Question about Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television
My sony rear projection screen is turning the picture green and red like a 3d effect iv tried adjusting it nothing worked
  • Anonymous Mar 17, 2014
    the picture has no red in it. Tried to adjust the settings but nothing works.
  • 556 Answers
Sounds like convergence circuit has gone out. Needs service.
Posted on Sep 10, 2009
The picture in my tv is coming up as triple there is a green picture, a red picture and a blue picture and it gives it a 3D effect, the picture curves down in the centre. the make of my tv is LG and the...
Please do us a favor and rate this solution after reading.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 11, 2011 | Samsung PCL541R 54" Rear Projection...
The red in the picture is shadowing the rest of the picture giving it a 3d effect
All projection TV sets have two very common problems. One is convergence ( 3D/Warped video or dead set) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. In some cases the TV will also not show any video. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
  • Screen looks 3D, wavy, or has a shadow or shadows
69189a5.pngSOLUTION
You can get the correct parts, step by step photo instruction guides, and support from www.TvRepairKits.com or click here
69189a5.pngSOLUTION
Jan 23, 2011 | Sony KP-53HS30 53" Rear Projection...
Blue will not focus causing "shadows". Magic focus will not solve the problem.
This tv have a problems call convergence,it dead.The tv convergence board the 2 STK convergence ICS and some or all it resistors are dead.These parts must be replaced to solved convergence problems.The shop will cost u $300-350 for parts and labors.
Jun 17, 2010 | Hitachi 53FDX20B 53" Rear Projection...
It seems that I am watching my TV in 3D.
im joel a simple electroncis tech. try to adjust the settings but it does'nt work the i think 3 color inside ( red,blue,green) is one or two of them is deffective.so the best solution try to go the expert tech nothing else
Apr 12, 2010 | RCA P52926 52" Rear Projection Television
Red and green arcs, 3-D effect
Convergence is dead.Know how to solders?Replaced 2 Convergence ICS and all it resistors.Tries Tv repair World.com,Tvrepairkits.com for the convergence kit.The shop will cost u $300 for parts and labors.
Jan 21, 2010 | Samsung HC-P4752W 47" Rear Projection...
The picture looks 3D
  • Screen looks 3D
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
Oct 03, 2009 | RCA HD52W56 52" Rear Projection HDTV
My Sony Projection TV middle of the screen curves down on top and curves up on bottom. Picture looks dubble like 3D, screen looks like concaved. Left side of the screen color is light green and blue, right...
This is a very common failure on Projection sets. Its called a convergence problem.
You may have one or more of the following symptoms.
Screen looks 3D
No Audio / No Video - Makes Chirping Sounds
You can see some examples and find a fix here...
Sep 26, 2009 | Sony KP-51WS510 51" Rear Projection...
Text/images overlap each other in 3 colors, 3D distorted picture
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
Using your original remote go-to the tv settings then goto the convergence section.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick email and they will put one together for you. Their kits includes photo instruction guides, original Sanyo STK chips, convergence resistors, pico fuses, etc.
Jan 28, 2009 | Sony KP-51HW40 51" Rear Projection...
JVC AV-56WP74 56 in. Rear projection blurred image
Check that the 3 output plugs are in the right sockets (Red, Blue, Green) There is usually a felt pen colored mark on a white tape on the plug in wires. The Board sockets are marked Red, Green, Blue.
Easyab
Jun 20, 2008 | JVC AV-56WP74 56" Rear Projection...
Red green and blue lines
Most projection TVs have an option to refocus. For example, my Sony rear projection TV has a button on the front for focusing the lamps. Try finding this button or option in the menus with your remote. Projection TVs actually use three lamps, one red, one green and one blue. These need to line up exactly in order to form a good picture, and when they come out of focus, you see the edges which sometimes has the effect of a 3D image when you aren't wearing 3D glasses. Hope this helps!
Sep 07, 2007 | Panasonic PT-53WX54 53" Rear Projection...
Sony Grand WEGA KF50WE610 50" Rear Projection HDTV-Ready Television Logo
98 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
