Question about G7 Productivity Systems IP 1500MX Printer
Printer is not printing
I cant print anything on my printer it says things are in queue but how can i start printing them
    Scholar:
  • 151 Answers
This is a silly question but Is the printer turned on or is the usb plugged in? If so, try pressing the printer resume button. If it still doesn't print, look at your printer settings at the control panel and see if the actual printer your using is the default printer...
Posted on Dec 09, 2007
Dell v515 printer
Several immediate things come to mind; check to make sure that the printer drivers are up-to-date; there maybe a possibility of an IRQ conflict; check to make sure that the printer is set as the default printer in control panel; make sure that the printer you want to print from in the <file>, <print> menus screen is selected and not a virtual one. Absent more info like OS and how your printer is connected to your computer (e.g., is it through a serial cable, then make sure com port is active in BIOS and is checked off in the properties menu [control panel, printer, properties, port tab]; or are you using an LPT-printer port or USB connection- make the same check. Sorry that I can't be more specific without additional info.
Nov 22, 2013 | Office Equipment & Supplies
Canon pixma mp610 cant delete the printing queue or print
This is not the fault of the printer but windows. Open the Control Panel, select Devices & Printers, find your printer, click on it, select Delete Print Queue. Problem is fixed.
Jan 07, 2013 | Canon PIXMA MP610 InkJet Printer
I have a lexmark x3400 printer and a windows 7 operating system. The current print job won't cancel and won't delete and I can't print anything else. I can't uninstall the device as it says the printer...
You will need to clear the print queue first before trying to send another print job. - Browse to Start -> cmd... and type in "NET STOP SPOOLER (this will stop the print spooler service) - Browse to your windows\system32\spool\PRINTERS\ folder - You should see files there ending in .SPL and .SHD created around the time you tried to print - delete these files. - Browse to Start -> type cmd... and type in "NET START SPOOLER" (this will restart the print spooler service) - Double click the printer icon in the lower-right corner of your taskbar to examine your print job queue and browse to View -> Refresh.
Apr 24, 2011 | Lexmark X3470 All-In-One InkJet Printer
Printer was working, but is not now. All cables are hooked up properly and have been disconnected and reconnected. I have several documents in the memory to be printed, but the printer will not respond. ...
Here are four things you can try; may not have to perfom all:
Check to see if your printer is off-Line
1.Open the Printers, Printer and Faxes, or Device and Printers folder.
To do this:
Windows XP users; Click on Start > Settings > Printers an Faxes or Start > Control Panel > Printers and Faxes.
Windows Vista users; Click on Start > Control Panel > Hardware and Sound > Printers.
Windows 7 users; Click on Start > Device and Printers.
2.Right-click on the printer object (icon), and select Use Printer Online.
3.Microsoft Windows 7 users will double-click on icon, select printer and then de-select Use Printer Offline.
Printer Paused
The printer or print queue is paused and the print queue icon remains in the notification area ('systray') of the task bar.
Explanation:This is typically an end user error. Hint: Dragging the mouse cursor over the print queue icon in the notification area will reveal (1,2,3) document(s) pending for (User name).
What to do:
•Double-click on the print queue icon to open the print queue.
•Click on Printer in the upper left-hand corner of the menu bar.
•Is there a check mark next to Pause Printing?
-If yes, click on Pause Printing to turn off this Windows feature.
-If no, confirm that there is a check mark next to Set As Default Printer and make sure Use Printer Offline is not selected.
Delete print jobs from the print queue
Access the print queue.
Delete all print jobs
• Click on Printer in the toolbar and then click on Cancel All Documents,
or
• Right-click in the print queue and select Cancel All Documents from the pop-up menu.
You can also delete individual print jobs
1.Highlight the individual job in the print queue by clicking on it.
2.Right-click on the highlighted job and select Cancel from the pop-up menu.
IMPORTANT! If a job is stuck in the print queue and cannot be deleted or canceled using the above steps, there may be an issue with the printer spooler that controls the printing options in Windows. If you observe this symptom, it may be necessary to stop and restart the print spooler; then retrun to delete print jobs.
