Question about RCA Pearl TH1102 MP3 Player
Keys locked on rave mp3 - RCA Pearl TH1102 MP3 Player
  • 4,281 Answers
First press power button for 10 seconds .
Then pull battery from mp3 and remove memory card from it.
Then again put battery in it's position then start mp3.
Then go to menu settings then reset all settings to factory defaults.
If still face issue then you have to check key pad of your mp3 clean dust from key pad and check its spring works fine.
Let me know if you need more assistanse.
Thanks.
Posted on Sep 08, 2009
Computers not seeing the Rave MP3 player
Sounds Like you need to get device drivers for this MP3 Player. Try driversguide.com or drivershq.com. Hope this helps
Nov 19, 2010 | GoVideo Rave-MP ARC2.5 (2.5 GB) MP3 Player
How do I delete songs existing on Rave.mp ?
Once you can connect the device to your computer, it should popup like a use device that you can delete the songs or file you want.
Aug 17, 2009 | GoVideo Rave-MP AMP128 (128 MB) MP3 Player
Windows xp wont recognize usb connection from rave. Is there a driver I need?
If you're using the retractable usb cable that came with the player, replace it. I had the same problem. XP recognized that there was a device, but couldn't open it. I was getting a "Driver not installed" error in device manager.
Jun 08, 2008 | GoVideo Rave-MP AMP512 MP3 Player
Rave-MP AMP126 MP3
This slot is for an SD card. You use this to expand the amount of music you
can hold.
Mar 24, 2008 | GoVideo Rave-MP AMP512 MP3 Player
Rave-mp 128 mp player
Have you tried using the install CD to re-install the player?
Or you can go in windows and under folder options, click show hidden files and folders. And hide operating files.
This will show all the files on the CD.
Remember to restore the settings to normal after you have done.
Nov 24, 2017 | GoVideo Rave-MP ARC2.5 (2.5 GB) MP3 Player
Rave Mp3
just basically have to hook it up to the PC and reload the firmware. (Tnough it seems the company is no longer in business, you might be able to find the firmware update file out on the net somewhere.) Seems to freeze up more if I have the SD memory card in there. Had better luck with some types of SD cards than others (faster speed cards seem to cause me less probs.) or backup the music etc, and restore the player to factory settings. good luck.
Sep 25, 2007 | GoVideo Rave-MP AMP512 MP3 Player
SD Card
Mine works with 2GB card... AFAIK, that's the max, although I haven't tried a 4GB card.
I found updated firmware at:
http://uiss.max.io/
*update*  site has not been updated and download links not working... useful info there nonetheless... I will put the file(s) on my site:
http://french.moren.ca/rave-mp/Rave-MP-Install.zip
http://french.moren.ca/rave-mp/iLO256Manual.pdf
expect them up there by Oct. 20/07...
the ILO player referred to there is electronically identical, if not physical and the update works with all the Rave MP AMP series. I had a hard time finding this but it was worth the effort.
works great :-)
Sep 05, 2007 | GoVideo Rave-MP AMP512 MP3 Player
Rave-MP 5.0
There are 2 issues- 1 the keys are locked - unlock and turn machine off. the other option is to recharge the battery
Jan 26, 2007 | GoVideo Rave-MP ARC5.0 MP3 Player
Rave mp mp3 player ---- frozen
Try a separate SD memory card (no bigger than 512mb). Also try replacing the battery if you haven't already. Mine has done this intermittantly since it was about a year old.
Jun 28, 2006 | GoVideo Rave-MP AMP512 MP3 Player
RCA Pearl TH1102 MP3 Player Logo
18 people viewed this question
Top RCA Audio Players & Recorders Experts
Gyula Lacz
Are you a RCA Audio Player and Recorder Expert? Answer questions, earn points and help others
