Question about HP Compaq ProLiant ML350 G5 Server
Can I switch off the quad core in the cpu for the ML350G 5
  • 339 Answers
If you update the firmware you can disable half of the cores if this is helpful. Here is a link to some additional information: http://forums13.itrc.hp.com/service/forums/questionanswer.do?admit=109447627+1254105832570+28353475&threadId=1323607
Posted on Sep 28, 2009
Why my foxconn g41md -v motherboard does not support core 2 duo processor
It does support a core2 duo up to quad core but they have to be 1333fsb (front side bus). I suspect you have an early model of the cpu which isn't compatible with the 1333fsb such as a 670fsb. If you look at the back of your CPU you will see the model number. Google that and see the results. You will need to upgrade your CPU.
Apr 04, 2014 | Foxconn G41MD Core 2 Quad Intel G41 DDR3...
Needupgrading my cpu
ztz198,
On the top of every Intel processor is the sSpec Number, and the part number.
Intel Core2 Quad, that operates at a maximum frequency rate ('Speed'), of 2.66GigaHertz,.........hmmm,
Gateway Support indicates if the option is a Core2 Quad core, it will use Up To a 1333MegaHertz, Front Side Bus frequency rate, ('Speed'),
[1333MHz FSB]
http://support.gateway.com/s/desktop/2009/gateway/dx/dx4822/DX4822sp2.shtml
That 'narrows' it down to about 6 different processors.
Starting with the Yorkfield-6M Core technology, based on the 45NanoMeter architecture. (45nm),
http://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors#.22Yorkfield-6M.22_.2845_nm.29
1) Core2 Quad Q8400
2) Core2 Quad Q8400S
3) Core2 Quad Q9400
4) Core2 Quad Q9400S
Then on to the Yorkfield Core technology, based on the 45nm architecture,
http://en.wikipedia.org/wiki/List_of_Intel_Core_2_microprocessors#Yorkfield_.2845_nm.29
5) Core2 Quad Q9450
6) Core2 Quad Q9450S
The maximum frequency rate of 2.66GHz, is actually a low estimate. It is a little higher, and rounded off to 2.67GHz.
BIOS Setup might state 2.66GHz, but a better program like CPU-Z, IMHO; will state 2.67GHz. A more realistic figure.
Does it REALLY matter? Yes, and No.
This way when you get into a conversation, with fellow minded computer geeks, you will stand out as one who knows; what hardware components he/she is using.
Also helps you determine what voltage range is being used.
What Instruction Sets are being used.
What technology is being used, and use it to know if the upgrade CPU will indeed work.
Also whether a BIOS upgrade is needed.
I'm guessing it is the Intel Core2 Quad Q8400.
How?
I cheated, lol!,
http://www.newegg.com/Product/Product.aspx?Item=N82E16883113110
Intel Core2 Quad Extreme at a maximum frequency rate of 2.93GHz?
That would be the Intel Core2 Quad Extreme QX6300,
Based on the Kentsfield XE technology, and 65nm architecture.
Uses a 1066MHz FSB.
Motherboard chipset is the Intel G43,
http://en.wikipedia.org/wiki/List_of_intel_chipsets#Core_2_chipsets
(Scroll down. Is not in 'alphabetical order'. It is past the P45, and G41 )
Yep. Should work.
Makes me wonder though, about how you addressed the Thermal Paste; situation.
The old Thermal Paste MUST be THOROUGHLY cleaned off, and fresh, new Thermal Paste PROPERLY applied.
CANNOT reuse old Thermal Paste.
CANNOT reuse a Thermal Pad, IF used.
http://www.hardwaresecrets.com/article/274
Do I also assume the inside of the computer case is spotlessly clean, to include the Heatsink sitting on the CPU; and the cooling fan for it?
Heatsink was sit on CPU flat?
Cannot be even a little tilted.
For this reason I remove the motherboard, and install Heatsink.
