Question about Canon PIXMA MP160 All-In-One InkJet Printer
Trying to print a document and it prints small info about the printer
5 Suggested Answers
  • 168 Answers
SOURCE: Printer Problem
I would try to Highlight the entire page, then right click,
Select Print, and then select "entire selected section" and then Apply and print.
This should work.
Good luck.
Posted on Feb 08, 2008
  • 60 Answers
SOURCE: small prints
  1. Click here (http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403)
  2. Halfway down the page type this in the "Please enter your question:" field "print too small"
  3. Click the search button
  4. I believe the first article is what you're looking for.
Posted on May 30, 2008
Grubhead
  • 5487 Answers
SOURCE: THE TYPE SIZE IS TOO SMALL ON MY MP460 PRINTER.
Some fonts might not be available to use in the printer, make certain it's a true-type font you are using in your document.
Posted on Jan 08, 2010
  • 212 Answers
SOURCE: when printing the document info is cut off on the left hand side op the paper
printer tiflon is damage please contact the shop kapeer and repair tefon paper
Posted on Apr 13, 2012
At random times, when a user prints, a document, pdf, picture ect.., it's slanted. It also happens when a user scans to themselves. What can cause this to happen?
There mite be something in the path of the paper which the paper hits and so it is slanted have you tried scanning on the big glass instead of thru the document feeder does it happen then? Now the printing is something else are you talking about copying or printing. If print I would check the paper draws ensure the guide are snug up against the paper. Do you internal prints slant such as the meter count print out or the fax info reports. or the demo page? If the problem is coping then place the original on the big glass and see if the slant There are small mylar guides though out the document feeder if some one pulled the original document out in the wrong direction they mite have flipped on of them causing a corner of the paper to hit one slanting the original ALWAYS pull the original out in the same direction as the flow of the document. Try sticking a business card down thru the way the paper flows you mite be able to reset the offending mylar.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 22, 2014 | Konica Minolta bizhub C250 All-In-One...
When printing the document info is cut off on the left hand side op the paper
Apr 13, 2012 | Canon LBP6000 Laser Printer
When I try to print a document, even small size documents (56 KB) I get a message on the LCD screen that says, "Out of Memory. Secure Print Data is full." How can I get the printer to print the document!?
need more information about printer?
is it new ?
did it come with expansion memory slot
can you see printer properties and reset the print setting
as in RAW print or other print queue options
Jun 11, 2010 | Brother HL-4040CN Laser Printer
I have a HP 5610, print very small letters
Go in the printer preferences and change the options to "print as in document" and make sure that 'scaled to it is not checked'.
Maybe, you scaled it down by accident. Also, make sure that you didnt choose 8 points in the original document. Otherwise, it will print small
Aug 04, 2009 | HP Officejet 5610 All-In-One InkJet...
Print size has changed to very small off internet
Assuming that normal printing is fine, This is due to the size of the print in the email. To output larger print you'll have to copy the email into a document, change the size and then print the document.
Apr 30, 2009 | Dell 924 All-in-One InkJet Printer
Print is too small.
r u printing from internet...? if yes then save the document before you print on your desktop or copy the document on word and then print.
Nov 28, 2008 | HP DeskJet 950c InkJet Printer
Problem with printing document footer text on RICOH SP C811DN
Check the paper size settings and orientation of the driver from the Control Panel, and that match to the paper size in the printer's trays.
Good luck and please rate me, thanks.
May 28, 2008 | Ricoh Aficio SP C811DN-DL Printer
Print out is too small
To resolve this, try the following actions:
* Check the default fonts within Microsoft Windows.
* Select your entire document and set it to a larger font.
* Make sure all your fonts are loaded properly.
* Change the resolution to quick print at 600 dpi. To do so:
1. Click Start, Settings, Printers.
2. Right click the Lexmark printer icon and choose Properties.
3. Choose the Document/Quality tab and set the resolution to 600 dpi quick print/draft.
* Change the Spool Data Format to RAW. To do this:
3. Select the Details tab and click Spool Settings.
4. In the Spool Settings screen, set the Spool Data Format to RAW.
5. Click OK and then Apply.
Nov 19, 2007 | Lexmark X2350 All-In-One InkJet Printer
Canon PIXMA  MP160 All-In-One InkJet Printer Logo
14 people viewed this question
old marine
old marine
