Question about HP PSC 2410 All-In-One InkJet Printer
My scanner is not working. Can't open HP director on my laptop. I tried to reinstall CD that came with it, but " more recent version installed" Printer and copier work fine.
    Problem Solver:
  • 14 Answers
Here are some diagnostics.
1. Go to control Panel and then to scanners & camera.
2. look for your scanner there.
3. if you find your scanner there try to scan from the wizard and you will be able to scan you docs.
To Reinstall the Hp Director....
1. first uninstall the HP director software using the removal utility located in your cd...
The uninstaller on the Internet is newer and works better than the one on the CD-ROM. Use this method only if the Internet version is not available. Follow the steps below to use the CD-ROM version only if you cannot get the regular uninstall to work correctly and cannot access the Internet:
  1. Leave the USB cable disconnected from the all-in-one.
  2. Insert the all-in-one CD-ROM into the computer. Cancel or close any installation windows that appear.
  3. Right-click the Start button, and then click Explore . This will open Windows Explorer.
  4. In the pane on the left, locate the CD-ROM drive letter that contains the all-in-one CD-ROM.
  5. There are two different versions of the software for some of these models. Use the file path that pertains to your version of the all-in-one software.
    • Early versions of the HP Officejet 6100 and PSC 2100 and 2200 series: Double-click the file hposcr01.exe , located in the Drivers\Uninst\language (ENU for English, ESN for Spanish, FRA for French, or PTB for Portuguese) folder of the CD-ROM.
    • The newer software version: Double-click the file Cleanall.bat , which is located in the Util\CCC\Cleanup folder of the CD-ROM.
    ONCE THE SOFTWARE IS COMPLETELY REMOVED.RESTART THE PC AND TRY TO INSTALL THE HP DIRECTOR SOFTWARE FROM THE CD.
Let me know for any further help....
http://www.ikarmatech.com
Posted on Sep 08, 2009
    Sergeant:
  • 199 Answers
Hello ! pls explore ur cd look for scanner drves then install it seams like u only install printer only .
good luck
bye
Hp Director is not working and I cannot scan from the printer/scanner
You should uninstall the software and reinstall it fresh. You should also download the newest version available on HPs website instead of the one on the CD that came with your machine to ensure that you are using the newest version.
Sep 09, 2008 | HP Office Equipment & Supplies
Can't open Hp director
I read ur problem.This problem with HP director occurs if you are running Internet version (7.0).If u have difficulties knowing your Internet version, pls do the things mentioned below.
1.Open internet explorer->click help->then click on "about internet explorer".---There you will see the version of your browser.
SOLUTION.
If see an hour glass appearing and disappearing without displaying the HP director window after clicking on HP director, You got the following solutions.
Solution 1.
1.Double click HP director icon.
2.Then Press Alt + space key together.
Result:YOU will see a small pop menu appearing on the desktop screen.
3.Click on "minimize" on that pop up screen.
Result:Now u will see a tab on the taskbar.
4.Right click the tab(hp director),then click restore...Now you will see your HP director window.
Note: Above solution should be performed while trying to open HP director.(ie) You should try this every time if u want to open HP director.To go for full time resolution,then try solution 2.
SOLUTION 2:
1.Open "www.HP.com"
2.Select "software and driver downloads"
3.Type your product name in the "for product text box",then hit enter.{(eg) if u type 7410 for office 7410,then u have to select the exact model in the next window}
4.Select the operating system.(if u dont see a option to select operating sys, there u will see "software and driver downloads"
5.In the next page, you will see a list call "Updates" you have to download a update which says "
Critical update to resolve an issue with HP Director after installing Internet Explorer "
6.After downloading the update, run the file and thentry to open HP director it will open the director window.
This will work.I assure u total problem resolution
Regards
Chittaranjan
Dec 25, 2008 | HP Scanjet 3570 Flatbed Scanner
HP Director missing from desktop
It may happen if you have version 7.0 of Internet Explorer.
Install the below patch on your system it will make the HP Director to work.
http://h30318.www3.hp.com/pub/softlib/software8/COL17377/oj-46104-1/CIT207355-HPCOM-PATCH-v8.exe
I hope it will work.
Sep 10, 2008 | HP Scanjet 5590 Flatbed Scanner
Installed but can't be found
We will experience this type of issues if the drivers are not installed properly.
Once remove the USB cable from the computer and insert the CD and click on ' add a device ' option and follow the onscreen instructions and connect the USB cable at the middle when it prompts.
Once it is finished, check for the printer icon and then try to print.
Also try to open the HP Director, if it doesnot open then download the IE7 patch from the HP website and then install it and try to open.
Please reply if you have any further more issues.
Jul 06, 2008 | HP PSC 1315 All-In-One InkJet Printer
Hp director
uninstall and remove all the icons from your PC first than reinstall the driver from CD and run complete setup it works.
Feb 18, 2008 | HP 5590 ScanJet Flatbed Scanner
H P Director not working
hi yesjay,
I've seen this exact same problem before. What I deduced from that experience is that the Readiris software takes over the redirector function of the HP Director service. The only way we got the HP Director to function again was to:
1.) Uninstall Readiris
2.) Uninstall the HP printer
3.) Reinstall the HP printer without installing Readiris
This resulted in the HP director service working properly again, but with the user unable to use the character recognition functionality provided by Readiris.
Hope this information helps to clarify your current situation and thanks for using the FixYa service
Kind regards
Feb 15, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Scanner/Director problems since installing new ink cartridge
http://h10025.www1.hp.com/ewfrf/wc/documentSubCategory?rule=45391&lc=en&cc=us&dlc=&product=90764
Dec 28, 2007 | HP PSC 1210 All-In-One InkJet Printer
Trying to reinstall printer and I keep getting an error message
Does this concern a hard drive, or a printer? disconnect the usb printer/scanner.
http://www.hp.com/
Get the most recent drivers and utilities for both the scanner and printer.
Keep me posted.
Oct 28, 2007 | Computers & Internet
HP PSC 2410 All-In-One InkJet Printer Logo
314 people viewed this question
Seeker5211
Seeker5211