Then I can hold the motherboard at eye level, and look across.
If a tiny crack of light shows on one side edge, of the Heatsink; then the Heatsink is NOT sitting flat.
This = No.
Four screws with springs on them, hold the Heatsink to CPU, Joe?
Yes. I know. This is so you cannot over-tighten the Heatsink to CPU.
You CAN however keep tightening, until the motherboard breaks, though. (Jus sayin')
However, if the screws are not tightened in a crisscross fashion, and tightened in incremental stages; the Heatsink may not be sitting flat.
Will await reply before going further. Post back in a Comment.
Regards,
joecoolvette
Note* Using capital letters for an entire word, is not 'shouting' from me.
It is to emphasize.
Mar 24, 2013 | Gateway DX482203 (PTGA002009) PC Desktop
CPU or Motherboard or both dead?
I would re-seat the CPU, and most likely the MB is not dead. You would not get any beeps if so.
Jan 31, 2013 | Intel Core i7-2600K 3.40GHz Unlocked...
Intel Core 2 Quad 8200 with a 945GCT-M3? Will it work?
Hello here is the homepage:
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?CategoryID=1&DetailID=719&DetailName=Feature&MenuID=1&LanID=0
Here you can see the supported cpu list.
The quad core cpu will not run on this mainboard.
Here is info about the quad cpu:
http://ark.intel.com/products/36547/Intel-Core2-Quad-Processor-Q8200-4M-Cache-2_33-GHz-1333-MHz-FSB
But you can add a Intel Core 2 Extreme LGA775
This should give a noteable difference compares to the old single core cpu.
Remember also to buy a bigger cpu cooling element.
Here is no upgrade for the bios.
Good luck
Nov 18, 2012 | Computers & Internet
Intel core 2 Quad Q6600 compatible with ECS P4M800PRO-M2
According to their website, no. The core 2 duo is supported, but not quad core. http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=674&CategoryID=1&MenuID=16&LanID=0
Look under the cpu tab.
Oct 31, 2012 | EliteGroup P4M800PRO-M2 (V2.0) Motherboard
What power supply would you recommend for a quad core processor?
Greetings - Even though the CPU is Quad core you could get by fine with a 350W PSU, unless of course you're going to have a killer juice sucking high end video card and/or are planning to overclock your CPU.
A good quality 450-500W would give you plenty of margin. More important to get quality vs rating numbers. Cheaper manufacturers tend to overstate the specs of their PSU's.
Enjoy your new CPU!
Mikeywaf
May 12, 2011 | AMD Phenom X4 9750 Quad Core Processor...
New CPU, No display
in my view, ur motherboard doesn't support the new processor, so plz check the capability of your motherboard, and replace with the supported cPU. ok byee
May 16, 2009 | Intel Core 2 Quad Q9550 2.83GHz Processor
Want start with new core 2 quad?
75% of all P35 motherboards are incompatible with Intel Core 2 Quad CPU's.  If you give the manufacturer name and the name of the place you bought it from we can help you further
Apr 19, 2009 | Computers & Internet
ASUS P5VD2-MX SE Motherboard CPU compatibility
Hello itsme99, click on this link I have posted. This link shows what CPU you're Asus P5VD2-MX SE motherboard can run.
http://support.asus.com/cpusupport/cpusupport.aspx?SLanguage=en-us&model=P5VD2-MX%20SE
You're board does not support Quad core CPU's!
This next link is the main page (Drivers, FAQ's ect.) for the Asus P5VD2-MX SE motherboard. (Look to the left of the page under Related Link). http://support.asus.com/download/download.aspx?modelname=P5VD2-MX%20SE&SLanguage=en-us
Here is a list of Asus Quad core motherboards.
http://event.asus.com/mb/quad_core/
Have a nice day.
Enjoy!
M
Jun 06, 2008 | ASUS P5VD2-MX SE Motherboard
HP Compaq ProLiant ML350 G5 Server Logo
101 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
