Question about Lenovo 3000 V100 Notebook
DC Power jack broken
The dc jack on my son's computer is broken. I can't find a replacement jack. Its a lenovo 3000 v200. Nobody online seems to stock them. Maybe the same jack for another computer would work? Or, any other ideas?
  • 205 Answers
Looks like you're right, I did not see any Lenovo replacement jacks either. You might try looking at the IBM Thinkpad jacks for various models to see if you can find the same jack.
I've repaired 3 laptops with this problem. Rather than replacing the jack on the mainboard I wired a "pigtail" to the mainboard and then zip tied a female connector to the back of the laptop itself. I did this because the mainboards were pretty beat up from the heat the original jack produced as it began to loosen. The end result is not as pretty as the original jack, but it absolutely takes all the stress off the mainboard. Those computers will never have this problem again.
Good luck.
Posted on Dec 09, 2007
  • 3 Answers
The rear panel houses a power jack (it differs from the standard IBM connector, the new jack is used in all 60-seires Thinkpad models and Lenovo 3000. The power is also different now - 20V 4.5A instead of 16V 4.5A), modem jack and a video out.
    Scholar:
  • 151 Answers
I think you can get a replacement at amzon:
http://www.amazon.co.uk/Laptop-Adapter-4-5a-Thinkpad-Lenovo/dp/B000WIIT1C
  • Chris Montano
    Chris Montano Dec 09, 2007
    well this adaptor worked for the same notebook I repaired...
I have a laptop Lenovo G50-80.the problem is this,laptop not powering on. Power adaptor is working properly.whats the problem
Obvious question is how do you know the power unit is ok? There can be broken wires in the cable to the plug, there can be a loose connection in the jack inside the laptop, the battery in the unit can also fail and trip an IC that wont let the unit power on until you replace the battery.
Feb 26, 2018 | Lenovo Computers & Internet
I need to replace the charging port on my Lenovo 3000 Y410
the power port (dc jack) on a laptop is an easy fix. a repair shop will strip the laptop down to get to the motherboard and solder a new jack onto it. the dc jack should only cost a few pounds (can usually be found on ebay) so the main cost will be for labour. If the charge is over 25 pounds I would shop around because it should take about 30 mins to fix.
Aug 11, 2012 | Lenovo 3000 Y410 Notebook
Broken dc jack on acer 3003ln
If the internal DC Power Jack is loose, you will have totake the laptop apart to repair it. The DC Power Jack is on themotherboard and most times it is soldered to the motherboard. That meansyou will have to desolder the old one and solder a new one in it's place. Sometimes the dc power jack sits in a slot between the bottom case and palmrestwhich hold it in place and has a cable harness that plugs into the motherboard.
Apr 21, 2012 | Acer Aspire 3000 Notebook
Hi when plug in my ac adapter into lenovo x61 the tablet will not turn on i try it on other computer and it will on what happen?
LOL, sounds like your tablet has seen it's better days. See why HP got out of the Tablet business? They are nothing but trouble.
Apr 08, 2012 | Lenovo Tablets & eReaders
Gateway kav60 not charging. i have to wiggle the cord and sometimes it refuses to charge.
I guess you've got a broken laptop power dc jack or power cable.
Symptoms of a broken Laptop DC power jack:
- The laptop only operates when you hold the DC power plug in a certain direction (DC jack is broken or loose).
- The laptop only runs on battery power (no power is getting through the DC jack).
- The laptop gets no power at all.
- The laptop will not charge the battery.
- The laptop switches from AC power to battery power intermittently due to a loose or broken power jack.
- The laptop suddenly shuts off.
- The DC jack may feel loose.
- Sparks come out of the back of the laptop when you insert the power plug into the DC jack.
Apr 21, 2011 | Lifetime Gateway KAV60 Replacement Laptop...
My laptop lenovo 3000 N100 battery has a problem.. therefore i purchased a new battery but the problem with this battery is that when i use the battery it runs the laptop for 10 -15 mins and then with a...
My Dell laptop has a power problem.
d600a.jpg?w=300&h=258
The Dell Precision M20 Battery stops charging when I move the power cord on the DC adapter. When I start moving the cord left to right, the power LED light on the front goes on and off and the battery charge LED goes on and off too.
dell-precision-m20.jpg?w=300&h=225
I removed the precision m20 battery and tested the laptop again. The laptop starts fine from the DC adapter when the battery is removed, but as soon as I start moving the power cord the laptop shuts off. It looks like the laptop looses power immediately.
If you have a problem like that, most likely it’s related either to the power adapter or the DC-IN power jack.
First of all, I tested the laptop power ac adapter with a multimeter. The power didn’t cut off no matter how badly I moved the cord. The power adapter output voltage was 15.45VDC all the time. That means there is nothing wrong with the power adapter and most likely there is a problem with with the power socket inside the laptop.
Now I’m going to test the power socket inside the laptop.
In order to access the power socket I had to disassemble the laptop and remove the top cover assembly with the display.
You can find disassembly instructions for many HP, Dell, IBM, Lenovo, Sony and Toshiba laptops in these service manuals and guides.
In the laptop I was fixing (Tecra M2) the power jack is attached to a DC-IN harness and this harness can be unplugged from the motherboard.
As you see, I removed the DC-IN harness from the motherboard, plugged in the power adapter and tested continuity with my multimeter as it shown on the picture.
When the power cord is still, the voltage output is 15.45VDC, the same as on the plug.
But as soon as I start wiggling the plug inside the jack, the power cuts off and voltage goes to 0. It means, the power harness is bad.
The problem was fixed after I replaced the defective DC-IN harness with a new one.
