, clip it back in place, put the dispenser back together and your done.
Jun 15, 2012 | GE Refrigerators
Hello! I have an issue with my maytag dishwasher model number MDB6100AWQ. It is running, and it goes to drain, and slowly starts leaking onto my kitchen floor! We took it out about a year ago and...
check the door gasket. check that it is draining. disconnect drain line from under sink ad put into a bucket. most likely it isn't draining ad is overflowing.
Sep 22, 2011 | Maytag Dishwasher
Water leaking from frig onto floor
Check out these tips...they can help you figure out what is going wrong with your refrigerator
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Apr 21, 2011 | Refrigerators
Cant get the machine to balance service guy comes out with my dad at my house who is 70 years old and service guy tells him nothing is wrong . i leveled it out and it shakes the house and says uneven load...
Hi from retired Englishman in SW FRance @ 16:49 Sat afternoon- nothing on TV!
As the service guy says there is nothing wrong with the machine it must be that it is STILL not absolutely balanced.
Really rock it from each corner. If it rocks, even a little, from the right hand front corner then it is the foot underneath that corner which need to be adjusted downwards until it is TIGHT onto the floor then locked by the locking nut so that it cannot vibrate loose. If not this corner then the left hand side need adjusting.
The feet DO need to be very firmly on the floor- honest!
Best of luck,
John C
Jan 29, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
I don't really have a problem but I put the wrong
1. Go onto facebook and login.
2. Click the "Home" tab on the upper left hand corner of your feed page (the page that shows up after you login).
3. To the right of your profile picture and under your name, click the "info" tab.
4. Under your "basic information" section, your birthday will appear under there. So if you bring your mouse to hover over the section, you should notice a "edit" link appear to the right of the info section, so click edit.
5. Change whatever needs to be changed and make sure that you "Save Your Changes!" If you don't save, then the error in your birthday will appear.
If the problem continues to appear, contact the site crew through the "help" link at the bottom right hand corner of the page.
May 14, 2010 | Computers & Internet
Water leaking on floor at right front corner of
check the door rubber for any tears,this is also called a boot glove.
Jul 14, 2009 | LG WM2688H Front Load Washer
Maytag mdb6000awb built-in leaking problem
it can be 3 problems. Most likely one is the seal from the acces apnel is leaking.
Or hinge of door is too lose or door seal.
My bet is on the seal for the acces panel.
HERE is drawing. However seal (#12E) is not drawn in.
You can also order the parts here and have them within about 3 days
Jun 29, 2008 | Maytag 24 in. MDB3700 Built-in Dishwasher
Water leaks onto the floor during every load. The water appears to be comeing from the front right hand side.
Please check the water tap connected to the washing machine. Sometimes it may be leaking.
May 18, 2008 | Whirlpool Washing Machines
Refrigerators Logo
105 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
