Question about Kodak ESP 3 Multifunction Printer/ Copier/ Scanner
Kodak ESP3 AIO. It will not scan, i get error message 1-2036 when I attempt to scan. No problem printing or copying
I get the error 2200 message everytime I try to send a fax
Hello there:
this is a scanner stall or jam. The steps below will help you to resolve the issue and clear the error message2.gif.
Printer Reset
NOTE: The embedded links in the table lead to specific troubleshooting documents.
StepAction1
Power off the All-In-One (AIO) and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
Did the error message return?
Yes: Continue to step 2.
No: Attempt a test scan. If the error message does not reappear, the error is resolved.2
Power off the AIO and remove the power supply from the back of theunit. Open the scanner cover. Check the scanner glass for cracks andthe scanner casing for cracks. Close the scanner lid. Open the topcover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
Yes: Continue to Contacting Lexmark.
No: Continue to step 3.3
Power off the AIO and remove the power supply from the back of theunit. Open the top cover of the AIO. Using the carrier belt, move thecartridge carrier to the middle of the unit. Insert the colorcartridge, close the top cover, reinsert the power supply, and power onthe AIO.
Yes: Repeat step 3 with another color cartridge. If the printer2.gif fails again, continue to step 4.
No: Repeat step 3and install the black/photo cartridge. If both cartridges areinstalled, attempt a test scan. If the error message does not reappear,the error is resolved.4
Power off the AIO and remove the power supply from the back of theunit. Open the top cover of the AIO. Using the carrier belt, move thecartridge carrier to the middle of the unit. Remove the color cartridgeand insert the black/photo cartridge. Then close the top cover,reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black/photo cartridge. If the printer fails again, continue to Contacting Lexmark.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark.If the error message does not appear with both cartridges installed,attempt a test scan. If the error message does not reappear, the erroris resolved.
Nov 10, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Kodak ESP3 error report 1-2010
I beleived taht you recieved this error message on your computer when scanning or printing., Right? For this case you need to call kodak toll free at 1 800 421 6699 since the software and the driver of your printer is having a problem. They will guide how to unistall properly your software and reinstall it., this issue is more on the software not on the printer
Nov 05, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
How important is downloading kodak home centre software for the kodak printer to work?
Kodak AiO home center, serve as a driver as well for your printer to print from the computer. It will let you scan, copy or print pictures. AIO home center will let you select the settings you want for your printer
Sep 28, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Error code 1- 2036
I fixed my error code 1-2036 by going to the "Configure Settings" in the AiO Home Center then selected AiO Printer changed to "Print Quality" to Draft and clicked OK.... Then I was able to Scan with no errors. I think the config settings were corrupted some how and this resaved them properly.
if that doesnt help
Go to Control Panel
Double Click on Printers and Other Hardware
Double Click on Scanners and Cameras
Double Click on Kodak 5100 AiO
Click Next
Read and follow directions
if both the solutions doesnt help... its time to call kodak
Jul 10, 2009 | Office Equipment & Supplies
The kodak aio home center won't open getting error 1--2010 esp3 printer
if using vista try this:
Right-click on the Home Center icon.
Select Properties.
Select the Compatibility tab.
Click Run this program as administrator.
Click OK.
reply if does not work.........
Jun 08, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Need to clean the heads but can't find instructions to do it.
To clean the printhead press: COPY and CANCEL at the same time.
To print a test page press: QUALTITY and CANCEL at the same time.
Go to Kodak AIO home center, click on the"?" and open the "user guide" for the complete manual. Wish they put in a printed version, put they don't. Good luck with the printer, mind has been nothing but problems. And keep trick of what you print. You will be shocked at the low output. Report it to Kodak and they might sent you new inks.
Bob D.
May 26, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
How can the Error 2200 be fixed? Lexmark X7170
Power off the All-In-One (AIO) off and remove the power supply from the back of the unit. Wait 30 seconds. Then reinsert the power supply and power the AIO on.
2 Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover and check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
3 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Insert the color cartridge, close the top cover, reinsert the power supply, and power on the AIO.
Yes: Repeat step 3 with another color cartridge. If the printer fails again, continue to step 4.
No: Repeat step 3 and install the black / photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
4 Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black / photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
Yes: Repeat step 4 with another black / photo cartridge.
Mar 31, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Error 2200
The 2200 error message indicates a scanner stall or jam. The steps below will help you to resolve the issue and clear the error message.
Printer Reset
NOTE: The embedded links in the table lead to specific troubleshooting documents.Step Action
Power off the AIO and remove the power supply from the back of the unit. Open the scanner cover. Check the scanner glass for cracks and the scanner casing for cracks. Close the scanner lid. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove both cartridges, close the top cover, reinsert the power supply, and power the AIO on.
No: Repeat step 3 and install the black/photo cartridge. If both cartridges are installed, attempt a test scan. If the error message does not reappear, the error is resolved.
Power off the AIO and remove the power supply from the back of the unit. Open the top cover of the AIO. Using the carrier belt, move the cartridge carrier to the middle of the unit. Remove the color cartridge and insert the black/photo cartridge. Then close the top cover, reinsert the power supply, and power the AIO on.
No: Install the color cartridge. If the printer fails, continue to Contacting Lexmark. If the error message does not appear with both cartridges installed, attempt a test scan. If the error message does not reappear, the error is resolved.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
PREM
Mar 02, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
KODAK AiO Home Center has encountered a problem
you need to uninstall the software and reinstall it, if you have not tried that. For XP Start-->control panel-->add/remove programme-->look for Kodak Printer software and uninstall it. For Vista Start-->control panel-->programmes and features and uninstall the software. Run the Kodak clear utility from http://unexpectedtwist4u.com/matthew and click on clear utility and you can either run it or save it first and then run it. Make sure to unplug the USB cable after uninstalling the software and reinstall the software from www.kodak.com/go/esp3downloads. Kodak phone support is open from 9 am to 12 midnight EST. Hope that works:)
Feb 28, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Kodak ESP 3 Multifunction Printer/ Copier/ Scanner Logo
212 people viewed this question
Top Kodak Office Equipment & Supplies Experts
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