In some laptops the power socket (DC jack) is soldered to the motherboard.
If the battery stops charging when you wiggle the power plug inside the jack, either you have a bad power adapter (test it with a voltmeter) or the power jack is broken or loose.
You cannot simply unplug the jack and replace it with another one. You’ll have to unsolder the old jack and solder a new one back on the motherboard as I described in this post.
If the power jack is not broken but loose (not making good contact with the motherboard) you can resolder the old jack without replacing it with a new one.
If you want to buy a new one,you can see more information from http://www.udtek.com
Feb 18, 2010 | Lenovo 3000 N100 Notebook
My power jack is broken. Need directions on how
You need to take the unit apart down to the system board. Sorry, I do not have the sefrvice manual.
The link below shows how to resolder the connector on the system board.
http://www.laptoprepair101.com/laptop/2007/12/06/dc-power-jack-repair-guide/
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Nov 30, 2009 | Lenovo IdeaPad S10-1208U Netbook
MY GATEWAY LAPTOP NO LONGER RECEIVES POWER.
Motherboard or harddrive? I'm betting it's more towards the motherboard. The DC Power Jack to be more specific. This is the port where the AC adapter, (Charger), plug is plugged into.
The DC Power Jack is not much bigger, than the plug for the AC adapter that plugs into it. There are small pin leads that are on the bottom of this jack, and they go through the motherboard, and are soldered to the motherboard.
Accidental bumping of the AC adapter plug, while plugged into the DC Power Jack, can damage the jack. It can break the connections for the adapter plug, and/or can crack the solder joints for those small pin leads.
[Laptops use DC electricity. A flashlight battery, and a laptop battery, are examples of stored DC electricity. DC electricity has two poles. Positive and Negative. The DC Power Jack has two connections. Positive and Negative. {Even if the DC Power Jack has multiple holes in it]
There is also another known problem associated with DC Power Jacks. It may stem from a bad motherboard design.
More to the point, the area where the DC Power Jack mounts on the motherboard. In this design, the DC Power Jack motherboard area, is almost a separate part of the motherboard. It's shaped like a Peninsula. (Think of an island, with one side connected to the mainland)
This peninsula shape, has the tendency to crack away from the main body of the motherboard. Circuit traces are broken.
When the AC adapter plug is setting in a certain position, it presses the two broken halves of the circuit traces together, for a momentary contact. As the AC adapter plug is moved from this position, the circuit trace halves are moved apart, and there is no contact.
(No distribution of electricity from one circuit trace half, to the other circuit trace half. Think of a circuit trace as a very, thin, flat copper wire. When a circuit trace is broken, there is essentially a wire that is broken into two parts)
Solution?
See if the DC Power Jack can be repaired, (Solder joint connections re-soldered), or replaced.
If the DC Power Jack motherboard area is the aforementioned peninsula shape, it may require replacement of the motherboard.
There are very FEW, computer repair shops that have the technical expertise to replace a DC Power Jack. Easy fix is to simply replace the motherboard. (More $$$$$ too)
However, some laptops DO require replacement of the motherboard for this repair.
Bad motherboard design, for the DC Power Jack area on the motherboard.
Re-solder DC Power Jack solder joints? (IF, this is the problem) Average is $50 to $75 (US)
Replace DC Power Jack? Average is $125 to $150. (US)
Replace motherboard? Depends on the Gateway model. Could be $225 to $400 (US)
[Yes, most of the time the cost warrants just replacing the laptop itself, as the cost of replacing, is close to the repair cost)
Just to SHOW you ab average DC Power Jack, and the repair involved of replacing. (Doesn't show you, that the entire laptop needs to be disassembled, down to the bare motherboard in hand)
This is NOT a recommendation to replace the DC Power Jack yourself! It is just for knowledge of what is partially involved. (You can accidentally burn the motherboard when desoldering, or soldering, rendering the motherboard useless)
Sep 09, 2009 | Computers & Internet
Lenovo 3000 N series 0768A39 model. problem in Motherboard
What problem specifically would that be?
If it's a problem with the DC Power Jack, (Port on your laptop where the AC adapter plugs into. The charger), this can be replaced.
Do be aware that there were bad motherboard designs, where the DC
Power Jack was mounted to. (Soldered) These bad designs, had a problem where the area of the motherboard that the jack was mounted to,
cracked away from the main body of the motherboard.
Let me explain that last statement in a little more detail.
Think of a laptop motherboard as being a 1 foot square. (It isn't, it's
irregular shaped) Now attach a 2 inch square to it.
This 2 inch square represents what the DC Power Jack is mounted to.
This small area has a tendency to crack, right along a line where it meets
I'm sure as you know, that there are signal traces on the motherboard.
Very thin, flat, copper strips, left behind after the motherboard has been etched by acid in the making of it. Like very flat, thin, copper wires.
When the DC Power Jack area cracks away, these traces are stretched,
and break. Sometimes if the DC Power Jack is in the right position, there
is an intermittent contact.
If your motherboard is made from a bad design as explained, the best
way to fix it is to get another motherboard. You can check on Ebay.
Weigh whether the cost of fixing it, or replacing it is the best solution.
Jul 10, 2009 | Lenovo Computers & Internet
Power connection broken
Sounds like the DC jack on the motherboard is broken. The jack is very inexpensive, but difficult to replace as it's surface mount soldered to the board and the laptop will have to be disassembled or the plastic case cut/modified to replace the DC jack.
Feb 09, 2009 | Lenovo 3000 N100 Notebook
Lenovo 3000 V100 Notebook Logo
994 people viewed this question
Top Lenovo Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
