Question about Motorola Mobility RAZR V3
My motorola phone is only 1 year old and has ceased functioning. Could it need a new battery already?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 153 Answers
Hii
can u be more specific? is it that it hangs , or response time is too slow ? or is it tht u have key pad problem?
Any ways i wud suggest u to charge ur battery full and goto the official moto software update , u wil find at the lower left side of ur phone tools and follow the instructions, it will update ur phone with latest software.
Note: Before doing this, kindly make a back up of ur contacts using motorola phone tools, and always make sure while updating the phone's software the battery shud be charged completely.
Regards
Posted on Sep 08, 2009
    Sergeant:
  • 199 Answers
Its software has been corrupted and needs troubleshooting by pc .
Take it to ur Technician and install software
and the phone should come on ,unless it has mother board problems ie Eprom ,power ic, processor.
pls let him check also these above .
good luck
bye
My H730 will not hold a charge?
If it is less than a year old contact Motorola Support (http://www.motorola.com/support) if it is longer than a year old you may need to get a new headset if you have already tried another charger to ensure it is charging properly.
Mark
Motorola Support
Jul 14, 2014 | Motorola Mobility H730 Bluetooth Headset
Battery life on my new I580 phone is extremely shorter than on my old i 580 . I have tried many diff batteries and they all discharge in about 4 hours heavy or light or no use at all . What do you suggest...
Hello, bwheat630!
I will suggest some things that you may have already tried, but atleast something is better than nothing.
1. Set your phone on settings that are lower (e.g. backlight dimmer and have the backlight turn off sooner).
2. Go on eBay.com and look up a battery for your phone here is the link just copy and paste into your browser:
http://shop.ebay.com/i.html?LH_ItemCondition=1&rt=nc&LH_FS=1&LH_BIN=1&LH_PrefLoc=1&_nkw=Motorola%20i580%20battery&_dmpt=PDA_Accessories&_fln=1&_trksid=p3286.c0.m283
you can buy the extended life battery pack.
3.You can also buy one or two have them charged for when you need them.
Best Wishes
-hopeufixit-
Dec 01, 2010 | Motorola Mobility i580 Cellular Phone
6 month old dell inspiron 1764 says can not identify a/c power adapter works with only the battery and works with charger will maintain around 50% but not charge
HI there,
In most instances, just as you've described yours, the culprit is usually the charger. It's not uncommon for the charging system in the charger to cease to function while the power function continues to work. This is particularly true of Dell chargers.
If the laptop is still under warranty, call Dell Support and they'll almost surely send you a new charger because this problem is considered to be a possible safety hazard.
Since Dell's standard factory warranty is for 1 year, they should be able to help you. If not, and you have to purchase a new battery on your own, be sure to purchase ONLY a Dell charger
Sep 19, 2010 | Dell Computers & Internet
Razor
HI,
Every phone battery has a life cycle. if the battery is more than year old , it most probably requires a replacement. As its not able to retain charge. If its under one year , get the same replaced from the motorola service center . I had the same problem with my razor and they replaced it free of charge as the same was under 1 yr .
Thanks
Proton
Apr 22, 2009 | Motorola Mobility RAZR V3c Cellular Phone
My motorola z3 battery only last for 10 hrs
Is it possible that you turned the bluetooth connectivity on? In that case, try turning it off. The bluetooth functionality really shortens the standby time.
Mar 26, 2009 | Motorola Mobility MOTORIZR Z3 Cellular...
Phone won't turn on. Tried a new battery and
If you have already tried using another battery and the device still fails to turn on/and or function correctly, then most likely your experiencing hardware issues.
I would check with your carrier in regards to any possible service/repair diagnostic test. Visit your nearest carrier's service center and filter your best options. You may still be under warranty with Motorola. Explore Motorola's website for manufacturer warranty information.
Sorry for the trouble. Thanks.
Mar 24, 2009 | Motorola Mobility RAZR V3
Razr Inop
you need to take the phone back and have it replaced for a new one.
Mar 19, 2008 | Motorola Mobility RAZR V3
Motorolai836
It's the mini coin cell battery in the rear housing. You must take it to a service center
Nov 17, 2007 | Motorola Mobility i836 Cellular Phone
Keypad
You will have to remove the screws below from your battery with a torx t7 screwdriver after that you can ease the front of your case off and replace your old keypad with a new fully functional 1
Oct 17, 2007 | Motorola Mobility L6 Cellular Phone
Phone discharges battery
Well take it to the shop you bought it from and you might have to have kept the receipt and they will send it off to the specialists ,
it is a common thing with motorolas and batteries should last at least 1 year anyway hope i helped :)
Oct 16, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