How to Stop and Restart the Print Spooler
Problem:
Unable to cancel print jobs; Unable to print; Print queue is unresponsive; Locked print queue; Unable to print; Cannot cancel print job; Printer driver not responding
Solution:
The print spooler controls print options within Windows. A problem with the print spooler can affect printer driver performance and Windows print queue responsiveness. Stop and Start the print spooler to see if observed symptoms subside or remain.
Method 1: Using Administrative Tools
Step Action
1 Click on the Windows logo start button.
2 Click on Control Panel on the right-hand side of the start menu contents.
3 Click on Maintenance.
4 Click on Administrative Tools.
5 Click on Services. NOTE: You may have to provide an administrator profile and password.
6 Scroll through the list and look for Print Spooler.
7
The following two options are available to stop and start the print spooler:
•Click once on Print Spooler to highlight it, and then click on the Stop or Start links in the right-hand window pane,
or
•Double-click on Print Spooler, and click on the Stop button followed by the Start button.
8 Observe the status column in the Services window to verify that the print spooler is stopped or started as applicable.
Trust this helps to resolve your problem. Please vote.
Dec 29, 2010 | Lexmark X5495 Printer
I cant get a print job to delete from the queue and its holding up all the other jobs
To delete print jobs stuck in the print queue on Windows:
  1. Click Start ? click Control Panel ? click Printers and Faxes.
  2. Right-click on the Lexmark print object and select Cancel All Documents.
  3. If that doesn't clear the queue, restart your computer.
If print job(s) still remain in the queue even after doing the steps above:
Stop the Print Spooler service from the Services console
  1. Click Start ? click Run ? type cmd ? click OK.
  2. Type net stop spooler at the command prompt ? hit Enter on the keyboard.
Clear the SPOOL folder
  1. Click Start ? click Run ? type spool ? click OK.
  2. Open PRINTERS folder ? delete all files in the folder.
Start the Print Spooler service from the Services console
  2. Type net start spooler at the command prompt ? hit Enter on the keyboard.
Try to print again after clearing the print queue.
Nov 24, 2010 | Lexmark Z611 InkJet Photo Printer
Docs in queue won't cancel so I can print another document
turn of the printer and unlug the data cable.
go to start>>printer and faxes, open the printer queue and deleted the job.
plug in the data cable and turn on the printer
Jan 29, 2009 | HP LaserJet 1020 Printer
Print Queue problem
I think you should try using following command:
1) Run command prompt
2) Use command "net stop spooler" followed by "net start spooler"
check if the problem persists.
Jan 13, 2009 | HP LaserJet 1020 Printer
When I press 'print' my new Canon Pixmz iP4600 it takes about 30secs before it starts to print. After printing, the print job remains in a queue for about 5 mins, preventing me from printing anything else.
This sounds more PC related than it does printer related. Your printer cannot determine when things enter/leave your print queue. I have seen that issues with several different printers and they all were PC related issues.
Dec 10, 2008 | Canon Office Equipment & Supplies
It Just Wont Print
Have you tried installing the HP Print Diagnostic Utility?
This utility fixes some of the basic issues with the printer /computer.
Download/Install and follow the onscreen instructions to run the utility and restart the computer when prompted.
I hope this tool resolves your issue.
gud luck.
Oct 26, 2008 | HP PSC 1315 All-In-One InkJet Printer
My print jobs hang up in the queue
Test pages are printer generated not from the computer. Have you checked Microsoft help on this? make sure you are on line. Go to My Computer /Help, then when the help pages comes up Type in print spooler See what you get Rephrase the question if the answer you seek is being missed.
Jun 21, 2007 | Dell Inkjet 720 Printer
G7 Productivity Systems IP 1500MX Printer Logo
Top G7 Productivity Systems Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Jax Planet
Jax Planet
Are you a G7 Productivity Systems Office Equipment and Supply Expert? Answer questions, earn points and help others
